Debating on what to do... I need a M/C lift - BMW Luxury Touring Community
post #1 of 21 Old Jul 17th, 2009, 9:48 am Thread Starter
I am getting a little too old to be crawling around on my garage floor working on the LT. I have been looking at table lifts for a while now and I can't decide on what I want to do. I'm stuck in between buying one in the $4000- $500 range or building my own. I found this web sit
www.afabonline.com/cycle.htm that sells the plans to build a table lift. It looks to be very well built and I could modify it to meet my needs. If anyone has ever built there own lift I would greatly appreciate any advise they can offer.
2001 K1200LTC
1988 Honda CBR1000F Hurricane
1986 Honda 750 Night Hawk
1980 Honda CB750F
scott122262 is offline
post #2 of 21 Old Jul 17th, 2009, 10:18 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Debating on what to do... I need a M/C lift
The type of lift listed in the web link WILL NOT work on a LT as there IS NO frame on the LT on the bottom. For $400 to $500 you can get a table lift to raise the bike up
Stevie Shreeve
katnapinn is offline
post #3 of 21 Old Jul 17th, 2009, 10:33 am
Look under "Table Lift". That is the one that will work.
post #4 of 21 Old Jul 17th, 2009, 10:34 am Thread Starter
You must have looked at the cycle lift plans. I was referring to the table lift plans for $30.00.
2001 K1200LTC
1980 Honda CB750F
post #5 of 21 Old Jul 17th, 2009, 10:37 am
Florian's Avatar
spend the dough and get a handy lift.
F
BMWMOA
12 GTL
Florian is offline
post #6 of 21 Old Jul 17th, 2009, 10:37 am
katnapinn's Avatar
Opps Sorry I missed that one. But I still think you could buy one for what you want to spend.
Stevie Shreeve
post #7 of 21 Old Jul 17th, 2009, 10:44 am
Unless you're going to be using the lift all the time, you can get by with one of the Harbor Freight lifts. Make certain you get the one with the front wheel chock. Mine has both air and manual pump lift operation. You will need to make up some sort of side extensions to help you get the bike on the lift (unless you have legs like a giraffe) and make sure the lift is absolutely level before you raise the bike up on it.
Beautify America - Get a Tattoo!
2002 K1200LT (going, going, GONE)
Tat_n_Telle is offline
post #8 of 21 Old Jul 17th, 2009, 11:25 am
dsauer608's Avatar
Once you own a lift, you find you DO use it all the time... ours is a Direct Lift Pro Cycle XLT, with the side sections to make it wide enough for a four wheeler - a great place to set your tools, beer, etc! The only thing I don't like about ours is that it's black, so all those tupperware screws can hide from you when you drop them. We've had it for several years now and it works like new and is so sturdy you can climb up on it with an LT up there, no problem.
Dean and Deb
Golden, CO
dsauer608 is offline
post #9 of 21 Old Jul 17th, 2009, 11:27 am
Wood614's Avatar
Check out this site. http://www.bestbuyautoequipment.com/...ifts_s/292.htm
I was able to buy the AL-1000M online and pick it up at a local warehouse. The lift is great, much better than the Harbor Freight lift and will hold the LT with no problems.
I really love having a lift, my old bones appreciate it even more than my head.
Jim Woodring
Monroe (Fly Speck), Tennessee
2001 K1200LT Canyon Red
1988 K100LT Tobacco Brown
1976 R60/6 Red
1975 Norton Commando Black with oil spots
Wood614 is offline
post #10 of 21 Old Jul 17th, 2009, 11:31 am
deanwoolsey's Avatar
I have a Harbor Freight lift. I modified mine slightly by adding wing nuts (non-Detroit type) to secure the removable rear plate and a piece of black pipe through the rear frame for added strength. I built two fold-up ramps and a small extension for the O.E. ramp and now I can easily load and unload the cycle myself. I doubt that in private use someone could ever wear it out. It all fits underneath my 2WD Dakota pickup truck when it's not being used except for the front end of the lift where the wheel clamp is located. That end goes against the garage wall.
deanwoolsey is offline
post #11 of 21 Old Jul 17th, 2009, 1:52 pm
Patric's Avatar
I got a Handy S.A.M. 1000 http://www.mile-x.com/handy-16000-motorcycle-lift.aspx From mile http://www.mile-x.com/ this spring . I have my LT on it right now , to work on a slipping clutch . I borrowed a Handy lift from a friend last to put a rear main seal in my GS . I decided then and there , I need to get me one of these things . Mile -X shipped it to me cheaper that it would have cost to drive down there and pick it up .
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is online now
post #12 of 21 Old Jul 17th, 2009, 2:54 pm
Senior Member (ret.)
RaffyK's Avatar
If you don't mind taking a drive, here's one:
http://www.advrider.com/forums/showthread.php?t=485753
Raffy
RaffyK is offline
post #13 of 21 Old Jul 17th, 2009, 3:04 pm
JPSpen's Avatar
I have the Harbor Freight manual lift and it works just fine.
I put a chock on the front. I put two cinder blocks on each side and that allows me to ride the bike right up into the chock. The chock holds the bike securely on the lift so I can get off and put the tie downs on it.
