zumo 550 and satallite antenna - BMW Luxury Touring Community
post #1 of 6 Old Jul 18th, 2008, 8:03 pm Thread Starter
kmdovie's Avatar
has anyone installed the gxm30 to a zumo 550 on a k1200LT??? if so...where did you install that 3" antenna??? i thought it would be small like the antenna i use in the truck that is very small...this honkin thing is large...and i really don't want to drill holes in the tupperware to make it obviously it was rigged... any help would be greatly appreciated...thanks... kirk
kmdovie is offline
post #2 of 6 Old Jul 18th, 2008, 8:24 pm
LFranz's Avatar
Re: zumo 550 and satallite antenna
I mounted my 550 on a BMR shelf.
I dont have the antennea, but I have seen a nice installation
by adding the side shelf to the BMR shelf.( Its an acessory for it, see BMR products) Do a search on this site for GPS installation, I think I saw a pict on there. Good luck
LFranz is offline
post #3 of 6 Old Jul 19th, 2008, 10:46 am
jhsonderb's Avatar
I put my GXM-30 antenna in the front pouch of my Chicane tank bag.
Jim S.
'07 SturmGrau K1200LT
jhsonderb is offline
post #4 of 6 Old Jul 22nd, 2008, 12:18 am Thread Starter
kmdovie's Avatar
thank you...... might go with the tank bag since it will not be as visible...
kmdovie is offline
post #5 of 6 Old Jul 22nd, 2008, 5:55 am
I just installed a 550 and the GXM 30 on my LT. I used the BMR Co-Pilot shelf and an accessory arm for the GXM 30. Works fine and looks good. I drilled the accessory arm and simply screwed it down using 3mm stainless screws. I suspect it's secure enough like that since I cover the whole bike at night anyway. Someone would have to know what it was and want it badly to go to the trouble of getting it, and like all XM radios, it would be useless once it was reported stolen since they won't activate a stolen radio.
I've got the Nav and XM sound piped through the Aux input on my '05's audio system and it nearly perfect. Nearly. The volume is significantly lower than the radio or CD player. I'm boosting it right now with a Boosteroo ($29 at Radio Shack) but I have an Amplirider from Electric-avenues.com ordered that should allow me to synch the volume perfectly.
(That matters only because I want to be able to switch to the radio or cd player without having remember to re-adjust the volume to avoid being blown off the seat!)
Bmyrrh is offline
post #6 of 6 Old Jul 27th, 2008, 10:18 pm Thread Starter
kmdovie's Avatar
thanks...this is helpful... i am probably going with the shelf and i do know the zumo is quiet when it comes to voice commands and music... even using the car adapter... loving the bike...
kmdovie is offline
