Autocom to LT radio, Where? - BMW Luxury Touring Community
post #1 of 2 Old Jul 11th, 2007, 10:32 pm Thread Starter
JCarver's Avatar
Question Autocom to LT radio, Where?
I have the Autocom Pro 7 along with part #67, which is to connect the Autocom to the LT radio. This is the one that has the switch to use the speakers, headsets, or both. The question is, where to I connect to the radio? Where are those wires located? What color are the wires?
Rason I ask, I've been known to let the smoke out of some electrical equipment. :-)
tia, tcars
John C
John Carver
K1200LTC, AMA, BMWMOA
Greensboro, GA
JCarver is offline
post #2 of 2 Old Jul 12th, 2007, 2:17 am
check this thread... for links to info. One of the "Brochures" (cant remember which) has a good diagram of the LT install.
I originally tapped power from the seat heater connection, however it is OFF unless the bike is powered on, so if you are just sitting there without engine on, you lose the comms. When I installed the switch connector, I took power from the rear of the powerlet connection under the back speaker instead. This is HOT when the ignition is on the Accessory position, so you still get to tell your partner NOT to get off the bike until you got yourself steady!!!
Hope it helps.
cheers
Autocom Active Plus CB radio? samleaddrop RT Series 3 Jan 18th, 2010 8:36 am
A New Radio Problem? RVB1019 K1200LT 7 Sep 3rd, 2007 6:55 pm
Autocom & Satellite Radio tbarstow Intercom, CB, & 2-Way Radios 6 May 17th, 2006 8:38 am
'99 radio into an AutoCom? parishollow Intercom, CB, & 2-Way Radios 4 Nov 14th, 2005 7:01 am
