BMW intercom squeal in heavy rain - BMW Luxury Touring Community
post #1 of 5 Old Aug 18th, 2009, 5:30 pm Thread Starter
kaswahn's Avatar
I'm going to try this here too - go little traffic and no replies in the Gadgets forum...
All,
tried the search but nothing turned up. We took our new-to-us 2002 LTE on the first long trip and everything was great except that the intercom system stopped working in heavy rain. We went through some pretty strong storms on our way back from OR and after about 5 min in heavy rain the intercom started to produce a continuous, loud squealing sound which could only be silenced by unplugging both helmets. Everything worked fine when plugging them back in after the rain had passed.
Anyone had this problem? I reckon there is water getting into something and shorting it out. Don't want to take everything apart - is there a place where water gets in easy?
Thanks for your help,
Frank
The Universe is expanding at 74.2 km/sec/Mpc.
kaswahn is offline
post #2 of 5 Old Aug 18th, 2009, 5:38 pm
JPSpen's Avatar
Re: BMW intercom squeal in heavy rain
Most likely the helmet connections themselves getting wet...
Then you get feedback....
Spray some WD40 into them and that'll displace the water.
Put the connector inside your jacket if you can and that'll help keep it dry..
Seal any other connections with a little bit of RTV and that'll keep those dry as well.
Good Luck
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #3 of 5 Old Aug 18th, 2009, 11:11 pm
blkswan's Avatar
I had the same problem with my first 03 LT. At that time BMW had J&M make their intercoms. We checked every connection and could not find a problem. The problem would intermittently happen from time to time, rain to no rain. I ended up speaking with J&M directly and they repaired the intercom at no charge, I have no idea what they did but the problem never occurred again. If your intercom came with the bike then I'm guessing your 02 has a J&M system, you might try contacting them directly. I would doubt the problem is with the head set connections, I've been through all kinds of weather with the same headsets and have never had the problem again. I would pull the tupperware off the left side and make sure all the DIN connectors are clean and wrapped with electrical tape. (along side of radio above gas tank) You also have a few under the passenger seat. Not to knock on anybodies home remedies but after working with electronics and electrical equipment for the last 20 years WD40 would be the last thing I would use in electrical connections, that's just my opinion I could be wrong.
Have fun.
Will Hedgspeth
blkswan is offline
post #4 of 5 Old Aug 19th, 2009, 5:46 am
wacolt's Avatar
I don't have the BMW intercom but, rather, have the Intarride system. When my bride doesn't ride for a while (measure using the calendar), corrosion tends to build-up on the connectors and creates a squeal when she first plugs in. After removing/reinstalling a few times, the squeal goes away.
Water intrusion seems to be your problem, as the others have mentioned.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
post #5 of 5 Old Aug 19th, 2009, 8:18 am Thread Starter
kaswahn's Avatar
Have fun.
Will Hedgspeth
Thanks Will. I will shoot them an email. I just cleaned and checked all connections by the radio under the tupperware before the trip they were/are fine.
Frank
kaswahn is offline
Final Drive failure - no BMW warranty support BobbyLT K1200LT 28 Aug 21st, 2014 4:14 pm
BMW Recall- 2007 Models RVB1019 Bike Talk 3 Nov 9th, 2011 8:04 pm
You guys are scaring me ! dnifong K1200LT 43 Feb 28th, 2008 10:31 pm
