Baehr K1200 intercom fault diagnosis - BMW Luxury Touring Community
post #1 of 4 Old Jan 11th, 2007, 8:35 am Thread Starter
Rockdoc's Avatar
I had a Baehr K1200 unit fitted last July and was very impressed. However, recently Ruth's microphone's stopped working. The system recognises that her connector has been plugged in and she can hear me and the radio/CD fine but I can't hear anything she says.
There is no obvious damage to or disconnected wiring in her helmet. I have tried swapping her helmet to the driver's connection and connected it directly to the passenger outlet - without the extension lead - with no change.
My problem is that I had the work done in Germany, while on vacation, and the UK distributor doesn't answer my emails. Does anyone know how I can check the system to whether it is the mike that's gone down and not the passenger voice circuit itself?
Keith
UK 2004 K1200LT Lux - Katie
Rockdoc is offline
post #2 of 4 Old Jan 11th, 2007, 9:32 am
Senior Member (ret.)
RaffyK's Avatar
The easiest would be to swap mics and see if that makes a change. Then you will know to eliminate the mic as a problem or to identify that it is. Test her mic in your helmet and your mic in hers.
Raffy
RaffyK is offline
post #3 of 4 Old Jan 11th, 2007, 10:52 am
BLBantz's Avatar
This is a real longshot, but my wife's microphone went out last summer during a heavy rain. Everything else worked fine. After a few days drying out, it worked fine again.
Brian
Fanwood, NJ
2003 K1200LT Anthracite
BLBantz is offline
post #4 of 4 Old Jan 12th, 2007, 8:11 am
vstromboli's Avatar
My mic also went out and it turned out to be the small, black connectors in the helmet. I ended up soldering all the connections together and haven't had a problem since. Good luck.
Jacques
Dallas, TX USA
'05 K1200LT - '02 Suzuki V-Strom
vstromboli is offline
Baehr intercom users for K1200LT model advice. edonthenet Intercom, CB, & 2-Way Radios 5 Mar 6th, 2011 2:03 am
My Baehr is Working hschisler Intercom, CB, & 2-Way Radios 4 Jul 2nd, 2006 9:22 pm
Intercom advice: VoiceII, Baehr or Autocom hammick Intercom, CB, & 2-Way Radios 13 Oct 9th, 2005 10:48 pm
