bug removal - BMW Luxury Touring Community
post #1 of 19 Old May 28th, 2009, 6:57 am Thread Starter
bug removal
What do you guys recommend for bug removal from the tupperware? I have heard that kerosene works but am a little afraid to use it.
budzee is offline
post #2 of 19 Old May 28th, 2009, 7:13 am
Re: bug removal
I've always used Honda Pro spray polish and wax. That stuff is amazing.
I would definitely stay away from kerosene.
Beautify America - Get a Tattoo!
2002 K1200LT (going, going, GONE)
Tat_n_Telle is offline
post #3 of 19 Old May 28th, 2009, 7:14 am
Re: bug removal
Warm soapy water and cotton towel, let the soapy water soak the bugs for a few minutes. When clean keep a 'good' wax base, lets the bugs come off faster.
little_jake
little_jake is offline
post #4 of 19 Old May 28th, 2009, 7:14 am
Palerider's Avatar
Re: bug removal
Try soaking a towel and placing it over the bugs for a while...........they'll loosen up after a bit then you can use a little Dawn Dish Soap and wash mitt..........works for me..................
Palerider is offline
post #5 of 19 Old May 28th, 2009, 7:36 am
Re: bug removal
I use a laundry dryer sheet ... it just seems it blows them off the bike.
Try to minimize the "scrubbing pressure" until the hard bug parts and dirt are flushed away..
Rinse well...
post #6 of 19 Old May 28th, 2009, 9:43 am
Re: bug removal
WD-40 works wonders, but I have no idea whether it also removes the wax. Dave's hydrogen peroxide is a neat idea, but it can fade colors on cloth or leather if not treated and if you aren't careful to rinse thoroughly (and again, I don't know what that does to waxed surfaces). Using dish detergent on motorcycles or cars is a guaranteed way to remove bugs...and protective coatings of surface wax...so if you use any of the above methods, make sure to follow up with a re-application of your favorite polish and then re-wax (I am a big fan of the Turtle Wax ICE products lately, you can put the stuff on plastics, over stickers, on vinyl, on the dash, anything).
+1 on the advice above regarding dryer sheets--use very gentle pressure if you're gonna' use them to avoid scratching, and only use USED dryer sheets--the brand new ones straight out of the box are often stiff enough to scratch or cause swirl marks.
I usually just throw a large towel over the front end, soak it with a hose, let it sit while I do the wheels with a sponge different than the one I use for the rest of the bike, and by the time I get to the front of the bike, they are soft enough to wipe off.
trainingwheelz is offline
post #7 of 19 Old May 28th, 2009, 10:09 am
DavidTaylor's Avatar
Re: bug removal
My shop sells this stuff called Bug Release. I believe it's made by the same folks that do the Wizard's Clean & Shine product. The Bug Release works like a charm - spray it on, wait 60 seconds, and they just wipe off.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #8 of 19 Old May 28th, 2009, 11:05 am
Re: bug removal
The wax is not removed and there is no fading or scratching on any surface I've used it on.
3% HP is weak stuff and only reacts with the bugs. It's 97% water!
In organisms, hydrogen peroxide is naturally produced as a byproduct of oxygen metabolism; virtually all possess enzymes known as peroxidases, which harmlessly and catalytically decompose low concentrations of hydrogen peroxide to water and oxygen.
Heya, Dave
Not doubting you on this, and I chuckled on the math lesson.
Question, though...
If hydrogen peroxide solution is what is used for loosening and removal of ear wax by doctors (see http://www.intelihealth.com/IH/ihtIH.../331/9875.html and others), then why wouldn't it also remove wax from the surface of a motorcycle/car?
post #9 of 19 Old May 28th, 2009, 12:21 pm
MattKas's Avatar
Re: bug removal
Go to the nearest Harley dealer. There is Harley branded Bug Remover spray. I use it and I like it. It works better and faster than Honda Polish Spray. As a matter of fact after I use the Harley Bug remover then I use Honda Polish Spray for last step.
Matt Kas
"Riding Year around"
MattKas is offline
post #10 of 19 Old May 28th, 2009, 3:38 pm
Re: bug removal
Ear wax is made up of squalene, lanosterol, and cholesterol.
Polishing/Clear-coating wax is Carnauba (what I use) or petroleum based, I think thats probably the core difference.
