Radio problem - BMW Luxury Touring Community
post #1 of 4 Old Sep 10th, 2009, 10:23 pm Thread Starter
Radio problem
Greetings! I recently had my 1200LT in for it's 24,000 mile service. When I got the bike back, the radio was not operating properly. When I hit the "seek" button, the radio would rapidly advance through the various stations on a "continuous" basis like it was not getting any signal from the antenna. However the "seek" button worked perfectly for changing the tracks on the CD. I was thinking that maybe the technician somehow pulled out the antenna input into the radio. Any ideas? Thanks.
erichotdoc is offline
post #2 of 4 Old Sep 11th, 2009, 12:19 am
shoswell's Avatar
Re: Radio problem
Can you tune in a station manually? static? if so the easy check is at the antenna it's self, four screws on the bottom to take out the "pig tail" and if you can see a small spring inside, your good on that end. its possible when the tech removed the stingray, he did not seat the antenna fully or missed it all together.
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #3 of 4 Old Sep 11th, 2009, 7:34 pm Thread Starter
Re: Radio problem
Thanks for the reply. Today, for whatever the reason, the radio started working properly. Before this happened, I called the dealer and he mention something about a "spring" like you mentioned. Since I really didn't do any trouble shooting to get it back to life, I have to think it will happen again. The dealer mentioned something about problems with the 2005 model which mine is. Your thoughts? Thanks.
post #4 of 4 Old Sep 11th, 2009, 11:21 pm
shoswell's Avatar
Re: Radio problem
The FM radios are a sour spot for most on the LT, reception is spotty at best. I am not aware of anything specific to any certain year. maybe there is and someone will chime in. The strange part is the dealer mentioning the spring. IIRC, there is nothing under the top case or at the rear of the bike that would involve removing the antenna for a regular service/maintenance? Only thing I can think of, is that they removed the mast while it was in the shop to make it easier to get around it. If that were the case, when they went to re-assemble the mast, the spring may not have seated correctly. Just be happy that its good to go, I think I'd still take it back (if in the area) just to have them check their work...
Stranger still, looking at the Microfiche I do not see a spring in the base of the antenna
Hoss
shoswell is offline
Radio just quit atps1234 K1200LT 62 May 29th, 2017 10:43 pm
Radio Repair Update - When is the next LT ready? Vince_nj1 K1200LT 28 Oct 2nd, 2010 2:46 pm
Weird electrical problem with Radio hd2bmw K1200LT 6 Jul 7th, 2010 7:10 pm
radio problem on 1200LTE couleekid Chit Chat 0 Jul 3rd, 2008 11:40 pm
Radio flickering KMC1 K1200LT 3 Jun 7th, 2006 10:50 pm
