Still Having PROBLEMS with Razr Phone Connection - BMW Luxury Touring Community
post #1 of 10 Old Nov 28th, 2006, 11:48 am Thread Starter
GBowler's Avatar
Question Still Having PROBLEMS with Razr Phone Connection
Can anyone offer any suggestions? My 2006 K1200LT Comm System connects with my Verizon Razr phone - I can speak up to about 2 minutes - then it cuts me out and I can't talk with the other person on the other end of the call until THEY speak! Result: "in and out" conversations! We can't figure it out!
I'm connected by a mini-usb cable with a female adapter, then a male-to-male 2.5mm adapter that goes into the BMW comm system.
Any ideas? Thanks!
Gary Bowler
New York City
Gary Bowler
2006 K1200LT Magnesium Black
70 West 93rd St., #30E
New York, NY 10025-0012
(212) 222-6433
GBowler is offline
post #2 of 10 Old Nov 28th, 2006, 12:33 pm
What about your power off delay setting under car settings?
Should be 0.
Actually, what are all your settings under blue tooth, car settings, answer options, headset?
Brian Smith
2005 K1200LT
Canton, GA
smithbs is offline
post #3 of 10 Old Dec 7th, 2006, 9:06 am Thread Starter
GBowler's Avatar
Should be 0.
Hello Brian:
Thanks for the response! Are you assuming I'm connecting by Bluetooth with my GPS? My mobile is connected by a cord to the BMW comm system. Answer options on the phone are "auto answer". My headset has the traditional connection to the bike. Car settings? I'm sorry - I don't know what that means.
Let me know of any other settings I might need to adjust. Again, thanks for your time and help!
Gary Bowler
Mobile: 917 833 5104
[email protected]
Gary Bowler
(212) 222-6433
GBowler is offline
post #4 of 10 Old Dec 7th, 2006, 12:37 pm
Originally Posted by GBowler
Hello Brian:
Gary Bowler
[email protected]
Gary - I don't have the BMW comm system, so not sure about this suggestion. Wondering if there is a 'squelch' adjustment on your '06 comm system? My Autocomm system has a 'squelch' setting that is adjustable for ambient noise and 'mic' threshold trigger.
Just thinkin' outloud here; might check your comm booklet and see if they address that feature. Good luck.
post #5 of 10 Old Mar 20th, 2008, 2:49 pm
Richdude's Avatar
Re: Still Having PROBLEMS with Razr Phone Connection
Gary,
I'm finding the same problem but it seems to go away when the passenger is also plugged in.. I've tried all the settings and switches on the voiceII and after 2 minutes the music comes back an my voice won't stop it.
It's been a while, did you find a fix?
If no one has the right way to fix it, I think I'm going to make a dummy passenger dongle to plug into the rear socket and see what happens.
Richard
Richard Wright
'99 K1200LT Champagne(in Heidelberg)
'08 K1200LT Black
Richdude is offline
post #6 of 10 Old Mar 20th, 2008, 5:25 pm
jhsonderb's Avatar
With regard to ssquelch ettings on the Voice II, I think Dick may be on the right track. The closest thing to a squelch setting that I can see would be the mic level control for the Voice II. I was having problems with my Nokia phone until I adjusted the Voice II mic setting to "1". I think 1 is the most sensitive VOX setting as opposed to the higher numbers on the Voice II (which was my original mistake). If your phone behaves better at the 1 setting on the Voice II, you might want to play with slightly higher numbers because the person you are talking to on the phone may hear to much ambient noise at highway speeds.
Jim S.
'07 SturmGrau K1200LT
jhsonderb is offline
post #7 of 10 Old Mar 21st, 2008, 12:40 am
Richdude's Avatar
I think the problem is a design one. Maybe it's unique to the Razor, but I doubt it. Anyone able to ride solo, speak for longer than 2 minutes without the person on the other end responding, and not have the music cut into your conversation?
The vox is turned off with a solo rider, otherwise the music would stop every time you start singing along and it doesn't. When a solo rider use the phone the vox responses to the incoming voice, but still ignores the rider. It's hard to believe they missed that one, so there must be a setting we've missed.
The passenger plug dongle fixes the problem. 32 ohms between pin 1 and 2; 32 ohms between pin 4 and 5; 265ohms between pin 1 and 6. The VoiceII thinks there is a passenger and the vox always responds. Phone calls work perfectly. Singing however, is solo, since the music now stops when you start.
Richard Wright
'08 K1200LT Black
Richdude is offline
post #8 of 10 Old Mar 21st, 2008, 10:27 am
jhsonderb's Avatar
Very Interesting! That seems to explain why my Nokia phone looses connection when I call my home to leave a message on my answering machine since my answering machine doesn't speak back (other than the opening greeting). Also, most of the time when I'm on a phone call, the caller does most of the talking: I usually only say "Yes, dear", or "huh". So maybe that is why my Nokia phone doesn't seem to loose connection. I'll have to do some further testing when I can get back in the saddle.
Do you have a schematic for the dongle you describe. Is it something that you plug into the passenger headset bulkhead jack?
Jim S.
post #9 of 10 Old Mar 21st, 2008, 12:52 pm
Richdude's Avatar
Yes, plug it into the passenger headset jack when riding alone.
Here's a the schematic. If you don't have the parts handy, I've got some extra din connectors. I'll make a dongle and mail it for $6.
Name:	pass sub dongle circuit.jpg
Richard Wright
'08 K1200LT Black
Richdude is offline
post #10 of 10 Old Mar 21st, 2008, 9:18 pm
Richdude's Avatar
On further testing, only the resistor that replaces the mic is necessary. Any value from 200 to 2k ohms works.
Richard Wright
'08 K1200LT Black
Richdude is offline
Razr owners: Inexpensive bluetooth into intercom fix hammick Intercom, CB, & 2-Way Radios 22 May 14th, 2008 2:29 pm
Not ANOTHER cell phone!!! messenger13 Chit Chat 5 Nov 17th, 2006 8:46 pm
Requesting Help! Razr phone connectivity to BMW comm system GBowler Intercom, CB, & 2-Way Radios 4 Nov 12th, 2006 4:24 pm
Please Help Me Find Verizon Razr Phone Connecting Cord! GBowler Intercom, CB, & 2-Way Radios 17 Oct 18th, 2006 1:07 pm
Baehr & Cell Phone Use, Two-Up hschisler Intercom, CB, & 2-Way Radios 1 Aug 21st, 2006 2:38 pm