But if you've got 4 or 5 grand to spend you can get a really nice lift.
I think the HF lift costs about 300 bucks.
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #14 of 21 Old Jul 17th, 2009, 4:30 pm
wa1200lt's Avatar
I was able to get the Harbor Freight lift for 20% off a price that was mistakenly reduce by $90. It is the pneumatic 1200 lb lift and it hoists the old gal right into the air no problem. The earlier comment about needing wings on the side of the table to safely ride the bike onto the table is valid.The HF wing kit is $200! There was a post earlier this week where a guy had a beeeyootiful shiny new hex head bike sitting on a lift table. For wings he took a pair of pickup loading ramps and built 4x4 risers to bring the level of the ramp up to the level of the table where he tied them to u bolts fastened to the tables surface. I will implement this tonight as I already have the identical 2x10x8' loading ramps.
I probably shouldn't post this picture as I didn't take it but the motorcycle, while not an LT is still gorgeous and the side ramps will improve the safety of the lift tables immensely.
Name:	sideramps mc lift.jpg
WAK1200LT
Loren
wa1200lt is offline
post #15 of 21 Old Jul 17th, 2009, 7:20 pm
rodgtc's Avatar
I have the Harbor Freight 1200 lb air lift and use the drive on car ramps I use for changing oil in the cars to extend my leg reach. The ramps and lift work great.
Rodger
Life is not measured by the number of breaths we take, but by the moments that take our breath away. Ride Safe
rodgtc is offline
post #16 of 21 Old Jul 17th, 2009, 8:41 pm
Jim
Slow Old Guy
Jim's Avatar
Another vote for the Handy. Bought mine through Raffy's group buy about 4 motorcycles ago. The Tiger is sitting on it right now. That thing is going to get passed down to my grandson. Great lift.
Jim Anderson
Idyllwild, CA
'04 Ural Tourist
'08 Tiger
Jim is offline
post #17 of 21 Old Jul 17th, 2009, 9:40 pm
And another Handy vote. When I wuz looking for a lift, I visited several m/c shops in the San Antonio/Austin area and every one of 'em had Handy Lifts. Some with hydraulic actuation; some with electric; and some with air. I chose the electric and couldn't be happier. That wuz 9 years ago and I'd buy another today if this one went south.
post #18 of 21 Old Jul 20th, 2009, 7:49 am
JCarver's Avatar
Another vote for the Harbor Freight manual lift. To make it much better to ride onto, I added some sides from a 2 x 8. There is angle iron welded to the bottom edge to hold the sides in place. The wood is cut to fit on the lip, so it isn't going anywhere.
John Carver
K1200LTC, AMA, BMWMOA
Greensboro, GA
JCarver is offline
post #19 of 21 Old Jul 20th, 2009, 8:24 am
wsp310's Avatar
I have the HF 1000# foot pump lift and love it. Just make sure you have the bike properly secured before you start to let her down! The release is very touchy and needs only slight "toe" pressure to come down. Here is a good deal right now on a better wheel lock for the lift. Also a coupon for purchase. I got the extended warranty that covers everything, including my stupidity! Also they have 15 and 20 % off coupons everywhere if you look. Brought the price of my lift down to about $250.00. When I'm not using my lift, I stand it on end and strap it against the wall next to the garage door. Up and out of the way.
http://www.harborfreightusa.com/usa/...5&keycode=0000
John Jones
2000 K1200LT Canyon Red
wsp310 is offline
post #20 of 21 Old Jul 20th, 2009, 8:58 am
wa1200lt's Avatar
Scott#####,
PM me, I have some info for you best given outside the public forum.
wa1200lt
WAK1200LT
Loren
wa1200lt is offline
post #21 of 21 Old Jul 20th, 2009, 10:31 am
SilverBuffalo's Avatar
I'm another Harbour Freight lift owner, it works good enough for me.
There are of course better (more expensive) lifts out there but for my budget
and considering how often I use it, I'm satisfied.
I have found a multitude of uses for it that I never thought of before I owned one,
it makes a great "work bench" to work on lawn mowers, washer/dryers, bicycles etc.
and just about anything else that needs to be fixed.
A while ago my wife wanted new washer/dryer, we gave the old ones to her granddaughter.
now ten years ago I would have picked them up and lifted them in and out of my pickup truck,
can't do it anymore, (well I probably could but I'd pay for it the next couple days)
I was able to raise the lift, slide the washer/dryer of the lift and into the truck.
All of that and no back ache, nice!
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
New Lift in the Garage! hschisler Chit Chat 19 Oct 17th, 2008 9:15 pm
Big Blue Bike Lift grahamw K1200LT 1 Jul 7th, 2007 9:01 pm
For THe People Interested In The Harbor Freight Lift Jerrym K1200LT 15 May 14th, 2007 9:17 pm
Harbor Freight Motorcycle Lift Jerrym K1200LT 18 Oct 29th, 2006 5:14 pm
Need help re. Harbor Feirght lift that won't paulcbrowne K1200LT 3 Apr 24th, 2006 12:26 pm
