Gear Oil Change Every Service - BMW Luxury Touring Community
post #1 of 10 Old Jul 5th, 2009, 10:27 am Thread Starter
I looked at the gear oil at the dealer that came out of the final drive of a GS that had 50,000 miles on it and had never been changed. It looked and smelled aweful. The dealer automatically changes the oil in the final drive at every service interval. I wonder if constantly having clean oil put in at every 10K service will cut down on the probability of a final drive failure?
ronk1200lt is offline
post #2 of 10 Old Jul 5th, 2009, 10:54 am
mtrevelino's Avatar
Re: Gear Oil Change Every Service
You can change the final drive fluid every one hundred miles. When it is "your" turn there is nothing to stop it from failing.
Mike Trevelino
Williamsburg, VA
2008 RT - Sold December 2019
mtrevelino is offline
post #3 of 10 Old Jul 5th, 2009, 12:58 pm
Did the GS you're referring to have a final drive failure?? Just curious.
I'm anal on fluid changes for all our vehicles; wasted resources or not. In the case of ole Toad, we've had engine oil, tranny lube and final drive lube changed every 3,000 miles since new. We've had two final drive failures within the 125,000 mile run.
In ole Blue Truck, we changed engine oil every 3,000 miles and the other fluids when recommended. Before it got donated to charity, it ran 280,000 miles needing only three serpentine belts and one water pump. Nuttin' else beyond recommended service items.
Doesn't answer your question specifically, but is just a data point.
post #4 of 10 Old Jul 5th, 2009, 3:22 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
I agree ... As far as I can see there "IS NO" rhyme or reason to a final drive going out. I do oil every 6K also FD & trans every 12K with NO problems. some on this site have reported 150K plus miles with NO major problems. While other have had major issues with less then 50K.
Stevie Shreeve
katnapinn is offline
post #5 of 10 Old Sep 19th, 2013, 4:19 pm
Wow, I see you said every 100 miles?? Is that what you really mean? That would be
Nearly every ride? Please explain.
Rightrudder2 is offline
post #6 of 10 Old Sep 19th, 2013, 4:38 pm
I do believe Mike typed that with tongue in cheek - right Mike??
And he's right about, when its your turn, it's your turn. I changed all fluids every 3 to 4k miles, and still had 3 Final Drives go south.
post #7 of 10 Old Sep 19th, 2013, 7:07 pm
The one thing frequent (6 K) oil changes does for you is it gives you a good indication of the drives current condition. Depending on what you see: a darkening of the oil (aluminum wear = taper bearing spinning) or shiny bits on the magnet (impending big bearing failure).
Most rear drive failures in the 30 - 90 K range were due to over shimming when setting the preload at assembly, while repeat failures are due to not correctly re-shimming the original failed drive during the repair.
post #8 of 10 Old Sep 19th, 2013, 9:28 pm
mtrevelino's Avatar
What I said is correct. The failed bearings were not originally set up correctly from the factory so I feel that no matter how many times you change the FD oil, the bearing is going to fail, period.
Mike Trevelino
Williamsburg, VA
post #9 of 10 Old Sep 19th, 2013, 9:30 pm
mtrevelino's Avatar
Thanks for the backup Dick!
Mike Trevelino
Williamsburg, VA
post #10 of 10 Old Sep 20th, 2013, 6:33 am
gbob's Avatar
I began changing FD lube with engine oil just to keep an eye on bearing condition.
It kept me from having a failure on a road trip , thats all I expected.
Bob G
gbob is offline
First Solo Oil Change - Complete! hschisler K1200LT 40 Mar 13th, 2016 11:28 pm
Do I Really Need A Torque Wrench For An Oil Change. gladiator99 K1200LT 55 Mar 23rd, 2013 1:16 pm
LT oil Change whatchamacallit shuster K1200LT 13 Jun 25th, 2009 6:27 am
03 LT my first oil change + questions paalao K1200LT 13 Jun 26th, 2008 5:01 pm
