alarm removal - BMW Luxury Touring Community
post #1 of 12 Old Jun 3rd, 2008, 5:51 pm Thread Starter
alarm removal
I am removing the alarm from my 2004 LT and I reached the point where I need to set pins to turn of the fuel pump and starter. Which pins do I need to jumper for each?
Rocky is offline
post #2 of 12 Old Jun 3rd, 2008, 6:12 pm
Re: alarm removal
Look here:
Alarm Bypass
post #3 of 12 Old Jun 3rd, 2008, 6:28 pm Thread Starter
Re: alarm removal
I used this procedure to remove the alarm but the jumpers do not match up. when I jump 3 and 4, it provides power to the starter but when I turn the key to start the bike the starter engages and continues to engage until I turn the key off. Pin 5 does not exist and is blank.
If I rehook up the alarm will it reset to off?
Rocky is offline
post #4 of 12 Old Jun 3rd, 2008, 6:35 pm
Re: alarm removal
It looks like the 04 is closer to the 05 I detailed in this article:
Later Alarms
Just follow the steps for the 12 pin connector and disregard the info on the locking connectors. I have looked at the diagrams for your year and that should get you going.
post #5 of 12 Old Jun 3rd, 2008, 9:13 pm Thread Starter
Re: alarm removal
Thanks that did the trick. Of course I needed my wife to describe the colored wires to me since I am color blind. But once I set the jumpers as you described and I realized the fuse to the fuel pump had blown, the bike started right up.
Thanks again
Rocky is offline
post #6 of 12 Old Jun 4th, 2008, 5:19 pm
Re: alarm removal
Glad it worked out.
post #7 of 12 Old Jun 5th, 2008, 8:53 am Thread Starter
Re: alarm removal
one last problem, since I made the changes to remove the alarm, the right turn signal remains on the entire time while the bike is running. If the kill switch is in the off position the turn signal work as usual except that it flashes faster than the left.
Rocky is offline
post #8 of 12 Old Jun 5th, 2008, 9:31 am
Re: alarm removal
Hey, Ron - if you don't git'r fixed before Satiday, come on to Cheesy Janes in Boerne and Dave or Grif or somebody will scope it out for ya - they're good at blowin' thangs u......, I mean, fixin' thangs up real good.
BTW - if you don't have an alarm manual, I've got one I can loan ya if you wanna make a copy of the key pages. I'll brung it along.
Best
Oh, hey - I forgot. Do the community a favor and add some info to your profile. We never know where the next Lotto winner is if'n the profile is blank!!!
post #9 of 12 Old Jun 5th, 2008, 7:45 pm
Re: alarm removal
Geeze, These crazy germans can't stick with a design. I had you jump pin 10 to pin 2 and pin 6. Remove the jumper to pin 2 (blue/red) and you should be allright. The 05 and up needs this for the turn signals to function. Sorry about that.
On the others it is just an output from the alarm to pin 2 and pin 7 that flashes the left and right side blinkers from the alarm. That is why it was flashing all the time. I need to clean up my article and re-post it for the earlier bikes (2001-2004).
post #10 of 12 Old Jun 5th, 2008, 9:33 pm Thread Starter
Re: alarm removal
Great Minds.............
I got home this evening and worked thru the problem and figure the same out. Everything is working great now. Now all have to do is wait for the FOB and information from Germany and I will reinstall the alarm.
Thanks for the help
Rocky is offline
post #11 of 12 Old Jun 6th, 2008, 10:48 am
sparky_k1200lt's Avatar
Re: alarm removal
Also, if you can believe the factory wiring diagram, another pin is designated for sounding the horn as well. That wire was *not* implemented on my '01 LT
...Bob
2001 K1200LT der LadungsTršger
1978 GL1000
sparky_k1200lt is offline
post #12 of 12 Old Jun 6th, 2008, 6:27 pm
Re: alarm removal
Well Bob between your effort and mine no one should ever be stranded by a blown alarm.
We just all need to carry a few paper clips for jumpers now in addition to shift linkage ball studs, QD "o" rings, metal valve stems and final drives. .
Help! Alarm fuse F3 keeps blowing sparky_k1200lt Batteries, Chargers, & Electrical 3 May 6th, 2013 7:44 pm
HELP! Alarm went off now bike won't start! blavenia K1200LT 12 Jul 22nd, 2009 10:33 am
Help! Alarm Smoked, Killed bike, 2001 LT Wood614 K1200LT 9 Jun 1st, 2008 8:36 am
Possible Alarm Solution Jinks K1200LT 3 May 26th, 2007 9:18 pm
New Alarm Fob for 2003 Dean_BMW K1200LT 0 Nov 23rd, 2005 8:11 pm