Then again, I could be way off base, but I'm getting great results without any issues.
See? That's my problem. Nothing but sh*t between my ears, (well, that's what the wife says)
post #11 of 19 Old Jun 1st, 2009, 7:05 pm
Re: bug removal
What do you guys recommend for bug removal from the tupperware.
Bugs-B-Gone...available at most auto supply stores.
It even removes cooked on bugs on the engine.
BMWGS is offline
post #12 of 19 Old Jun 2nd, 2009, 8:41 am
BennyBob's Avatar
Re: bug removal
+1 on the Harley Bug Remover. Works quickly only $4.95 at the local dealer. Followed up with spray on Turtlewax. Not sure if the bug remover effects wax, I put on wax after anyway because a good wax coat helps future bugs release. As seldom as I clean the bike, every little bit helps.
Benny C. (Central Texas)
BennyBob is offline
post #13 of 19 Old Jun 3rd, 2009, 5:38 pm
blankshot's Avatar
Re: bug removal
The best thing I have used to date is Meguiares NXT car wash soap and warm water. They come right off no problems. I've tried all the others and they all worked the same so when I tried this I was surprised how well it worked. It even gets off the soft tar that sprays on the car... sorry bike.
Cheers,
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
blankshot is offline
post #14 of 19 Old Jun 3rd, 2009, 11:21 pm
powwow's Avatar
Re: bug removal
Wet a rag and fold it into a pad. Dip the pad into baking soda and wipe the bugs. They will come right off. That's always worked great for me.
Life happens...you control your reaction.
2017 KTM 350 EXC-F (single track monster)
2018 Honda CRF250L Rally (fun on the fire roads)
2015 R1200 RT (holy cow…what a bike)
2007 K1200 LT (sold)
2005 DR 650 (sold)
2002 Harley Ultra (sold)
1999 Harley Road King (sold)
1996 K1100 LT (sold)
1990 Honda Shadow (sold)
1978-1993 Raising Kids; Paying Mortgages
1975 Honda CB550 (sold but wish I still had)
Homemade Motor Bike (mounted a 3.5 HP Briggs & Stratton on my bicycle at age 12)
powwow is offline
post #15 of 19 Old Jun 4th, 2009, 9:26 am
GVPurvis's Avatar
Re: bug removal
Soap and water with a and a wet rag
Vic Purvis NB4T
07RT
Alabaster,Al.
GVPurvis is offline
post #16 of 19 Old Jun 4th, 2009, 9:33 am
Steve_R's Avatar
Re: bug removal
Spoken like a true Harley rider. Been for a ride, it needs a bath.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #17 of 19 Old Jun 6th, 2009, 11:59 am
wrmoss's Avatar
Re: bug removal
What--is that chinese? I don't get it...
Wade
99 K-1200LT
wrmoss is offline
post #18 of 19 Old Jun 6th, 2009, 6:38 pm
BCVBeck's Avatar
Re: bug removal
+1 on what DaveDragon said. 3% Hydrogen Peroxide & a damp microfiber towel. The HP is like .99 a quart. Hard to beat the value. Cheers.
Bruce
BMW MOA# 130127
IBA# 49203
MSF RiderCoach
USN (Retired)
'13 R1200GSA (Magma Red)
"Life, Liberty, and the Pursuit of All Who Threaten It."
BCVBeck is offline
post #19 of 19 Old Jun 6th, 2009, 6:49 pm
Don't Wait
Thats the key! The quicker you go after them the easier they come off. Soak a rag in water, let sit for a while and they come right off. Same on the windshield. Don't need any soaps or chemicals. Just water..... Now if you wait too long, then use the magic.
I also keep several extra coats of wax on the front of the bike during the love bug season and don't wipe off the last coat.
Cassette removal & usable space? MickS K1200LT 22 Oct 3rd, 2007 6:41 pm
Seat Removal ??? GSinNC K1200LT 4 May 13th, 2007 1:37 pm
PICTURES OF SLAVE DRAIN w/o REMOVAL cccpastorjack K1200LT 5 Mar 25th, 2007 4:35 pm
Running Rich Canistor Removal Motomadman K1200LT 8 Aug 7th, 2006 8:25 pm
Tipover wing removal glenhinegardner K1200LT 4 Jun 16th, 2006 8:28 am
