SENA 20s - BMW Luxury Touring Community
post #1 of 4 Old Sep 16th, 2015, 4:19 pm Thread Starter
drmajor's Avatar
SENA 20s
I have SENA 20s.
It is Paired with my Iphone and Garmin 660..
I would like to also pair to my Escort 8500. Sena makes a BT unit, SM10 I think @$139.
Will it work to get a BT Transmitter (say Bluetooth 4.0 @$30) and plug into the Escort?
What is the protocol SENA uses, or how can I "know" it will work?
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
post #2 of 4 Old Sep 16th, 2015, 4:29 pm
zippy_gg's Avatar
Re: SENA 20s
Do you ride often 2-up? If so, do you use the intercom a lot?
This is important if you are going to use the SM10 to connect your Escort (and Zumo 660 too if you'd like) because if you are using the intercom you will NOT get radar alerts, and if you are getting radar alerts you won't be using the intercom. Let me explain... You will need to tap the jog dial (I have the SM10-H and not the 20s) to toggle back and forth between the 2 modes Intercom/Sm10. You can use the SR10 instead of the SM10 and that issue will disappear, but you may find the Escort too chatty and interrupting your intercom conversation... That is where i am at, and I think I will add a visual alert to the radar detector and forget about the audio alerts, something like the Mark Parnes unit
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 4 Old Sep 16th, 2015, 9:51 pm
johnbaker15's Avatar
Re: SENA 20s
Originally Posted by drmajor View Post
I have SENA 20s.
The Escort 8500 has an Earphone jack output so you could do a hardwire output feed into any BT transmitter and pair that with the 20S. There is no BT protocol involved to worry about, just the hard wire.
The Sena SM10 is a bluetooth transmitter that can pair and brodcast to two headsets at the same time. So you should be able to use the earphone output from the Escort into the SM10 and BT transmitted to the 20S. The SM10 is designed to "talk" to two headsets at the same time.
HTH
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #4 of 4 Old Sep 17th, 2015, 6:13 am Thread Starter
drmajor's Avatar
Re: SENA 20s
Thanks....
What I hope to do is use an after market BT transmitter ($30) into the earphone jack of the 8500.
I have heard some say they could not pair some Garmin Nuvi with Sena, so didn't know if there was issues,
David Major
Charleston, SC
-2003 LT
drmajor is offline
Sena 10C rangemaster Intercom, CB, & 2-Way Radios 6 Oct 7th, 2015 8:26 am
Review - SENA Prism POV Camera. PadG Other Stuff 19 Aug 9th, 2015 9:25 am
SENA BT Device Manager Issues? rangerb3 Intercom, CB, & 2-Way Radios 4 Mar 1st, 2014 10:10 am
Multiple GPS with Sena SMH10? Deek RT Series 2 Feb 8th, 2014 10:46 am
News on Firmware for Sena SMH10, RT specific Dasadab Intercom, CB, & 2-Way Radios 4 Oct 19th, 2012 10:58 pm
