SENA 20s Echo - BMW Luxury Touring Community
post #1 of 6 Old Sep 30th, 2015, 4:25 pm Thread Starter
drmajor's Avatar
SENA 20s Echo
I have 20s and wife has SMH10.
Usually, I get an echo when we talk. She does not hear it.
Suggestions?
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
post #2 of 6 Old Sep 30th, 2015, 4:40 pm
mwnahas's Avatar
Re: SENA 20s Echo
Do you have sidetone turned on?
Just Go
Cleveland Ohio
2014 K1600 GTL Grey Wolf.
mwnahas is offline
post #3 of 6 Old Sep 30th, 2015, 6:03 pm Thread Starter
drmajor's Avatar
Re: SENA 20s Echo
yes., but how can the mic pick up the earphones? I dont turn it up a lot..
David Major
Charleston, SC
-2003 LT
drmajor is offline
post #4 of 6 Old Oct 1st, 2015, 8:23 am
PadG's Avatar
Re: SENA 20s Echo
Don't know the exact nature of your echo, but Sidetone is the feature that lets you hear what your microphone pick up, like when you talk! Your wife probably had hers turned off, and so she doesn't hear the echo! It's easy enough to turn yours off, and see if the echo goes away.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #5 of 6 Old Oct 1st, 2015, 9:07 am Thread Starter
drmajor's Avatar
Re: SENA 20s Echo
Will try....after hurricane goes by..
David Major
Charleston, SC
-2003 LT
drmajor is offline
post #6 of 6 Old Oct 5th, 2015, 2:24 pm Thread Starter
drmajor's Avatar
Re: SENA 20s Echo
Just got word from SENA tech support..
Sorry for the delay.
If there is an echo, you will need to disable SIDETONE from the configuration menu setting.
Different bikes, devices, and applications are going to output different levels of sounds and volumes.
As for volume there is only one way on the Sena to adjust volume.
You can easily adjust the volume by rotating the Jog Dial. You will hear
a beep when the volume reaches the maximum or minimum level. The
volume is set and maintained independently at different levels for
each audio source even when you reboot the headset. For example,
once you set the volume for mobile phone handsfree, it will not change
even if you adjust the volume for your Bluetooth MP3 music. However,
if you adjust the volume during stand-by mode, it will affect volume
levels of every audio source.
You can try to adjust the volume as well from the Garmin 660.
Thanks and have a wonderful day!
Sena Technologies Inc. Support Team
> So, as I read this, if using the Garmin 660 and I set the volume to "5" and when talking with wife I set her to "7"- it will "mix" that ratio....???
David Major
Charleston, SC
-2003 LT
drmajor is offline
Sena 10C rangemaster Intercom, CB, & 2-Way Radios 6 Oct 7th, 2015 8:26 am
Review - SENA Prism POV Camera. PadG Other Stuff 19 Aug 9th, 2015 9:25 am
SENA BT Device Manager Issues? rangerb3 Intercom, CB, & 2-Way Radios 4 Mar 1st, 2014 10:10 am
Sena vs 2012 RT golf18 RT Series 16 May 6th, 2013 2:08 pm
News on Firmware for Sena SMH10, RT specific Dasadab Intercom, CB, & 2-Way Radios 4 Oct 19th, 2012 10:58 pm
