CB For K1200LT - BMW Luxury Touring Community
post #1 of 14 Old Dec 9th, 2006, 1:24 pm Thread Starter
GBaker's Avatar
CB For K1200LT
My apologies if this has been asked before. I have searched to no avail. Has any one used or does any one know if the J & M JMCB-2003 handle bar CB will plug into and work as the cb for the VOICE Comm II?
Any additional adapters or wiring changes needed?
As J & M is the supplier of the BMW CB and a prior Comm system they understandably said they had no hook up for the German Voice Com. I have a FRS/GMRS that works well and the PTT is also installed. Just hate spending ~$600.00 for the BMW CB and Antenna....
Any other suggestions??
Gene
GBaker is offline
post #2 of 14 Old Dec 9th, 2006, 2:47 pm
Lynn_Keen's Avatar
Gene
I could be wrong but I don't believe the J&M bagded CB radio is plug and play compatible with the VOICE II. However since I've been known to be wrong once or twice I would suggest a call either directly to J&M or Sierra Electronics. Ask them the question and I'm sue they'll be happy to set you straight. By the way, I'd be interested to know what they tell you.
Lynn Keen
North East Florida
MSF #28271 Retired
'01 R1150 GS- totaled
'02 R1150 GS sold
'85 K100/EML sidecar sold
Lynn_Keen is offline
post #3 of 14 Old Dec 9th, 2006, 3:01 pm
SilverBuffalo's Avatar
I don't know the answer to the original question but rather have a question of my own along the same lines.
I have the CB that came from BMW on my 02 LTE (Midland ) and I'm wondering if it would be compatible with the Voice CommII on my 05 LT.
My guess is that whomever can answer the first question can also answer this one .
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #4 of 14 Old Dec 10th, 2006, 11:05 am Thread Starter
GBaker's Avatar
Thanks for the input from you and SB. I have contacted Sierra and will advise when I hear form them. My guess is yes with some possible tweaking.
GBaker is offline
post #5 of 14 Old Dec 11th, 2006, 9:22 am
jamesgoodchild's Avatar
I've hooked a J&M 2003 to my VoiceII. I had to build a custom connection and I had to put filters inline with it. It works, mostly. I've got a bit of a squeal during transmitt that I haven't been able to totally eliminate. I'm hoping to get some time over the winter to tear it apart and redo from the ground up.
So many toys out there, so little time!
2015 BMW K1600GTLE
2008 Piaggio 250 Betty's toy
2001 HD FLSTSI
1957 BMW R60
IBA #26695
RA #39456
MOA #150880
Always looking for more...
jamesgoodchild is offline
post #6 of 14 Old Dec 11th, 2006, 1:05 pm Thread Starter
GBaker's Avatar
Thanks James. That is encouraging. I would think it a matter of matching the input wiring from the Voice II to the feed from the CB. But am concerned as to any booby traps BMW may have rigged to block such a hook up.
GBaker is offline
post #7 of 14 Old Dec 11th, 2006, 4:14 pm Thread Starter
GBaker's Avatar
Lynn, Sierra says no but for a couple hundred dollars difference I may go the way James did and deal with a little sqealing.....
GBaker is offline
post #8 of 14 Old Dec 12th, 2006, 7:39 am
I believe it is more than just matching the wiring. Without filters, the squealing was quite bad. Possible impendence mismatch for the mic. The speakers did work well right from the get go. Bob Weir's excellent work on isolation filters with the Radio Shack "little green transformers" was a life saver. If you want, I could dig out the cable connection diagram I built for this.
2015 BMW K1600GTLE
2001 HD FLSTSI
1957 BMW R60
IBA #26695
RA #39456
MOA #150880
post #9 of 14 Old Dec 12th, 2006, 9:03 am Thread Starter
GBaker's Avatar
James that would be fantastic. If you could so and email or fax it to me. I will pm my email address to you.
Thank youso much.
GBaker is offline
post #10 of 14 Old Dec 13th, 2006, 11:05 am
Lynn_Keen's Avatar
James,
I too would be interested in the filter network that you built. I have the rebagded J&M unit that BMW sold back in '05 that was supposed to be compatible with the VOICE II. I've kind of given up on it. My problem is a squeel in the receiving radio when I transmit. Works OK when I receive transmissions from other radios. Perhaps I could adapt the filter(s) that you built and improve my results.
Lynn Keen
North East Florida
MSF #28271 Retired
'02 R1150 GS sold
post #11 of 14 Old Dec 14th, 2006, 1:14 pm
I went thru this with a switch from a 2000LT with the BC-3 and the JM CB that was installed when they came out in 04. Went to a 2003LT without a com system. Dealer could not get the BC-3 to work with the 03 radio...one plug was too large and would not allow the stingray mount properly. The Voice II would fit, but then the J&M CB would not mate up with the din plugs. J&M changed the din plug to match the VOICE II
Lowell
lvahl is offline
post #12 of 14 Old Dec 16th, 2006, 10:27 am
the1mavin's Avatar
Thumbs up
I would also be very interested in the diagram. I am in the same position as Lynn - I have the BMW/J&M unit that is supposed to work with the VOICE II.
Should I PM you with my email address?
Tim
2005 Graphite
The only way to live is in the wind....
the1mavin is offline
post #13 of 14 Old Dec 16th, 2006, 11:18 am Thread Starter
GBaker's Avatar
Tim
When I get it i will pm you.
GBaker is offline
post #14 of 14 Old Dec 16th, 2006, 4:21 pm
motorhead's Avatar
Chance of getting in the information loop ?
I have a Bahre comm unit that squeels like crazy with my Midland CB ... so as a result, CB is not getting used.
Have the same trouble with my ICOM gmrs 2 way when used on the battery eliminator power adaptor.
Tried the Rat Shack ground loop eliminator, but radios PTT function locks on transmit when it was hooked up
So like a LOT of folks, A CB on an LT, is not a good thing
Scott
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
