RV electrical question - BMW Luxury Touring Community
post #1 of 6 Old May 9th, 2008, 7:16 pm Thread Starter
Chick's Avatar
Question RV electrical question
Do any of you electrical gurus out there have any idea how many 50 amp 125/240 extension cords you can string together from the power source to the RV?
Is there a significant loss of power over a certain distance, risk of fire, or any other problem?
Chick
Saved by Grace -- Ephesians 2:8-9
2005 Graphite LT
BMWMOA #118809
NRA Life Member
Chick is offline
post #2 of 6 Old May 9th, 2008, 7:35 pm
gunny's Avatar
Re: RV electrical question
Depends on how much of a voltage drop you can tolerate and that will depend on how many amps (load) size of wire and how far you string this wire.
Gonna make a couple of assumptions here. I'd say that you'd be OK out to 100' providing you don't try to run too much stuff at the same time causing a large amp draw and then a voltage drop. Put the reefer on gas, be sure the water heater is on gas, tell the electric control panel that you are on a 30 amp circuit and you'll be OK. Measure the voltage, line to neutral and as long as it dosen't drop below 108 you can assume all is well.
B D R
gunny is offline
post #3 of 6 Old May 9th, 2008, 7:57 pm Thread Starter
Chick's Avatar
Thanks for the input, Gunny. Unfortunately I have an all electric rv, so I can't switch to gas. I was hoping for a 100 foot distance.
Here is a description of the cords I am looking at:
"36 feet 50amp RV / Camper extension cord rated for 125/250V. This cord is UL and cUL approved so it suits both the U.S. and the Canadian market. This high quality power cord has three 6 gauge and one 8 gauge 100% copper wires that are individually insulated and color coded."
Chick
2005 Graphite LT
BMWMOA #118809
NRA Life Member
Chick is offline
post #4 of 6 Old May 9th, 2008, 9:03 pm
That 50 amp cord is going to be much less than 50A if you add more of them to get you 100'
Try looking here http://www.myrv.us/electric/
Morley is offline
post #5 of 6 Old May 9th, 2008, 9:11 pm
Just ridin'
Randy's Avatar
With 6AWG conductors at 100 feet you are looking at about a 2% voltage drop at 50 amps. This drop is for solid copper wire - stranded extension cords will actually have less voltage drop. You should be fine.
Randy Prade
Aurora, CO
Just ride it!
Meet Riley
Randy is offline
post #6 of 6 Old May 9th, 2008, 9:36 pm Thread Starter
Chick's Avatar
Thanks, guys! As usual you are VERY helpful.
God bless
Chick
2005 Graphite LT
BMWMOA #118809
NRA Life Member
Chick is offline
Bussed Electrical System? 2wheeljunkie Batteries, Chargers, & Electrical 8 May 12th, 2008 7:04 pm
Progress/Autoswitch/fuel line question yechave K1200LT 6 May 7th, 2008 4:23 pm
Stupid Electrical Question LTPenguin K1200LT 6 Sep 4th, 2007 4:00 pm
Suspension adjustment assembly question davek1 K1200LT 2 May 8th, 2007 10:24 am
Dauntless Wiring Question pieceofficer K1200LT 12 Apr 16th, 2007 11:35 pm
