"No Radio" - BMW Luxury Touring Community
post #1 of 2 Old Apr 8th, 2007, 8:58 am Thread Starter
alstrickland55's Avatar
"No Radio"
Yesterday my radio quit working and I got the "No Radio" on the display. I have a 2002 LT with the BMW ComSystem which was made by J&M. There are several threads on this forum about the very same problem, and I read them all. This is apparently a common problem and there several possible solutions. Some have been able to solve the problem by disconnecting the battery for a while (30 minutes or more) and reconnecting it. I tried this and it didn't fix my problem. One person said his problem was caused by a blow 10 amp fuse located on the back of the radio. My fuse was not blown. One rider said that his problem was due to corrosion on the circuit board under the control buttons on top of the stingray. Apparently cracks in the rubber around the buttons allows moisture in, particularly when it rains or when the bike is washed. In his case he cleaned off the corrosion and it temporarily fixed the problem. Unfortunately, he found out that the rubber boots can't be replaced. I took the control panel apart and found no corrosion. In many cases replacing the radio was the only solution. Some have had their radios replaced several times. I finally tracked down my problem. The culprit turned out the be the Ice-Link I had installed for my Ipod. I disconnected the Ice-Link and the problem went away. I plugged it back in and the problem came back. The Ice-Link never worked very good anyway so now it's in the trash. I will just use the Aux. jack to listen to the Ipod.
Al Strickland
Blairsville, Georgia
1967 Honda Cub
1972 Honda CB350
1979 Suzuki GS750E
2009 R1200GS
2013 K1600GTL
2009 K1300GT
alstrickland55 is offline
post #2 of 2 Old Apr 8th, 2007, 11:39 am
I had the same problem with my Ice Link and replaced it with a the Dice unit. Seems to work much better, but still had a lockup this weekend. I will take a look at where I have my Ipod.
Dale White
"The shortest distance between two points is often unbearable."
— Charles Bukowski
desertlizard is offline
Help, radio flashing "no Radio" docwagner K1200LT 10 Jan 30th, 2020 3:04 pm
"NO RADIO" on LT simon K1200LT 6 Aug 23rd, 2006 2:14 pm
2730 "No XM antenna" MattyK GPS 0 Jun 16th, 2006 10:14 pm
"No longer a virgin" or "It's sooo primitive" eatanner South Central 6 Nov 2nd, 2005 8:15 pm
"No, honey, please!! Not the Motorcycle!!" Daman858 Chit Chat 0 Oct 18th, 2005 7:37 pm
