Technical Non Bike Question: Repairing Plastic LEAK - BMW Luxury Touring Community
post #1 of 7 Old Jul 28th, 2007, 8:57 am Thread Starter
Way off Bike topic, but I felt with all of the collective knowledge, someone would know how to fix this problem without replacing the whole pump. Got back from a 1,500 mile trip to find the pool pump plastic housing with a PIN HOLE LEAK. It is made of a very hard plastic and the leak is so small that I can easily stop it with finger pressure. Are there any new magic products that will stop it? I can probably replace the housing but thought I'd try to fix it first.
post #2 of 7 Old Jul 28th, 2007, 9:22 am
Woolly's Avatar
Have you tried using a hot soldering iron to melt the hole closed?
  • MB SLK 350 MT
  • 1974 Triumph Bonneville 750
Woolly is offline
post #3 of 7 Old Jul 28th, 2007, 9:26 am
jhsonderb's Avatar
I have successfully fixed leaks in water pipes using epoxy plumber paste. It is found in the plumbing section of "Home Depot" (or similar) stores. It is moldable and cures to a consistency that you can file it to dress it up if necessary. Following is a quick link to show you what I'm talking about. The link is just an example, not a testimonial for this particular brand, although I think this is the stuff i used.
http://www.wmharvey.com/prod/cat4/pep/epoxy.php
Jim S.
'07 SturmGrau K1200LT
jhsonderb is offline
post #4 of 7 Old Jul 28th, 2007, 12:24 pm
myk_edwards's Avatar
What about putting a self tapping screw into it, with some nutlock or silicon on it.
Plumbers paste is a good idea too.
Rgds
"For those that know, no explanation is needed,
For those that don't, no explanation is possible."
2001 K12 LT Toscana Green AKA Baby Sh*t Green
Kawasaki EN500 - been sold on!
Hardtail Chopper ( Honda CB 500 engine) in a box still!
myk_edwards is offline
post #5 of 7 Old Jul 28th, 2007, 12:28 pm Thread Starter
tanks
I thought about the hot soldering iron and checked with local Pinch a Penny dealer who said best solution is to use a plastic 2 part epoxy from Ace. I'll give epoxy a try if the hot iron doesn't work. Its in an area where it would be hard to drill and tap with a screw.
post #6 of 7 Old Jul 29th, 2007, 6:34 am Thread Starter
Ace Quick Set epoxy
Yesterday I used the Ace product and so far it seems to be working. The leak has stopped with the pump under pressure. Unfortunately my guess is that there will be other leaks in the general area of the pump so best start thinking of replacing the area in question. Next leak will be when I'm out of town and I'll come home to an empty pool.
post #7 of 7 Old Jul 29th, 2007, 7:30 am
Marine-tex expoxy,found in the Boat/sporting goods at Wal-Mart. It will stop leaks in boats while still in the water.
kyrider is offline
A question and an introduction royal K1200LT 18 Sep 19th, 2006 9:09 pm
Removed top box, new bike now. Question? xrmattaz K1200LT 18 Jul 27th, 2006 7:16 pm
Coolant leak question gholt417 Bike Talk 1 Jun 30th, 2006 4:58 am
New bike, and a simple question - I hope sprangw K1200LT 8 Feb 14th, 2006 10:36 am
