over heating K1200 LT - BMW Luxury Touring Community
post #1 of 16 Old Jun 15th, 2010, 1:45 pm Thread Starter
baurcorp's Avatar
HELP!!! My K 1200 has 80K on it and the other day coming home from a short trip (110 miles) the guage started moving to the red whenever I set still in traffic for any length of time. It got to the red mark for a brief second before the fans turned on and slowly started to cool down. I thought i was going to have to turnit off and sit on the side of the road but it coole denough to keep going. My quetion is "could this be the sensor for the gfans not working or is something more sinister going on?" When I got home I used a little water mist into the radiator and my bike cooled down fast, the guage went under my normal riding temp so I don't think it's the water pump. Any help is greatly appreciated.
HEY....IT'S THE WAY OF MY PEOPLE....
1973 Yamaha 750 (R.I.P.)
1980 Yamaha 550 SECA (R.I.P.)
1999 Kawasaki ZRX 1100 (R.I.P.)
1984 HONDA 200 ATX
1999 Kawasaki ZX 9 R
2003 BMW K1200 LT
baurcorp is offline
post #2 of 16 Old Jun 15th, 2010, 2:03 pm
Re: over heating K1200 LT
Warm day...
But my '05 handled ok.. When did you last do coolant change?
J.M.J...
Dcn Channing
post #3 of 16 Old Jun 15th, 2010, 2:10 pm Thread Starter
baurcorp's Avatar
Last fall, I changed the radiator cap when I flushed the system. 50/50 mix
1984 HONDA 200 ATX
2003 BMW K1200 LT
baurcorp is offline
post #4 of 16 Old Jun 15th, 2010, 2:45 pm
Did bike really feel hot?
I wonder if you have a "failing" sensor...? If you have access to an infrared temp sensor, that would be a quick check..
http://www.harborfreight.com/infrare...ter-93984.html
J.M.J...
Dcn Channing
post #5 of 16 Old Jun 15th, 2010, 2:51 pm Thread Starter
baurcorp's Avatar
can you please explain the last post in simple terms? I don't follow what to measure to determine the failure of the heat sensor relay to the fan.
1984 HONDA 200 ATX
2003 BMW K1200 LT
baurcorp is offline
post #6 of 16 Old Jun 15th, 2010, 10:54 pm
ErnieA's Avatar
Assuming that both fans were working when it was heating up...
Radiator cap... If it will not hold the 14 to 16 psi (pounds per square inch) the coolant will reach the boiling point at lower temperatures. In other words: the coolant under pressure has a higher boiling point. Lookie here for an simple explanation. If the coolant has not been changed in the last two years you should do it now with a new cap. Then enjoy the riding season without worry...
Ernie A
Milwaukie, OR
2013 R1200GSW
> 28k miles!
ErnieA is offline
post #7 of 16 Old Jun 16th, 2010, 7:56 am
Sent a PM...
If you need an extra set of eyes on the problem ring me up.
J.M.J...
Dcn Channing
post #8 of 16 Old Jun 17th, 2010, 1:35 pm Thread Starter
baurcorp's Avatar
Originally Posted by cfell
Sent a PM...
Thanks I will give you a call this weekend if possible.
1984 HONDA 200 ATX
2003 BMW K1200 LT
baurcorp is offline
post #9 of 16 Old Jun 17th, 2010, 1:36 pm Thread Starter
baurcorp's Avatar
the fans came on only after the temp guage went in the red.
1984 HONDA 200 ATX
2003 BMW K1200 LT
baurcorp is offline
post #10 of 16 Old Jun 17th, 2010, 5:13 pm
DaFlake's Avatar
I'm currently on my second LT. It's a 2002. The first was a 2000. Both of the LTs would turn the cooling fans on just when the temp needle touches the red zone. Then the needle would go down to the 3/4 range where fans would stop and bikes will heat up again. That's the cycle for both the bikes and neither one showed symptoms of overheating. This would happen on heavy stop and go specially on a warm day. Also happened twice when I was stuck following a slooooooooow long line of trucks or cars travelling upwards westbound on Hwy 108.
Big drop in stress when I got used to this nature of the beast.
JMTCW
DaFlake is offline
post #11 of 16 Old Jun 18th, 2010, 9:04 am
ibbones's Avatar
JMTCW
Almost the same here. Only one LT. It's a 2002 and it is plenty warm in South Texas. My temp guage will just start to kiss the red mark when the fans kick in and the temp drops down to 3/4 but once I start moving out of traffic, they will drop back to the 1/2 mark.
"BONES" <///><
2018 R1200RT
2002 K1200LTC--- Belle
ibbones is offline
post #12 of 16 Old Jun 18th, 2010, 12:48 pm
FWIW:
Here are the specifications for the cooling system.
Thermostat opens @ 85 (185)
Fans Kick in @ 105 (221) (usually very near red on the gage)
High temp light on @ 115 (239)
C (F)
post #13 of 16 Old Jun 18th, 2010, 2:25 pm
Went to lunch in Austin.
Fans kicked on while waiting at second of Austin's looooooong traffic lights.. bar kept climbing... but.. stabilized.. yes, fans kicked... and held temp eventually.
Once moving, things improved.
J.M.J...
Dcn Channing
post #14 of 16 Old Jun 26th, 2010, 5:01 pm Thread Starter
baurcorp's Avatar
yeah, I was in my driveway trying out the fans, they never kicked on and it went to red. I cooled it off with a little water mist and it immediately went down past the middle mark. I believe the fan relay is bad. I bought one and now don't know where the relay box is located. I am pulling off skins as I post but don't really know which ones to pull of. do I have to strip off all the skins? I hate to be at this all afternoon to replace a $15.00 part.
1984 HONDA 200 ATX
2003 BMW K1200 LT
baurcorp is offline
post #15 of 16 Old Aug 3rd, 2010, 9:05 am
rab1967's Avatar
Did you ever find where the relay goes?
Bob Brendel
05 LT, Light Metallic Yellow
99 LT, Totaled 3/09
97 HD Former Work Bike
88 GL1500
84 GL1200
S3 400 Kaw, too long ago to remember the year
175 Yamaha even longer
People sleep peaceably in their beds at night
Only because rough men stand ready to do violence on their behalf
George Orwell
rab1967 is offline
post #16 of 16 Old Aug 3rd, 2010, 9:21 am
JPSpen's Avatar
Ha ! Talk about a thousand dollars labor and a fifteen dollar part...
The relay box is under the fuel tank which must be removed in order to change out the relay..
sorry...
All the tupperware (both sides ) has to come off. then the stingray.. Then the seat and mounting bracket then the fuel tank.. the Relay box is on right side..
Have fun.. It should take about two hours to get to it... For a novice.. About an hour if you're experienced with removing all the stuff to get to it...If you have plastic quick disconnects for the fuel tank. Change them out too before they leave you stranded or worse on fire...
Have fun..
P.S I'd stick my finger in the outlet and see if I could turn the fans by hand at some point.
They will eventually sieze up if never used ....
P.S.S. Might want to change out the brake light relay while you're in there. Maybe air filter, fuel filter, Cause you're gonna be right there......
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
Nolan N103 w/ Bluetooth - k1200 Cord Adapter Tom_Becker Ergonomics & Rider Comfort 2 Sep 26th, 2010 9:55 pm
basement heating tmgs Chit Chat 18 Nov 2nd, 2006 5:17 pm
Looking to buy a Used K1200 LT darryldaggs K1200LT 11 Oct 24th, 2006 7:44 pm
K1200 LT Sound System Challenges daturley K1200LT 6 Jul 3rd, 2006 9:53 am
