Intermittent Rear TPM Sensor - BMW Luxury Touring Community
post #1 of 13 Old Apr 22nd, 2018, 1:05 pm Thread Starter
Question Intermittent Rear TPM Sensor
Every once in a while the rear TPM readout shows -- instead of a pressure indiction. Sometime its hours, sometimes it minutes before it goes back to displaying a pressure. I assume that the TPM monitor on the inside of the tire must has some type of battery allowing it to transmit. Is what I'm seeing an indication of the TPM battery going dead?
Mother Goose
MotherGoose is offline
post #2 of 13 Old Apr 22nd, 2018, 2:24 pm
Temesvar's Avatar
Re: Intermittent Rear TPM Sensor
The TPMS sender has a battery and it should last 6-7 years.
Mine lasted almost 9 years, but as it gets weak, it will show
nothing, or just horizontal lines, either front or rear. Unfortunately,
the batteries are not replaceable, and the senders cost a small fortune ...
2008 RT Biarritz Blue
2007 Triumph Sprint ST(sold)
memories:
1986 Yamaha FJ 1200
1985 Yamaha FJ 1100
1983 Yamaha XJ 900
Temesvar is offline
post #3 of 13 Old Apr 22nd, 2018, 5:51 pm
beech's Avatar
If you're handy, several videos on YouTube showing how to change out the battery. Personally, I'd try this first. The torque to re install is 9Nm. Check for leaks with soap bubbles. If you buy aftermarket units they have to have the serial number on the inside curve so you can link them to the bike computer via a GS-911. One of the aftermarket shops, beemerboneyard or Euromotoelectric had a price break on them. Be vary suspicious of any Asian units. No monitoring unit is install and use, all have to be synced to your bike.
Beech
beech is offline
post #4 of 13 Old Apr 22nd, 2018, 6:28 pm
Temesvar's Avatar
As beeck mentioned, here is the video:
https://video.search.yahoo.com/searc...8&action=click
I never tried it, and nobody I know bragged about. The problem with it is,
you will never know you did a good job until you go for a ride with it.
I will try it, but when will change tires, sometimes this summer. Will
post if successful or otherwise. If not, will have to wait for the next tire
change. My bike is a 2008 and the TPMS worked until late last year, so
about 9 years.
memories:
1986 Yamaha FJ 1200
1985 Yamaha FJ 1100
1983 Yamaha XJ 900
Temesvar is offline
post #5 of 13 Old Apr 22nd, 2018, 11:36 pm
beech's Avatar
I forgot about the hassle of tire changing or just removing to insert this thing. I wish you lived closer. I'd install it for you and test it here. I have a tire changer up in the shop that works really cheap. Just to pull the tire and install will cost you 50 to 100 bucks at the dealer. Fun part about the new bmw unit, the code number is on the inside portion of the device so you install it, can see nothing put the tire on, and install the wheel. Now you have to type in the code to the gs911, oh darn I did not write it down, it's in the wheel. And it is not the part number on the side of the unit. And to top it off, one guy on the ADV.com site installed some Asian ones, turns out the code was HEX decimal not a normal code the computer looks for. He figured this out and transposed it to base 10 numbers and all went well.
I put some more effort into it, here is a great deal on the real thing:
https://www.beemerboneyard.com/36237694420.html
Now you need a GS-911 to connect them to your computer on the bike or have a dealer sync them, remember my warning about where the correct sync number is.
(Change them both at the same time.)
Beech
beech is offline
post #6 of 13 Old Mar 31st, 2019, 7:38 pm
I don't know where you guys shop but max BMW sells a pair of oem sensors for $243.
The Chinese knockoffs are crap.
Teach is offline
post #7 of 13 Old Apr 1st, 2019, 10:31 am
chromedomeRT's Avatar
Whats' your discount code? Mine came out to $449 for a pair.
Name:	Screen Shot 2019-04-01 at 7.20.27 AM.png
chromedomeRT is offline
post #8 of 13 Old Jul 15th, 2019, 10:07 pm
Chrome, don't know which site you used but I just replaced front and rear, $243 for the pair + shipping from MAX. Try one of the other links
Teach is offline
post #9 of 13 Old Jul 16th, 2019, 3:50 pm
beech's Avatar
I was just on MAX site looking at the 03 to 09 RT for sake of argument. The front is listed as 236$ and the rear about 224$. Both are 1 each in the listing. How did you get a pair for 250? I buy 99% of my parts there and keep an eye on prices.
Beech
beech is offline
post #10 of 13 Old Jul 18th, 2019, 6:47 am
Beech, don't know what is up. I just purchased 2 for my 11 GS for $243 + the shipping in April. I looked today and I am seeing a price of $236.57 each. I was actually PO'd when the sensors showed up and I had to order 2 rebuild kits because the sensors didn't come with the rim seal and lock nut. Maybe I just got lucky. Regardless, they're showing $237 each when I looked today. Guess I should have purchased a set as backup in April.
Teach is offline
post #11 of 13 Old Jul 21st, 2019, 11:49 pm
beech's Avatar
Yes, they are pretty outrageously priced. There are enough of these out there someone could make a good business making a working (read non rip off) aftermarket unit.
Beech
beech is offline
post #12 of 13 Old Sep 4th, 2019, 6:55 pm
I am not a fan of tpms in the first place. In my opinion it's just one more thing that can break.
Teach is offline
post #13 of 13 Old Sep 5th, 2019, 9:06 am
SpinDog's Avatar
Saved me once, picked up a nail somewhere along my ride and warned me before I got onto the super slab.
2014 R1200RT - Quartz blue metallic
2010 Kawasaki VN900
-CT USA-
SpinDog is offline
Rear brake question Artm635 RT Series 16 Apr 19th, 2014 2:30 pm
BMW Motorcycle Quality 150flyer Bike Talk 5 Oct 28th, 2013 8:30 pm
LT rear speakers come on initially and then cuts out joseph_p K1200LT 10 Apr 29th, 2010 8:27 pm
2005 Rear End Jerrym K1200LT 28 May 17th, 2007 8:34 pm
Linked brakes negative bmwrubbercow K1200LT 19 Aug 4th, 2006 4:00 am
