Amazing S1000 RR valvetrain video - BMW Luxury Touring Community
post #1 of 7 Old Feb 20th, 2010, 7:53 pm Thread Starter
RealWing's Avatar
http://www.autoblog.com/2010/02/19/v...wes/#continued
2015 K1600GTL
1970 Plymouth Superbird 440-6bbl
1969 Plymouth Barracuda Fastback 340-auto
1969 Plymouth Barracuda Convertible, 6.1 L SRT8 Hemi transplant
RealWing is offline
post #2 of 7 Old Feb 20th, 2010, 9:28 pm
wa1200lt's Avatar
Re: Amazing S1000 RR valvetrain video
Great video! You know the cam lobes have to beat the crap out of the valves but watching it happen really brings it home. Sure was glad when they finally backed down the throttle!
WAK1200LT
Loren
wa1200lt is offline
post #3 of 7 Old Feb 20th, 2010, 10:11 pm
I can see that a metal cap at the end of the valve spring appears to be turning. Does that mean that the valve stem, and hence the valve, is also turning?
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #4 of 7 Old Feb 20th, 2010, 11:27 pm
motorhead's Avatar
Thus we witness first hand the reason why Ducati developed the desmonic valve train
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #5 of 7 Old Feb 20th, 2010, 11:49 pm
Much better if can show the rpm at the same time.
Thank you for your sharing
fh8932 is offline
post #6 of 7 Old Feb 21st, 2010, 6:30 am
- Bob
Yes. On most engines the valves are meant to turn slowly to keep wear even. On engines like our current LT, the followers turn (but not necessarily the valves). If you look at the tops of the followers when you do a valve check you will see that the wear is even all around the top of the follower, not in-line with the cam lobe. On many engines the cam surfaces are ground at a very slight angle to cause this by more pressure on one side of the lobe than the other.
post #7 of 7 Old Feb 21st, 2010, 8:37 am
Enjoy The Ride
saddleman's Avatar
It would be nice to see it done with high speed video & then slowed down to see what the springs look like at high RPM. We can slow our video down of our valve springs at work so that one revolution at 10,000 rpm takes several seconds to see. It's amazing to see the spring deform side to side & leave the spring seat each revolution then settle back to it's original shape before it starts the cycle all over again.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
Wisc Sightseeing Advice jsciullo Mid West 14 Jun 16th, 2010 11:01 pm
Alaska 2009 JoeSlump Northern California 6 Nov 22nd, 2008 12:05 am
Looking for an R12RT owner in Northern NJ (Passaic/Morris?) rdwalker RT Series 2 Nov 8th, 2008 10:26 pm
