Drive Squeal- I smell major repairs$$ - BMW Luxury Touring Community
post #1 of 8 Old Jul 28th, 2008, 5:01 pm Thread Starter
Unhappy Drive Squeal- I smell major repairs$$
Driving to work, second gear, 30 mph. Suddenly there is a horrible squealing noise and the cluth is slippping, or at least power to the rear wheel is lost. Shifted to neutral, the noise stopped. Pushed to a parking lot (whew!) and started it up just fine. Shifted to first and the noise returned as the engine quickly died. I am thinking the dry clutch on my 01 LT is no longer dry. Recently changed all fluids, no issues. Anyone remember where the tie-down instructions for this thing are at?
chrisorkelly is offline
post #2 of 8 Old Jul 28th, 2008, 5:25 pm
DanMartin's Avatar
Re: Drive Squeal- I smell major repairs$$
Sounds more like a driveshaft problem. The rubber bushing connecting both halves may be tearing/slipping. Worn out clutch won't squeal.
http://www.bmwlt.com/files/albums/us...Tie%20Down.pdf
Document is under files/technical documents
used driveshafts are easy to find.
dan martin
DanMartin is offline
post #3 of 8 Old Jul 28th, 2008, 8:09 pm Thread Starter
Thanks for the tie down info.
Any more thoughts on the squealing?
post #4 of 8 Old Jul 29th, 2008, 9:23 am
amarider's Avatar
First thing check and see if you have any fluid left in your clutch reservoir.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is online now
post #5 of 8 Old Jul 29th, 2008, 10:13 pm Thread Starter
Got lots of DOT 4 in the clutch reservoir. I plan on draining all the fluids and checking quantity and quality on the way out. The noise is apparent even in neutral, but goes away after shifting into gear. All with absolutely zero power to the rear wheel.
post #6 of 8 Old Oct 26th, 2008, 2:37 pm Thread Starter
Input spline and clutch plate, various seals and a bearing or 2. $2805.21 at my friendly neighborhood BMW shop. They told me it was not caused by my riding technique or poor maintenance, but that sometimes "these things just go bad". Needless to say, no help from the factory on this one. I feel ripped off. This is a 2000 with about 25K miles.
post #7 of 8 Old Oct 27th, 2008, 7:38 am
razman10's Avatar
OUCH!!!!
Although it's true that "these things just go bad", that's a lot of money to fix a toy!!! We don't want to spend that much to fix "a toy!"
Toys should not break.
__________________
Ray "Razman"
2004 BMW K1200LTE - Rosie (As in Whole Lotta Rosie)
1996 HD Sportster XLH883 Hugger (sold)
1986 Honda Interceptor VF500F (sold)
Your chosen perspective changes everything. - Unknown Author
"You are what you repeatedly do. Excellence is not an event - it is a habit." - Aristotle; 384-322 BC, Greek Philosopher and Scientist
razman10 is offline
post #8 of 8 Old Oct 31st, 2008, 8:12 pm Thread Starter
If it was "just a toy" I would sell it and get a new one. This is my first non-HD touring bike since 1984. Everyone sez Harleys are unreliable. In 20 years and 4 FLH models, I was never once stranded, and never once did anything more than preventative maintenance.
Final Drive failure - no BMW warranty support BobbyLT K1200LT 28 Aug 21st, 2014 3:14 pm
Final Drive Rebuild Offer/CCR Tech Session CharlieVT K1200LT 2 Jun 26th, 2008 7:36 am
Tips, Anti-virus, Anti-Spyware and Hard Drive Maintenance petevandyke Chit Chat 14 Mar 10th, 2008 1:02 am
Final Drive Seal @ Drive Shaft Crestwood330 K1200LT 3 Jun 25th, 2007 7:58 pm
