Got a neat new tool for BMW maintenance--WORX SD - BMW Luxury Touring Community
post #1 of 25 Old Mar 5th, 2013, 8:56 am Thread Starter
petevandyke's Avatar
This is gonna' make tupperware removal and minor adjustments a LOT easier (and dare I say it, more fun). Instead of five different screwdrivers/hex wrenches/torx heads, just one that you "rack the slide" to switch bits.
WORX SD homepage--check out the video
and no, I'm not affiliated with Worx, but I did stay at a Holiday Inn Express last night...
petevandyke is offline
post #2 of 25 Old Mar 5th, 2013, 12:00 pm
bikerj's Avatar
Re: Got a neat new tool for BMW maintenance--WORX SD
Pete, Have you got one yet? Looks like it doesn't cost an arm or a leg either.
"Front-mounted LED light means no more working in the dark" Yeah, I do all my maintenance in the dark. Might be good to take on those long bike rides.
Jeff
Big D is my neck of the woods
08 HD wide glide
prior:
07 HD XL1200C (sold!
78 KZ750 twin
76 CB750F
71 CL175 Scrambler
73? Yamaha 100 enduro
bikerj is offline
post #3 of 25 Old Mar 5th, 2013, 12:57 pm Thread Starter
Yup. Came fully-charged. smaller than a cordless drill (which is a good thing), and it turns at the speed of a cordless screwdriver (not a drill)
I ran around the house fixing the little things I've neglected for a while, had fun with it.
Only thing is doesn't have is a torque break, so you can set it to stop at a certain point, but it's plenty controllable and I don't see it ripping through sheetmetal or anything.
post #4 of 25 Old Mar 5th, 2013, 1:11 pm
12R12RT's Avatar
I bought a similar dingus from Sears, but it came with no bits and I don't think the battery is as good.
The bits look to be standard 1/4" short bits, so you can customize a cartridge for your needs.
27 in-lbs is dang near perfect for Tupperware removal and installation.
The six round magazine makes it acceptable for use in New York, too, being just under the 7 round limit....
Tom
12R12RT
08KLR685 - RIP
09KLR650
12R12RT is offline
post #5 of 25 Old Mar 5th, 2013, 1:48 pm Thread Starter
Laughing...until Obama takes away our screwdriver bit magazines!
Yup, it holds standard bits, so the ones I've picked up over the years are good to go.
I think I missed my calling, should have gone into sales
post #6 of 25 Old Mar 6th, 2013, 10:10 pm
lkchris's Avatar
You wouldn't get that tool inside the front of the fairing of an R1200RT to remove the four screws on the side ... especially the rear ones.
I wouldn't get anywhere near my bike with one of these, as it's damage just waiting to happen.
Kent Christensen
Albuquerque
lkchris is offline
post #7 of 25 Old Mar 6th, 2013, 11:12 pm
Looks like a must have for a handyman.
Which I believe I am . . . NOT
OK around the house anyway cutting grass and taking out the trash
ride safe
billsmith is offline
post #8 of 25 Old Mar 7th, 2013, 2:50 am
Enjoy The Ride
saddleman's Avatar
Only hand tools are used on my bikes.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #9 of 25 Old Mar 7th, 2013, 3:14 am
bikerj's Avatar
I guess I just know when to let go of the trigger.
Jeff
08 HD wide glide
prior:
78 KZ750 twin
76 CB750F
71 CL175 Scrambler
bikerj is offline
post #10 of 25 Old Mar 7th, 2013, 9:08 am
SilverBuffalo's Avatar
yup same here, that tool might be useful to remove screws
but when it comes to replacing them I need to "feel" that they go in properly
and especially with tupperware screws that they don't tear or rip the rubber grommet,
which is real easy to do.
Also while we're on the subject of tools,
whenever I do maintenance or anything besides major repair,
I always use the tools that are in my saddlebags,
if I need to get additional tools from my garage,
that means I need to add it to my "on board" tool kit.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #11 of 25 Old Mar 8th, 2013, 5:14 pm
Guest
11862's Avatar
I cut off an old screwdriver, drilled a 1/8 inch dia hole in the end, and drove in a 3 mm hex bit. That way I can feel my way into starting those tupperware screws without over tightening them and can guide the screws properly. I don't want power for starting or tightening either. The threaded holes in the gas tank are especially crucial to get right.
11862 is offline
post #12 of 25 Old Mar 8th, 2013, 6:23 pm
Do you have a picture of what that tool looks like.
I understand cutting the old screwdriver but to what length or clean off. Are you using it basically as a handle or affixing the 3mm at some distance into the steel. Please clarify. If you don't mind sharing.
ride safe
post #13 of 25 Old Mar 9th, 2013, 10:05 am
Guest
11862's Avatar
Don't have the picture anymore & bike is stashed 100 miles away.
