Autocom help - BMW Luxury Touring Community
post #1 of 11 Old Jul 24th, 2011, 8:05 pm Thread Starter
itspossible's Avatar
Autocom help
I recently returned from a trip around Newfoundland during which my Autocom died. We were running in the rain, first my wifes went, I could here her but she couldn't here me. Then the ipod music thru the headset died and the following day my headset died. The speakers on the bike work fine with the ipod its just the intercom.. Anyone else had this problem? I'm wondering if its a water issue from the rain, I opened the unit and it appears dry.
Suggestions on how to diagnose this would be appreciated, it's a 2002 LT
thanks
Ron
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
itspossible is offline
post #2 of 11 Old Jul 24th, 2011, 8:29 pm
Re: Autocom help
While we use a Baehr system, we had a similar problem. Turned out it was water ingress in the lead to my wife's helmet where it plugged into the short lead on the helmet. The intercom would go immediately after a sequence of loud static noises. Hotel hairdryer and liberal use of tape sorted the problem..
Born Again Middle aged BIker
K1600GT
C650GT
BAMBI is offline
post #3 of 11 Old Jul 25th, 2011, 12:40 am
Re: Autocom help
yes, have a had a "water" problem in the past also... applied a liberal amount of WD40 on all connections and the unit, and re-taped everything up to seal it better after the old tape had dried out... problem went away.
Good luck!
post #4 of 11 Old Jul 25th, 2011, 7:13 am
STARFIGHTER's Avatar
Re: Autocom help
We've ridden in some pretty heavy dpwnpours and no problem......
Unit is under the seat, all lead connections are in "holders" so open end of lead from unit is pointing down.
All connections to MP3 etc get wrapped in baggies in rain.
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
post #5 of 11 Old Jul 25th, 2011, 11:47 am Thread Starter
Re: Autocom help
Well I applied WD40 to all connections and jacks but still no joy. I did open the Autocomm unit to reveal the circuit board but saw no condensation and I did not spray any WD 40 on it, reassembled evrything but still nothing.
Is there a way to determine if the unit is powering up and generating a signal?
than ks
Ron
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
post #6 of 11 Old Jul 25th, 2011, 8:03 pm
Re: Autocom help
I don't know how old your unit is and how old your headsets are but the older the headsets are, the more likely that as you fiddle with the connection the more likely you can introduce cable problems and that can compound your original issue.
I have an older M5 (5 PIN headset connection) and If you have the headset on your ears and you plug in the plug to the Autocom and it is on you might be able to hear some clicking or scratching. Mine will give a 2 second series of tones in the headset when it is powered on and I have my helmet on.
Did you try plugging your headset into both headset plugs?
Did you meter the circuit that you have the AutoCom connected to to verify if you have the 12V.
When I bought mine there was a plug included that allowed me to connect a 9v battery to power the unit. If you have that you might try that.
If you don't have a spare cable you might be able to plug the headset directly to the AutoCom dongle bypassing the extension cable.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #7 of 11 Old Jul 25th, 2011, 11:46 pm
Re: Autocom help
Give the guys at rocketmoto.com a call/email. They have the best customer service on the planet!
If you are not living on the edge, you are taking up too much space!
'08 K1200GT
'04 1150 GS w/ ADV Tank
'05 F650 GS (My Wife's)
'00 Yamaha Drag Star 1100 (Sold, When I lived in Japan)
'94 Yamaha 400 Virago (Wife's, sold)
'83 Gold Wing (Sold)
'80 GSXR 400 (Sold, From when I lived in Japan in the 80's)
'83 Yamaha Maxium 550 (I got that one brand new from the dealer, Gave it to my best friend when I joined the Air Force)
'71 Yamaha LT 100 (Rode to death!)
frankgh is offline
post #8 of 11 Old Jul 26th, 2011, 1:07 pm
Re: Autocom help
thanks
Ron
Send it to me, I will check it out and let you know if it is repairable or not. Kieth
which unit is it ?
Kieth is offline
post #9 of 11 Old Jul 26th, 2011, 3:26 pm
Re: Autocom help
Sounds like Keith as great customer service too! Gotta love it when dealers are tracking you down! God Bless Capitalism!!
'08 K1200GT
frankgh is offline
post #10 of 11 Old Jul 27th, 2011, 2:39 pm Thread Starter
Re: Autocom help
Thanks for the offer Keith, I did manage to get 1 headset working this morning and found a broken wire in the other headset, so looks like the WD40 did the trick. I am a bit curious about the operating voltage though, I'm only getting 10.5 volts from the power source its tapped in too. Maybe I should change this.
Ron
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
post #11 of 11 Old Jul 27th, 2011, 3:39 pm
Re: Autocom help
Should be 12 volts ....ground to the negative of the battery.
I have new 7 pin headsets in stock, and some used 5 pin headsets. Kieth
Kieth is offline
Autocom vs Koss (Koss wins) bonafidebob Intercom, CB, & 2-Way Radios 11 Jan 29th, 2010 5:06 am
Autocom on 1200RT radio BrunoL RT Series 5 Sep 14th, 2008 4:24 am
Voice II to Autocom connector jdhargrave Intercom, CB, & 2-Way Radios 8 Jul 4th, 2008 6:15 am
Autocom Hollywood K1200LT 2 Mar 4th, 2008 8:18 pm
Autocom issues SteveHebert Intercom, CB, & 2-Way Radios 4 Nov 29th, 2005 2:38 pm
