iPhone volume - BMW Luxury Touring Community
post #1 of 13 Old Sep 24th, 2008, 1:22 pm Thread Starter
charlieg's Avatar
iPhone volume
Is anyone using an iPhone on their bike. I have had no problems with other cell phones and my Autocom unit, but with the iPhone I have almost no volume. I can't see where there is any volume control on the iPhone either.
Any ideas on how to get more volume other than a different cell phone?
-Chuck-
'05 K1200LT
'92 FXSTC
'66 HD Sprint
IBA #375
"Eat, Drink and be Merry for tomorrow we Ride"
charlieg is offline
post #2 of 13 Old Sep 24th, 2008, 2:15 pm
dwsdad's Avatar
Re: iPhone volume
Looking at the iPhone screen, look on the left edge. The top black thingie is the ringer on/off switch. Below that is the volume toggle. Crank it all the way up and you'll hear it fine. I never have to have it high though.
'06 K1200GT - "Road Rocket"
Marshall, Tx
dwsdad is offline
post #3 of 13 Old Sep 24th, 2008, 6:00 pm
Moot's Avatar
Re: iPhone volume
Doug is correct about the location of the volume control for the iPhone. That same control also works if you are using the iPod music function on the iPhone. This allows you to increase or decrease the volume of music which is impossible with gloves on since the touch screen volume control will not react to a gloved hand. I am normally operating my volume at about 2/3 which is more than adequate even at 70 mph or up. My system is a bit different, however. I have a WiRevo dongle on the iPhone broadcasting the bluetooth signal to a Camos with helmet speakers. Both the WiRevo and the Camos have volume controls so I have three possible ways to control the iPhone volume. All three are normally at about 2/3 since if anyone or all are higher than that I start to get distortion on the music. With this set up, I am able to hear the iPhone actually better at 70mph through my helmet that I can just using the phone normally. Hope that helps.
Moot is offline
post #4 of 13 Old Sep 24th, 2008, 6:09 pm
bonafidebob's Avatar
Re: iPhone volume
It depends on how you're connecting the iPhone to the autocom, and whether you're talking about phone calls or music. If you use bluetooth for the phone calls, then the volume is fixed -- usually it's under control of the bluetooth headset. If there's a GPS in the picture here (that is, iPhone -> GPS -> autocom bluetooth adapter), then you can set the phone call volume in the GPS.
For music you've probably plugged the iPhone into the autocom using the 3.5mm headphone adapter, in which case the volume buttons on the side of iPhone will control the music volume. You might want to get a remote that plugs into the iPhone dock connector so you can change the volume on the fly. I've got this setup for music through my Autocom, and it works well.
Finally, the speakers that come with the autocom headset aren't very good. I wear earplugs when I ride, and I can barely hear the autocom through them or over the wind noise. Like many others I replaced the speakers with some from a set from some Koss titanium headphones from Radio Shack, which are much louder and also produce better quality music. I can hear them at speed with earplugs in, no problem. I wrote about my conversion in this thread.
bonafidebob is offline
post #5 of 13 Old Sep 25th, 2008, 6:29 am Thread Starter
charlieg's Avatar
Re: iPhone volume
Thanks for the replies. The rocker button on the left side of the phone seems to only control the ringer volume, I am interested in increasing the volume of a phone conversation. I have the iPhone connected to the Autocom through the mini-pin headphone connection on the top of the phone.
I notice that the earphone, microphone combination that came with the i-Phone is a stereo, three ring pin and my connection to the Autocom is only a two ring (mono) connector could this cause a decrease in volume?
-Chuck-
'05 K1200LT
'92 FXSTC
'66 HD Sprint
IBA #375
charlieg is offline
post #6 of 13 Old Sep 25th, 2008, 7:04 am
dwsdad's Avatar
Re: iPhone volume
The rocker switch does control the call vol, the ringer vol, and the iPod vol. If yours doesn't control the call vol, you have a bad unit.
Marshall, Tx
dwsdad is offline
post #7 of 13 Old Sep 25th, 2008, 7:54 am
browad's Avatar
Re: iPhone volume
That may not be true. It depends on how the iPhone is hooked up, and how the Autocom handles inputs. I've not played with one myself, but with other units they take an input signal and the switching unit (Autocom in this case) ignores the volume control from the original source in favor of the switch controlling the volume. What that means is that the volume control on the iPhone/other source does nothing. You may be able to "cheat" this by maxing out the volume before plugging it in.
An easy way to check the iPhone's switch is to play some music through the headphones/speaker and see if your volume switch works. You can also play with the Sound Check option. Info on that is here.
Adam
2006 K1200LT 2001 Kawi KLR650
The
wants YOU!
browad is offline
post #8 of 13 Old Sep 25th, 2008, 8:11 am
dwsdad's Avatar
Re: iPhone volume
I know the control works on my Motocomm. I would think that any intercom unit would just take the signal from anything and pass it through. The only exception would be a line out, which has a constant output level. An audio out should be adjustable on any device through any intercom.
charlieg, can you adjust the call vol with the rocker with no headset plugged in? How about when the iPhone headset is plugged in?
EDIT: charlieg - did you buy the tty adapter for the iPhone? I needed that to connect to my Motocomm.
Marshall, Tx
dwsdad is offline
post #9 of 13 Old Sep 25th, 2008, 11:43 am
Re: iPhone volume
Probably. AFAIK there is no adapter that lets you use the autocom with the iPod as a telephone headset, because the iPod connector isn't standard. So you may be routing one of the audio channels to the autocom microphone or something like that.
The only phone connections I'm familiar with for autocom use bluetooth for the telephone conversation (uses the headset profile, which is mono audio with a microphone) and a wired connection for music only (stereo audio, no microphone.) Yes, this means your iPod is plugged in to two different inputs on the autocom, but it all works out.
post #10 of 13 Old Sep 25th, 2008, 2:38 pm
Just ridin'
Randy's Avatar
Re: iPhone volume
-Chuck-
To add to the other comments - the rocker will control the ringer volume, when the phone is in standby, the iTunes volume when playing iTunes and the phone call volume when in call. Make a phone call and while the call is in progress, adjust the volume.
Randy Prade
Aurora, CO
Just ride it!
Meet Riley
Randy is offline
post #11 of 13 Old Sep 25th, 2008, 3:54 pm
grifscoots's Avatar
Re: iPhone volume
Would I have to put down my kkkkkkkkaffee, stop applying make-up, quit texting and get out of the left hand lane to accomplish this?
-=grif=-
Grok
grifscoots is offline
post #12 of 13 Old Sep 25th, 2008, 5:00 pm
Re: iPhone volume
And don't forgit your turn signal!!!!
post #13 of 13 Old Sep 25th, 2008, 6:39 pm
grifscoots's Avatar
Re: iPhone volume
You know they don't know what that is.
-=grif=-
Grok
iPhone works with DICE...! davedionne iPod/MP3 4 Mar 19th, 2010 6:28 pm
3G iPhone and Mac 'geniuses' Randy Chit Chat 24 Aug 22nd, 2008 7:45 pm
iPhone 2.0 Software eljeffe Chit Chat 7 Jul 12th, 2008 6:14 am
Left the laptop at home and did it all on the iPhone eljeffe Chit Chat 18 Aug 4th, 2007 11:18 am
GPS 478 music volume JOHNF GPS 2 Jan 6th, 2007 8:09 pm
