Electrician question - Voltage coming through an off switched outlet. - BMW Luxury Touring Community
post #1 of 15 Old Sep 6th, 2012, 2:18 pm Thread Starter
I noticed a low voltage (florescent) bulb in a lamp flickering last night after the wall switch was turned off. Could not believe this was happening so I measured the voltage coming directly from the outlet and it measured about 10% of the regular voltage.
Something does not seem right! Can anyone explain this?
post #2 of 15 Old Sep 6th, 2012, 4:58 pm
sperra's Avatar
Re: Electrician question - Voltage coming through an off switched outlet.
Time for a new switch ? maybe a mouse removal
sperra is offline
post #3 of 15 Old Sep 6th, 2012, 6:35 pm
One possibility is that something else up the chain is on, and too many connections in the neutral (white) wire between that and the electrical panel. A voltage drop can show up in the neutral line can show up as voltage in a light fixture.
Use your volt meter to test between the white wire and a good ground, it normally should be at or very near zero. If more than that, you have "dirty" neutral wiring.
One common cause is a "non solid" neutral, with it open at some point. White neutral wires should never be seperated in a fixture so that removing them from the fixture results in an "open" neutral. Anywhere a neutral circuit is wired into a fixture, switch, etc., it should be with a pigtail crimped or wire nutted to the two white wires coming into the box. Most fixtures will not have more than one, unless fixtures are in parallel.
I have seen people put the two white wires under the screws on a switch or fixture, but removing them to replace the device leaves other devices upstream without a return, and can be dangerous.
post #4 of 15 Old Sep 6th, 2012, 7:25 pm
deanwoolsey's Avatar
What David said. Got me a big surprise one day changing out a ceiling fan. Someone had wire nutted several neutral wires together and I found the live return when I took the nut off to attach the fan. OUCH!!!!!
deanwoolsey is offline
post #5 of 15 Old Sep 6th, 2012, 7:44 pm Thread Starter
Thanks David,
I'll pull the switch first and then check to see if it looks ok. My guess is that there is a neutral not connected correctly. I have noticed that plugs in the same outlet spark when plugged in.
post #6 of 15 Old Sep 6th, 2012, 11:08 pm
LJSMITH1's Avatar
Is there a dimmer somewhere in the circuit? If so, check to see if it has a nightlight feature on the dimmer (a small neon glow behind the button or rocker when off). If so, this is the source of your Voltage.
2005 BMW K1200LT Blue
BMWMOA #124788
Predecessor:
1999 K1200LT (entered the BMW "organ donation program" on 6/2/11) 38,256 Miles
LJSMITH1 is offline
post #7 of 15 Old Sep 7th, 2012, 7:18 am Thread Starter
No dimmer. There is a wall switch that controls 1/2 of a two prong outlet. My guess now is that there is a bad ground or white wire possible in the two prong outlet. It really is spooky to have the switch off and the lamp flickering!
post #8 of 15 Old Sep 7th, 2012, 8:49 am
DanMartin's Avatar
How do you get a switch to only control half of an outlet?
I thought there was one inlet for both plugs.
DanMartin is offline
post #9 of 15 Old Sep 7th, 2012, 9:50 am
johnbaker15's Avatar
DanMartin,
If you look at the outlet on the side there is a break off tab. Wire the power to bottom of the outlet, break off the tab and wire the switch to top of the outlet.
Most all room entry switches that do not control an overhead light are wired to a wall outlet and swith the top of the outlet. HTH
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #10 of 15 Old Sep 7th, 2012, 1:06 pm Thread Starter
We have a lot of them like that. Switch controls several lamps in the room but does not turn off things plugged into the top. Works well, most of the time!
post #11 of 15 Old Sep 7th, 2012, 8:01 pm
Dan,
Must be a regional thing...north vs south.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
post #12 of 15 Old Sep 7th, 2012, 8:17 pm
That is the way most electricians will wire them, bottom switched, top always hot. Lamps plugged into the bottom switched, allowing easier plugging in other items (better visibility on top rather than reaching under the lamp wires).
post #13 of 15 Old Sep 8th, 2012, 7:39 am
mtrevelino's Avatar
Also, in most newly constructed homes, the electrician will turn the receptacle around, so all the "normal" receptacles will have the ground at the bottom on the hot and neutrals, while the combination plug will have the ground on top of the hot and neutrals. This way you can walk into a room and immediately tell which outlet is controlled by a wall switch.
Mike Trevelino
Williamsburg, VA
2008 RT - Sold December 2019
mtrevelino is offline
post #14 of 15 Old Sep 8th, 2012, 9:19 pm
Dan, pull the wires from the switch and then check voltage, we get small sugar ants in Fl and they love switch devices. Ping me if you get stumped. I am a state Mechanical contractor & Master Electrician. Don't ignore this.
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #15 of 15 Old Sep 9th, 2012, 2:39 pm
gunny's Avatar
Broken neutral somewhere. Might be a loose neural connection.
B D R
gunny is offline
Zumo 550 voltage question Dann323 RT Series 2 Mar 30th, 2012 6:08 pm
more power (voltage outlet) baker K1200LT 4 May 9th, 2009 8:28 pm
Accessory outlet question??? motorman587 K1200LT 3 Feb 3rd, 2007 6:10 pm
Power Outlet Question dwillie K1200LT 7 Aug 30th, 2006 6:11 pm
