Electronically Challenged - BMW Luxury Touring Community
post #1 of 7 Old Dec 8th, 2007, 4:34 pm Thread Starter
thehueg's Avatar
I have a 2006 K1200LT and plan a trip from Massachusetts to the rally in Gillette next summer and then on to Yellowstone, Glacier and then back. I have the VCII and would like to buy the BMW C.B. "ready-to-go". Do they offer a plug-and-play product? If so, what cost? Mounting? Additional materials required to make it work? By the way, I already have the PTT as I use a FRS radio with my son on his bike. However, he's not going and I recall the trucking community was often helpful in the "old days" when I had a C.B. in my four-wheeler. Appreciate any direction to photos, specs, etc.
thehueg is offline
post #2 of 7 Old Dec 8th, 2007, 11:44 pm
Hey Hueg,
Please, fill in a bit of your profile.. we like talking to new folks... and don't "sell" your name here.. right Admins??
Anyhow, there are no "plug-n-play" LT gizmo's such as you are looking for. If J&M sells the CB...goes up on the left handlebar and ties into the J&M BMW intercom. Can you say "Cha-ching!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !" ?
Here are some choices:
http://www.bikeintercom.com/products..._intercom.html
http://www.webbikeworld.com/motorcyc...com-review.htm
http://www.webbikeworld.com/motorcycle-intercoms/
Here is a place with a picture of the J&M CB http://www.motorcycle-communications...FQIQFQodBjmq8A
For myself, I don't like the "CB Chatter"... the FRS allows direct and discreet communication with my riding buddies.. without a lot of fiddling around.
Now, if you are still sold on a CB for "emergency" I suggest you buy one you can pack on your bike.. a small "emergency" CB radio should suffice.
On my most recent trip I found several of the Truckers have been using the FRS ... so you won't necessarily be "alone"... however, it's your call. For me, it's nice not having the CB cut into my music....or my lovely wife's singing...
J.M.J...
Dcn Channing
post #3 of 7 Old Dec 8th, 2007, 11:56 pm
ah... I omitted my personal choice..
www.intaride.com in UK
www.intarideusa.com in USA
J.M.J...
Dcn Channing
post #4 of 7 Old Dec 10th, 2007, 8:43 am
GBaker's Avatar
Just bought and installed the one specifically for the VCII. Part number you need is 71600441937. List is $495.00 Chicago BMW was $395.00. Plus you need the BMW antenna I think the list is $169.00 but this was also less at Chicago BMW.
Two very important points: This is the only BMW cb part number you want as it is the newest version for the VCII. Older ones had issues this one has cured. When I ordered mine it did not even show in the BMW Motorrad catelog web site. Also the BMW antenna needs to be checked upon install to be sure the center wire goes far enough up into the antenna to be engaged by the set screw that connects it to the antenna. Other wise you will have very limited range and will not be able to adjust the SWR.
Please trust me on these two points. Let me know if you plan to do the install yourself. If you have the dealer do it be sure he sands all ground connections and checks that little wire going up into the antenna. install is not that difficult. Most time consuming part is taking off and replacing the tupperware. It is bascally ready to go as the main plug for the VCII is prewired to recieve the din plug from the cb. There are a few more connections to make. Instructions are in the boxes for the CB and the Antenna.
Gene
'06 K1200LT
IBA 31499
GBaker is offline
post #5 of 7 Old Dec 10th, 2007, 9:10 am
GBaker's Avatar
One more suggestion regarding the FRS. If you have a Kenwood and while you have the tupperware off, go ahead and get a stealth antenna for the Kenwood. As you will have the sting ray apart any way, drill a small hole in it for the antenna cable. I ran mine under the tupperware and mounted it to the inside of the top piece of tupperware on the right handle bar. Out of sight, works better than the rubber duck antenna, and allow the FRS/GMRS radio to fit snuggly in the odiment box with the lid closed.
Gene
'06 K1200LT
IBA 31499
GBaker is offline
post #6 of 7 Old Dec 10th, 2007, 9:23 am
Gene.. how about a link to that part? and pics if available, please.
J.M.J...
Dcn Channing
post #7 of 7 Old Dec 10th, 2007, 9:34 am
GBaker's Avatar
The stealth antenna http://www.autocomamerica.com/produc...roductid/25774
Am very happy with it.
Gene
'06 K1200LT
IBA 31499
GBaker is offline
Armoured pants for the vertically challenged karp Rider's Gear & Luggage 9 Jul 22nd, 2007 6:41 pm
Help for the vertically challenged paulcbrowne K1200LT 0 Jan 31st, 2006 7:44 pm
Next Generation LT lovetomotor K1200LT 127 Jan 23rd, 2006 6:32 am
Any hope for the mechanically challenged? PolishS K1200LT 12 Oct 3rd, 2005 2:53 pm
