Info wanted on Autocom 7 pin connector - BMW Luxury Touring Community
post #1 of 3 Old Jun 26th, 2011, 10:27 am Thread Starter
I am looking to make up a lead from a Autocom 'Active Rider' with the 7-pin connector to an existing helmet speaker and mic. So does anyone have the pin out specification?
sphoad is offline
post #2 of 3 Old Jun 26th, 2011, 8:34 pm
Re: Info wanted on Autocom 7 pin connector
you should find it here on the Autocom website...
http://www.autocom.co.uk/Support/Downloads/
post #3 of 3 Old Oct 1st, 2011, 1:31 pm
SportTourShop's Avatar
Ignore side car stuff. Diagram is old but mostly right.
Measure the impedance of your existing speakers and verify that they are 32 ohm. If they are less you risk burning up the amp. More will typically not generate as much volume.
I'd advise replacing microphone with Autocom's mic. It's miles better than anything out there. See part 2074.
Other than that, make sure the electrolet mic's positive goes to red and ground to shield. Make sure Yellow goes to ground. This controls the Auto-on feature.
Connector is a 7-pin 270 degree DIN. You can get from Digikey, etc. Understand that the Autocom cables have an overmold for water resistance and most connectors you order won't. Consider an old stock Autocom 2091 loom for easier install. Watch out as the 2091a does not break out for speakers.
Feel free to call with questions (888) 685-9269.
If I may ask, why are you looking to reuse headset?
SportTourShop is offline
It works!!! - ABS 2 fault reset (long) BDC K1200LT 114 Nov 24th, 2018 6:17 pm
Newbie needs info on autocom sytem mtntamer Intercom, CB, & 2-Way Radios 4 Jun 5th, 2011 8:58 pm
AutoCom /Bluetooth jseaver GPS 2 Oct 3rd, 2009 11:33 am
V-Strom Info wanted JK75RT Bike Talk 11 Sep 15th, 2006 12:16 pm
Touring Black Sea area - info wanted rmg08057 K1200LT 1 Mar 18th, 2006 9:05 am
