BC3 and 75-822 CB? - BMW Luxury Touring Community
post #1 of 6 Old Nov 25th, 2010, 9:39 am Thread Starter
notn2bars's Avatar
BC3 and 75-822 CB?
Just finished doing the rear main seal, slave cylinder repair on the k1200lt I purchased last year. I would like to add cb, as the group I ride with all use cb's, it is a mixed bag of riders.
Anyway, the bike has the J&M comm system. I was wondering if the Midland 75-822 can be hooked up to the comm system?
Beer is ok, wine is better, God is Great! and people, well, they're people.
Ed Jones
1969 Suzuki 500 -gone
Honda 350 - gone
Honda 450 - gone
1972 HD Sportster - gone
Kawasaki KZ 900 - gone
2000 Yamaha 1100 - gone
2000 Yamaha 1600 - gone
2001 HD Dyna - gone
2000 K1200 LT
2002 HD Ultra Classic
notn2bars is offline
post #2 of 6 Old Nov 25th, 2010, 11:17 am
shoswell's Avatar
Re: BC3 and 75-822 CB?
Gosh... Its been so long since I have dabbled in the comsystem its actually hard to recall... That said, if you have the BC3 as you state I would call up J&M to see if they make or know of an adapter. I think the OEM was a 820, but not certain. Under the stingray there are connections for a CB on the BC3 system. Figuring the pins out would be a trail and error issue. There may be schem's in the forum somewhere that could help. I however would go through the PS2 connection in the front as it would be easier to hunt and peck out the connections....
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #3 of 6 Old Nov 25th, 2010, 1:33 pm
blueknightga6's Avatar
I think the original was a 75-830. Mine was OEM and didn't receive or transmit, even the weather band. I now have the 822 installed. BUT, I used some redneck engineering and used the wiring harness from the old 830. I can now hear CB but have had a real hard time getting it to transmit using the headsets and the already installed PTT. Now here's the odd part. If I use the PTT on the CB itself, all is fine.
Chris Ehlbeck
blueknightga6 is offline
post #4 of 6 Old Nov 25th, 2010, 4:47 pm Thread Starter
notn2bars's Avatar
Thanks for taking the time to reply. I will give J&M a call tomorrow and see what they have to say. Should I post this on the main forum so see if anyone has any ideas?
Ed Jones
Honda 350 - gone
Honda 450 - gone
2001 HD Dyna - gone
2000 K1200 LT
post #5 of 6 Old Nov 26th, 2010, 7:32 pm
shoswell's Avatar
Sounds all too familiar. I had the same problems trying to get my Icom plumbed to the BC3. I ended up crossing over a wire on the mic side to make mine work. Sad to say now, but when I got the BC3 (not original to the bike) she had the CB all plumbed up. I sold the patch cord and like a stupid arse, i did not work out a wiring schematic...for future reference... never thought I would need or want a CB...
Hoss
shoswell is offline
post #6 of 6 Old Nov 27th, 2010, 8:44 am
My Midland 822 works like a champ using an automotive adapter in place of the battery pack. The wiring under the stingray is all there, but the thing is, you've got to make sure you've got the thing grounded properly for it to work well. There are/were grounding strap(s) that didn't originally come with the kit that were later included that fixed most problems.
If you can't find the kit with the straps, it's easy enough to make your own. Trick is to ground to the antenna mount to about three other places on the frame under the seat with a suitable wire harness. The supplied kit used a shrink wrap insulated braided 3/8" flat harness with soldered round connectors. You can also make your own push to talk switches/harness and save yourself some money. Got mine at Radio Shack..
BTW, I believe originally the Midland 75 820 and 75 822 were marketed separately with the 822 being the one that came with an automotive harness. They are the same radio. The 830 mentioned above was the 2nd iteration of the CB offered on 2002/2003 models I think.
1jusbill1 is offline
