Charging System Problem - BMW Luxury Touring Community
post #1 of 1 Old Apr 23rd, 2008, 10:29 am Thread Starter
jwd98056's Avatar
I have been having indications of problems in the charging system for a little while. My cruise control won't stay engaged, headlight dims slightly when applying brakes or with the cycle rate of my Gerbing jacket liner at low engine RPM . Who needs a headlight modulator . I also get a tailight fault indication when braking at low RPM. It has been cranking over slower than normal if I don't put it on the battery tender in the garage. It finally wouldn't start after an extended ride around town on Saturday. I got it jump started and rode it home via the freeway and it started when I got home. It seems to be providing some charge at highway cruise conditions or higher RPM but not enough to keep things going in stop and go traffic.
I have been through all the usual suspects; replaced the battery, checked the alternator belt, checked the battery connections and looked for possible short circuits. That pretty much leaves the alternator or the ZFE module. My vote would be the alternator. I am just coming up on 24k.
I bit for the extended warrenty so it looks like I will be getting a good chunk of it back .
#32756 -
#122647
'12
FLTRU Ember Red Sunglo (
'05
R1200GS Desert Yellow (
'00
K1200LTC Canyon Red (
) - Retired 10/2012
'02
FLSTC Custom (
jwd98056 is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Sputtering problem speedy K1200LT 22 Nov 20th, 2009 12:17 pm
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 11:37 pm
Opening the Com System? LTPenguin Intercom, CB, & 2-Way Radios 6 May 5th, 2007 12:50 pm
charging problem, maybe?? boocoo_dinky_dow K1200LT 3 Apr 26th, 2006 4:12 am
