Lower Cord extender - BMW Luxury Touring Community
post #1 of 9 Old Sep 18th, 2007, 5:44 pm Thread Starter
Human Behaviour Analyst
Lower Cord extender
Wondering if there exists a lower cord extender I could use to bring my IC plug-in point from the LHS of the front fairing beside the computer to somewhere closer to me ... like beside the radio keypad for example.
Seems like the cord I have running from my helmet to the current connection point is a little "stretched".
As far as I know they're the standard length provided by J&M with the headset.
It's not like I'm the size of Yao Ming or anything either.
Any help is appreciated.
Keir
wkclark is offline
post #2 of 9 Old Sep 18th, 2007, 6:00 pm
kellenbenz's Avatar
The lower cord that I have from BMW has a length of about 2 ' without coils on it and is long enough to go over the handlebars without snagging anything. I think the standard J&M cords are shorter. The BMW cord should fit the J&M headsets.
Question....are you using a 1 piece cord from the helmet to the bike...or a 2 section cord that has a D shaped connector part of the way down?
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #3 of 9 Old Sep 19th, 2007, 10:27 am
kellenbenz's Avatar
I forgot to mention that you can make an extension cord also using parts from Radio shack. Go pick up a 6 pin din jack and a 6 pin din plug along with the length of wire that you require. The wires do run straight through from pin to pin ( unlike a lot of other things J&M built ) .
I made one of these 16 inches long and tested it on the bike...it allowed me to basically relocate the point where you plug the headset cord in.
HTH,
Ron
IBA 45658 MOA167437
post #4 of 9 Old Sep 19th, 2007, 4:40 pm Thread Starter
Hi Ron,
Thanks for the tips. I do have a D shaped connector just about 6" from where the headset enters the helmet.
Before I blow the wad on the BMW (Bring My Wallet) cord I think I'll explore the RadioShack 6 pin cord option as you suggest!
Appreciate the insights sir!
Keir
wkclark is offline
post #5 of 9 Old Sep 30th, 2007, 4:39 pm
kellenbenz's Avatar
I finally got around to taking a picture of the cord extender that I made. This allowed me to use the $21.50 J&M cord from Sierra Electronics instead of the $60 BMW lower cord. My headset with the lower cord cost me $115.00.
Headset = JM-HS-BCD257 $93.50
Lower cord= JM HC-PWY J&M Integratr $21.50
http://www.sierra-mc.com/proddetail....%2DBCD257%2DUN
This lower cord works perfectly as is for the passenger with no extension needed.
Ron
Name:	Cord extender.jpg
IBA 45658 MOA167437
post #6 of 9 Old Jul 2nd, 2009, 9:29 pm
Re: Lower Cord extender
Hi Ron,
I am having trouble getting the J&M lower cord to reach the fairing socket. Sierra Electronics acknowledged the J&M lower cord is too short; they only have one length.
Your post and picture are great, but I can't seem to articulate what I need to Radio Shack and looking on their website is hopeless.
Any ideas? I have a 2000 K1200 LTC like your RIP bike!
DaveFromDenver is offline
post #7 of 9 Old Jul 3rd, 2009, 6:01 am
kellenbenz's Avatar
Dave,
I actually took a worn out lower cord that was good on the end that connected to the bike and cut it to 16". Then I got a 6 Pin DIN Jack at Radio Shack and soldiered it on the cut end. I used an Ohm Meter to be sure that the wires were correct from one end to the other (they do go straight through).
If you don't have an old cord to use, you will need a 6 pin DIN plug, a 6 pin Din Jack and 16 " of audio wire with at least 6 wires.
HTH,
Ron
IBA 45658 MOA167437
post #8 of 9 Old Jul 3rd, 2009, 7:32 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
The plug in point on my bike next to the BC quit working & BMW wanted over $100.00 for a new one. I pulled the left upper fairing & found the point where that connector plugged into the wiring harness on the left of the radio.I then plugged my "Lower cord" in there and ran it along the radio & under the seat. After I put the bike back together I pull the cable out in front of my seat. It now runs straight up to my helmet & stay up next to my body out of the way.
Stevie Shreeve
katnapinn is offline
post #9 of 9 Old Jul 3rd, 2009, 10:49 am
You guys are the greatest.
Did you find a ready-to-plug-into jack? Are you using the "short" J&M lower cord or the BMW?
Voice II cord for the Motorola HF820 jhsonderb Intercom, CB, & 2-Way Radios 10 Nov 15th, 2007 4:14 pm
BMW headset system 1 cord pinout kellenbenz Intercom, CB, & 2-Way Radios 0 Apr 27th, 2007 9:47 pm
Intercom compatibility gstevens Intercom, CB, & 2-Way Radios 6 Dec 9th, 2005 10:22 pm
