Bleeding ABS brakes - BMW Luxury Touring Community
post #1 of 4 Old Jun 20th, 2009, 10:06 am Thread Starter
NCrider's Avatar
Bleeding ABS brakes
We're finishing out a full service on an ABS-equipped 01 F650GS, last item brake bleed. Question on ABS bleed. Members of f650.com are split as to whether this could/ should be done as self-maintenance. The manuals state that the MoDiTec must be used to ensure there is no air left in the system and the valves are actuated allowing all the old fluid to be purged. Some F650.com members state they have done the flush with no poor performance results. Those who have done a bleed seems to use the same simple method of bleeding non-ABS.
Anyone with a good understanding of the system have an opinion in the matter? If it's really best, then we'll let the dealer do this one item.
As always, than you in advance.
Norwood
NCrider is offline
post #2 of 4 Old Jun 20th, 2009, 10:46 am
DavidTaylor's Avatar
Re: Bleeding ABS brakes
I think you would be OK bleeding the brakes yourself, especially if you use something like a Mighty Vac micro bleeder. I flush and bleed the brakes on my ABS equipped 95 GS at regular intervals, even replaced the front master cylinder and refreshed the system with no issues. I did it on my 99 LT as well. As long as it doesn't have the servo assist brake system you'll be fine.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #3 of 4 Old Jun 21st, 2009, 7:29 am
rkirker's Avatar
Not familiar with the ABS-equipped 01 F650GS system, But posted to see if will help out at all.
I have bleed the brakes on the 02 K1200LT 3 (ABS Integral) 3 times and have had no ill effects.
I do not use a Vacuum pump. I bought Speed Bleeders for all of the bleeder valves except the ABS unit itself and just used the servos to flush/replace the fluid in all of the 4 loops.
I have followed the attached instructions every time.
I also leave the battery charger on the battery when I do this as it will kill the battery quickly if you flush all 4 systems one after the other.
If you are careful and do not introduce air into any of the systems you should be golden.
Good luck
Rich Kirker
2002 LTC Pacific Blue
Caliper Moto Lights, Hyper light brake lights, Spiegler brake lines, Ride West side markers, Grip puppies, HyperPro Springs and CA HID Kit.
BMWMOA #124306
2009 Honda Shadow (Wife's)
Blue & Pearl
"Well It’s not rocket science but absolutely a nightmare. At the end of the day you had a fairly unique situation that I personally at this moment in time could see me having as well 24/7. With all due respect, it shouldn’t of happened."
rkirker is offline
post #4 of 4 Old Jun 21st, 2009, 8:49 am Thread Starter
NCrider's Avatar
Thanks- I need to get the mightyvac- I had a passive bleeder helper. Need to possibly get some speed bleeders, too??? I'll google/ search it.
NCrider is offline
R1150RT-P with ABS - always noisy when brakes applied? kingkong5 RT Series 6 May 29th, 2009 9:03 am
ABS Brake Bleeding Tool Mugszy K1200LT 0 Jan 31st, 2009 8:17 am
Bleeding brakes K1200LT Caveno K1200LT 7 May 5th, 2008 2:40 pm