It was a large screwdriver with the end cut off so that all that was left was the handle and ~ 6 inches of rod. The rod was drilled 1/8 dia by ~1 inch deep in the end using a drill press. This was just the right diameter to allow a length of 3 mm hex key stock (from hex key obviously) to be driven in w a hammer. I think I had to grind the corners off the hex key a little bit to get it started.
11862 is offline
post #14 of 25 Old Mar 9th, 2013, 12:32 pm
bikerj's Avatar
I don't know Niel, but it sounds like from your description there's already similar tools on the market w/o going to the trouble of fabricating one.
Or were you trying to keep idle hands from being the devil's workshop?
Jeff
08 HD wide glide
prior:
78 KZ750 twin
76 CB750F
71 CL175 Scrambler
bikerj is offline
post #15 of 25 Old Mar 9th, 2013, 1:28 pm
Guest
11862's Avatar
With our shops - (which we of course all must justify) I can make one about as fast as ordering - and then I don't have to wait! Besides I didn't want to throw the screwdriver away even though the #3 phillips head was totally shot.
11862 is offline
post #16 of 25 Old Mar 9th, 2013, 3:18 pm
12R12RT's Avatar
True. 27 inch-pounds of torque is horrendous. I almost flipped my bike over once...
Tom
12R12RT
08KLR685 - RIP
09KLR650
12R12RT is offline
post #17 of 25 Old Mar 9th, 2013, 6:49 pm
I can visualize now.
Got the picture. Thanks for the follow-up, well explained.
ride safe
post #18 of 25 Old Mar 11th, 2013, 11:05 am Thread Starter
You guys are a riot.
You really shouldn't be using a standard screwdriver, you should be using a torque wrench so you are POSITIVE that you don't over-tighten your fairing screws. Otherwise, you might ham-hand one screw and under-tighten another, and we don't want that!
Me? I don't have Popeye forearms, so something that makes removing all those screws take less than half the time is something I'm interested in.
Just sharing something I thought was neat, certainly NOT insisting that everyone use them, particularly on those trick RT fasteners...
post #19 of 25 Old Mar 11th, 2013, 11:15 am
12R12RT's Avatar
Yeah, just the thought of those special fasteners makes me break out in a cold sweat.
Tom
12R12RT
08KLR685 - RIP
09KLR650
12R12RT is offline
post #20 of 25 Old Mar 12th, 2013, 7:37 am
RiderRay's Avatar
I'm with you Peter. Seems like people are getting cabin fever and have to find something wrong with everything.
Thanks for the post, tool looks interesting. I had a high school shop teacher many, many years ago that often said "Don't blame the tools, blame the mechanic."!
Ray Rau
Brewster, NY
'99 LT - Champagne
RiderRay is offline
post #21 of 25 Old Mar 12th, 2013, 9:44 am
Pete thanks for sharing what appears to be a useful tool for all kinds of around the house applications,
I meant nothing derogitory towards you because of my personal preference for using only hand tools,
I've been involved in some kind of mechanical work my entire career,
Saddleman wrenches on high performance race cars for a living,
guys like him and me know and love tools, I've never seen a tool I didn't like (or want)
but just like you don't use pliers or visegrips to remove a bolt
I'm a strong believer in using the "proper" tool for the application
I helped a guy remove the tupperware from his LT once he
had torn everyone of the rubber bushings with a cordless screwdriver
(he is a computer guy) and wondered why he had so many rattles
I've fixed many issues that were created with the use of an improper tool,
so yeah I agree blame the mechanic and his "choice" of tools.
so if you can't fix it with a hammer,
it must be an electrical problem.
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #22 of 25 Old Mar 13th, 2013, 7:26 am
mwnahas's Avatar
a little too much torque.
http://www.youtube.com/watch?v=APH9-TW9cM0
Just Go
Cleveland Ohio
mwnahas is offline
post #23 of 25 Old Mar 13th, 2013, 7:46 am
OttawaJim's Avatar
You might want to mention that to the guys at Max BMW
http://www.youtube.com/watch?v=2UHU4ZQ2C_Q
OttawaJim is offline
post #24 of 25 Old Mar 13th, 2013, 11:12 am
12R12RT's Avatar
I want one of those "Save the TaTas" screwdrivers!
It looks like it has a lot more torque than my driver, though, so it would definitely flip my bike over.
Tom
12R12RT
08KLR685 - RIP
09KLR650
12R12RT is offline
post #25 of 25 Old Mar 13th, 2013, 11:44 am
You might want to pay attention to the special cautionary warning he gives at 9 minutes!
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
Tool usage 101.... bigbear Humor 5 Mar 7th, 2010 5:53 pm
Yearly RT Maintenance Cost Xavier6162 RT Series 12 Nov 18th, 2007 8:44 pm
Tool definitions simoncharles Humor 2 Jun 4th, 2006 7:49 am
