6pt v 12pt Sockets....Why? - BMW Luxury Touring Community
post #1 of 15 Old Jun 21st, 2008, 9:51 pm Thread Starter
browad's Avatar
I greatly prefer the 6pt sockets over the 12. Any reason to use the 12 over the 6? Can't think of any offhand...
Cheers,
Adam
2006 K1200LT 2001 Kawi KLR650
The
wants YOU!
browad is offline
post #2 of 15 Old Jun 21st, 2008, 10:06 pm
Re: 6pt v 12pt Sockets....Why?
12 point bolts/nuts. 12 point sockets/wrenches get a "bite" in 6 more positions than 6 points do.
Morley is offline
post #3 of 15 Old Jun 21st, 2008, 10:12 pm
Scott_Anderson's Avatar
I prefer the 6pt socket on a 6pt head/nut as it will grab the flat's of the bolt and not be likely to round-off the points like a 12pt socket is capable of.
Scott_Anderson is offline
post #4 of 15 Old Jun 22nd, 2008, 9:28 am Thread Starter
browad's Avatar
How common are 12pt bolts?
Adam
The
wants YOU!
browad is offline
post #5 of 15 Old Jun 22nd, 2008, 9:56 am
Quite common..in some applications. Jap cars seem to like using them on the engines and in aviation they are everywhere, especially jet engines.
Morley is offline
post #6 of 15 Old Jun 22nd, 2008, 10:11 am
CharlieVT's Avatar
I don't run across 12 point fasteners very often, but when I do I'm glad I have a set of 12 point sockets around.
12 point sockets are "quicker" in that there is less time spent getting the fit-up of the socket on a 6 point fastener. This may seem insignificant until you are working in some awkward, hard to reach place. Then sometimes the 6 point socket won't go on the fastener first try, and you have to stop,click the ratchet to turn the socket a little (two hand procedure) and try again.
12 point sockets often have a thinner wall making access into tight spots easier.
6 point socket are generally stronger, and preferred for high torque applications.
As pointed about above, if the fix of the socket on the fastener is a little sloppy, the 6 point socket is less likely to round off the fastener, slip, and leave your knuckles bleeding.
Having both around makes life a little easier.
CharlieVT is offline
post #7 of 15 Old Jun 22nd, 2008, 11:14 am
grifscoots's Avatar
Where the hell did I put my Whitworths?
-=grif=-
Grok
grifscoots is offline
post #8 of 15 Old Jun 22nd, 2008, 3:21 pm
12 pts give more contact area. Usually don't find them that often (the mercedes NAG trans output shaft nut comes to mind). Mac and Snap-on sell 6 points that will grip a 6 point bolt thats mostly rounded off. Well worth the $ if you wrench for a living or maintain your own vehicle.
Bob1200rtc1 is offline
post #9 of 15 Old Jun 22nd, 2008, 7:20 pm
Zeke's Avatar
Grif;
Only "old" tool men had whitworth, not saying I"M old.
And dont forget where you put the german allen wrenches with the pin.
Zeke
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
post #10 of 15 Old Jun 23rd, 2008, 6:59 am
bigbear's Avatar
Very common in the hydraulic pump & motor industry. Especially Eaton/ Vickers products.
I suspect the initial reason for using these was that they could use a smaller bolt head size and still achieve a torque spec rating for the bolts. I.e. 7/16" 12 point flange head on a 3/8" grade 8 bolt. This allows also allows them to countersink the bolt heads into a casting and less area is required for socket clearance.
Roy Gregersen
85 K100RT sold
02 LTC DOA 9/21/14
12 R1200RT
bigbear is offline
post #11 of 15 Old Jun 24th, 2008, 3:07 pm
I still have a set of Whitworth Combination Wrenches. Wonder if the Simthsonian is interested in a donation?
broxsond is offline
post #12 of 15 Old Jun 24th, 2008, 3:17 pm Thread Starter
browad's Avatar
Now all we need is a Lucas electrics comment. The Prince of Darkness comes! Let's see...what's left?
Adam
The
wants YOU!
browad is offline
post #13 of 15 Old Jun 24th, 2008, 6:13 pm
CharlieVT's Avatar
Question whitworth?
I waiting for someone to tell me what the heck a whitworth is.
post #14 of 15 Old Jun 24th, 2008, 6:46 pm
grifscoots's Avatar
Re: whitworth?
Oh, Charlie. You used to be my hero. http://www.google.com/search?hl=en&q=Whitworth+sockets
-=grif=-
Grok
post #15 of 15 Old Jun 24th, 2008, 7:23 pm
CharlieVT's Avatar
Re: whitworth?
Well color me ignorant and lazy.
I could have googled it myself huh?
Thanks for the links Grif. I found it interesting reading.
This page I found most informative:
http://www.jag-lovers.org/xk-lovers/...th_system.html
Here's from that page: "For some reason now lost in obscurity, the distance across the flats of Whitworth hex nuts and bolt heads is not nice sensible fractions of an inch, nor is it millimeters, nor does it follow any discernable pattern such as a percentage of the bolt diameter. You are supposed to use special Whitworth sized wrenches. The sizes stamped on Whitworth wrenches refer not to the distance between the flats, but to the diameters of the nuts and bolts they are intended to fit. In practice it turns out you can get away with using metric wrenches in most cases."
If you need any Whitworth tools, I'd certianly recommend you get them from King Dick: Abingdon King Dick is a tool company based in the UK still making Whitworth size tools.
Well, in my own defense I have never owned any British Iron, BSA, Trumpet, Snortin Norton, Jag, or anything else that might have a Whitworth fastener that would require a Whitworth wrench. (Well, there is my Rolls )
I was bettin that I actually had a Whitworth wrench, and just didn't know the name for it, but dayem I'm now sure I don't have any such thing. I had thought it might the wrench to tighten the packing seal on the pitman of my sickle bar mower. The mower is a Wood & Smith, made in Canada I think, certianly not the UK.
Name:	Wood & Smith Mower.jpg
2005 LT Accessory Ports & Heated Clothing hschisler K1200LT 47 Feb 25th, 2011 6:21 pm
R1200rt Available Sockets Kaybee40 RT Series 2 Jun 8th, 2008 9:43 pm
12 v. Electrical Relays & Sockets PMitchell Batteries, Chargers, & Electrical 4 Jul 23rd, 2007 9:21 pm
panel type sockets sparknme Intercom, CB, & 2-Way Radios 7 Oct 31st, 2006 11:46 am
Covered DIN sockets. Malki Intercom, CB, & 2-Way Radios 14 Nov 6th, 2005 7:27 pm
