RV motorcycle carrier - BMW Luxury Touring Community
post #1 of 4 Old Oct 7th, 2008, 5:54 pm Thread Starter
Anyone have any knowledge/experience with carrying their LT (or other large motorcycles) on a motorcycle carrier on the back of an RV? Specific carriers that are good or bad? Thanks.
jadelbert is offline
post #2 of 4 Old Oct 7th, 2008, 6:08 pm
lenny's Avatar
Re: RV motorcycle carrier
there was an rv up the street from me for a week with an lt on the back,i drove by a few times never saw anyone around,so i couldnt ask him any questions,but from the looks of the carrier you ride up on it and im sure there was a way to tie it down
lenny is offline
post #3 of 4 Old Oct 7th, 2008, 6:47 pm
RonKMiller's Avatar
I've got this exact same Eagle Lift - but wider - mounted on the back of my one ton flatbed. I've used it several times to carry my LT. Mine has a beveled ramp which makes it fairly easy to roll it up on the gate. I can do it by myself - but a helper is nice. Mine is rated at 1600 lbs. which is double the weight of the LT. I wouldn't go with anything less. All you would need is a stout wheel chock like the Condor and some heavy duty tie downs for a permanent carrier.
Oh yeah, it's been in continuous service since 1989 without ever having failed. The only thing I've done is replace the cables with higher capacity ones, replace the pulleys and lube it once in a while.
I lift a 1400 lb. hot air balloon basket on it almost daily - and it groans but always works.
This could be easily mounted on an RV frame with a bit of welding. You would probably need to modify the suspension with at least helper springs and air bags to keep it level...
"Like Butt-ahh!"
RonKMiller is offline
post #4 of 4 Old Oct 7th, 2008, 10:23 pm
Wolfgang's Avatar
There have been lots of threats on an RV forum I hang out on at times. The issue is the distance from the rear axle of the motor home to the rear-most part of the chassis were you attach the motorcycle lift. The leverage that the bike has on the frame is tremendous on some installations and flys in the face of common sense. For most applications the consensus is that a 2 axle trailer is the preferred mode of transporting a bike.
Why: It puts minimum stress on the RV chassis, it is much easier to back up than a single axle trailer (I have one and is a bear to back it up with a 36 foot motor-home), and it has brakes that put no extra load on the MH brakes.
I followed a class A MH a while back with a Goldwing on a very nice looking bike lift (I believe the brand is called "Overbuild") The gyrations that the bike made when he went over some interstate expansion joints were quite spectacular.
Wolfgang
K1200LT 1999 Champaign SOLD
R1100RS 1994 Teal SOLD
R1150RT 2003 Blue (Sold)
R1100RT 1997 Blue
Pest, Budapest Hungary
Mark Twain
Wolfgang is offline
Rather longish, but good tips & info! vvk Bike Talk 7 Jun 19th, 2011 4:43 pm
Motorcycle Airbags Part of Safety Trend hagar Bike Talk 9 Sep 16th, 2006 1:38 am
