Heavy Bike - BMW Luxury Touring Community
post #1 of 11 Old Jun 8th, 2006, 7:44 am Thread Starter
garry_kramer's Avatar
Question Heavy Bike
Was visiting a friend yesterday, His Harley has been in the shop since winter, cracked crankcase. I couldn't believe him when he said his bike weighed 1200#'s I thought the LT was heavy. Can this be true. It is a 2 wheeler, don't know the model, because I haven't seen it and it's been in the shop.
IBAID 26718
BMWMOA 117552
2012 RED KLR650
garry_kramer is offline
post #2 of 11 Old Jun 8th, 2006, 8:29 am
HD weight
Heaviest bike HD builds is the FLHTCUI Ultra Classic.factory listed dry weight is 788 lbs.Sorry Dave.ther's no way your 67 weighed 1250.New Gold Wing is 798.
CaptRich is offline
post #3 of 11 Old Jun 8th, 2006, 9:34 am
No, unless he put over 400 pounds of accessories on it!
post #4 of 11 Old Jun 8th, 2006, 10:49 am
zippy_gg's Avatar
Could it be...?
His biker chick???
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #5 of 11 Old Jun 8th, 2006, 12:56 pm
Your friend has more than a cracked crankcase... could be he's smoking crack... Just kidding. The Ultra Classic (HD's biggest) is in the same weight class as the LT and Wing.
buddoggin is offline
post #6 of 11 Old Jun 8th, 2006, 8:37 pm
Ultra classic real heavyweight !
Just returned from Americade where I spent some time with a couple of guys with identical ultra classics.
THey both claimed that their bikes weighed around 1100 lbs. I thought that the LT was a little shy of the goldwing and that they were the heaviest.
If I thought the LT was heavy he suggested I try to heave the HD off the side stand.
Even though I didn't weigh it, I can attest that it is VERY HEAVY, Sure felt like every bit of 1100 lbs. and much heavier than the LT. Maybe because it has that girth centred so low and the side stand really lets it lean way over so you're starting with it really tipped.
Definately too much bike for me!
starky is offline
post #7 of 11 Old Jun 8th, 2006, 10:11 pm
2006 Ultra Classic
DIMENSIONS U.S. UNITS
Length 98.3 in.
Seat Height
Laden 27.3 in.
Unladen 30.7 in.
Ground Clearance 5.1 in.
Rake Steering Head/Trail 26.0º / 6.2 in.
Wheelbase 63.5 in.
Fuel Capacity 5.0 gals.
Oil Capacity 4.0 qts.
Weight
Dry Weight 788.0 lbs.
Running Order 819.0 lbs.
POWERTRAIN
Engine Twin Cam 88®
Displacement 88.0 in.³
Bore x Stroke 3.75 in. x 4.00 in.
Engine Torque 86.0 ft. lbs. @ 3500 rpm
Fuel System Electronic Sequential Port Fuel Injection (ESPFI)
Compression Ratio 8.9:1
Miles per Gallon
Carb. N/A
ESPFI 46 hwy / 39 city
Primary Drive Chain
Gear Ratio (overall)
1st 10.110
2nd 6.958
3rd 4.953
4th 3.862
5th 3.150
6th N/A
WHEELS/TIRES
Wheels
Front Black 9-spoke cast aluminum
Rear Black 9-spoke cast aluminum
Tire Size
Front MT90B16 72H
Rear MU85B16 77H
ELECTRICAL
Instruments Electronic speedometer; odometer; resettable tripmeter; tachometer; fuel gauge; oil pressure; volt meter; air temp
Indicator Lamps High beam; neutral; low oil pressure; engine diagnostics; accessory; speakers; turn signals; low fuel warnings; cruise control; security system (optional)
CHASSIS
Brakes
Front Dual
Rear Single
Lean Angle (per SAEJ1168) 30º / 31º
Exhaust System Chrome, cross-over duals
post #8 of 11 Old Jun 9th, 2006, 9:45 am
retiredjj's Avatar
you want heavy? try a boss hoss with the automotive v8.
retiredjj is offline
post #9 of 11 Old Jun 9th, 2006, 11:31 am
Originally Posted by starky
-----------If I thought the LT was heavy he suggested I try to heave the HD off the side stand.
It IS because of the larger lean angle on the sidestand. My son-in-law's Soft Tail Heritage was harder to lift off the sidestand than my LT was, and it was a considerably lighter bike.
People have often wished for the Harley sidestand on the LT, and my comeback is always that if they had to lean it over as far as the Harley leans they would have a hard time getting it back upright.
On the Soft Tail I had to lean it a little to the right to get the sidestand to swing out, to clear the locking tang, then lean it WAY to the left to get it on the stand. I would NOT want that same stand on an LT!
post #10 of 11 Old Jun 11th, 2006, 9:38 am
dglenn1's Avatar
Confusion?
Sure he's not confusing weight with engine displacement? These weight numbers sound awful close to common displacement numbers.
Dan
2005 K1200LT - Ocean Blue
; Nolan 103 Helmet w/Bluetooth;
and
(Secures gear/luggage);
; Droid X (Replaces
and factory radio);
(Not installed);
(Currently unistalled),
; Clymer Manual; BMW Service DVD
dglenn1 is offline
post #11 of 11 Old Jun 11th, 2006, 11:28 am
airborneod's Avatar
I have owned many HDs, 2 of them Ultras and none of them felt as heavy (to me) moving them off the side stands the LT does, Maybe because I was younger!!!
Airborne "Never Forget"
Vonore, TN
2003 LT-E "HLZ BNZ"
2004 Rune "PNS EXTN"
1970 ZA-50 "JR"
airborneod is offline
Lemon law bike for sale. Would you buy? edonthenet K1200LT 45 Aug 3rd, 2006 10:07 pm
1986 miles, the rockies, and one helluva motorcycle eljeffe K1200/1300GT (The Next Generation) 17 Jun 12th, 2006 8:19 pm
OK...So now I get it! Vance K1200LT 8 Mar 14th, 2006 3:51 pm
The story of buying my LT (Really REALLY long...) bmwjason Ride Tales 0 Jan 6th, 2006 11:09 pm
