A car question - BMW Luxury Touring Community
post #1 of 5 Old Feb 8th, 2008, 8:02 am Thread Starter
c00k1e's Avatar
A car question
My car (a petrol fuel injected runabout) runs fine till I decelerate. When I come to accelerate again it bunny-hops!
It doesn't stall whatever I do and if I decellerate without using the gears (clutch and brakes) it is fine accelerating
Any ideas what could be wrong?
c00k1e is offline
post #2 of 5 Old Feb 8th, 2008, 9:09 am
AliMar's Avatar
These days with all the computers and sensors its tough to make a call without the device that reads the fault codes. A wild guess would be a fouled up sensor on the exhaust side making the computer change injector spray timing when you get back into it... Without the fault codes you could spend a ton of time and money chasing the unknown...
Mark
'07 RT
AliMar is offline
post #3 of 5 Old Feb 8th, 2008, 12:01 pm
blankshot's Avatar
What make is it and engine size? It could be many things but maybe we can point you in the right direction. By the way is there a check engine light on?
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
blankshot is offline
post #4 of 5 Old Feb 8th, 2008, 12:37 pm Thread Starter
c00k1e's Avatar
This is way older than a fault code reader. I ride bikes and have banger cars for really bad weather.
Its a 15 year old French car.
c00k1e is offline
post #5 of 5 Old Feb 8th, 2008, 2:04 pm
If you are talking about a drivetrain issue,
If rear wheel drive, U-Joint could be about to snap...
If front wheel drive, CV joints could be shot and about to snap...
In either case, a bad Motor Mount could cause this as the "slack" is taken up.
J.M.J...
Dcn Channing
Question??????? NOGILLS2 K1200LT 6 Jul 10th, 2007 3:35 pm
Suspension adjustment assembly question davek1 K1200LT 2 May 8th, 2007 9:24 am
Dauntless Wiring Question pieceofficer K1200LT 12 Apr 16th, 2007 10:35 pm
Another seat question Smith K1200LT 2 Mar 28th, 2007 12:21 pm
potentially dumb air pressure question petevandyke K1200LT 11 Sep 24th, 2006 7:44 pm
