Earplugs that are not as insulating? Less than 30dB? - BMW Luxury Touring Community
post #1 of 12 Old Mar 23rd, 2008, 6:27 pm Thread Starter
Hi, all,
I use earplugs when riding. The typical ones that you can get have usually over 30dB attenuation.
That is too much for me. I'd love to find soft-foam plugs that are just a tad over 20dB.
Any suggestions? Thanks in advance.
Robert in Northern NJ
rdwalker is offline
post #2 of 12 Old Mar 23rd, 2008, 9:36 pm
Re: Earplugs that are not as insulating? Less than 30dB?
Originally Posted by rdwalker
Hi, all,
Take a gander at this site. They should have sumpthin' that'll work for ya. Good luck.
post #3 of 12 Old Mar 24th, 2008, 10:28 am Thread Starter
Thanks, Dick, that site is useful. I ordered the sample pack.
I use 30+ normally, but my new J&M portable intercom (Integrator IV) is barely audible with plugs inserted.
For quite a while by now, I have been using the BMW-branded J&M unit built into my K1200LT; that one is loud enough to hear music and talk through all types of plugs.
I am a bit disappointed with the portable unit (which I need for the R1200GS) - it seems to struggle to generate enough volume. No problem without plugs, of course, but with the 32dB plugs inserted I can barely hear audio even when set at the highest level.
Before I build an in-line booster amplifier for the headsets, I am willing to sacrifice a bit of wind noise attenuation - at least to see how it works out.
Looks like I'll be most likely trying the moldable Mack's plugs. Will let you know.
The 29dB Hearo's are too close to my usual 32dB plugs: even though they attenuate half the audio power, they do not sound much different - human ear's response is logarithmic and reducing audio power by 2 does not have much effect.
Robert.
rdwalker is offline
post #4 of 12 Old Mar 24th, 2008, 11:49 am
Robert.
Robert, I don't know a thang about this product, butt I hear lotsa folks use 'em. Called a Boosteroo, or sumpthin' like that. Apparently a type of in-line audio volume booster. You might check on 'em (Google it) and see if it might work. Good luck, sir.
post #5 of 12 Old Mar 24th, 2008, 12:18 pm
kellenbenz's Avatar
Robert,
You seem to be very knowledgeable on the subject...so you probably already know this...butt...There are earplugs with speakers built in that do a nice job of keeping wind and road noise out while giving you plenty volume for your sounds.
If you are using the J&M integrator, you can get an adapter from cyclegadgets that will offer you a 1/8 th inch stereo jack for them to use
http://www.cyclegadgets.com/Products...asp?Item=SPLUG
http://www.cyclegadgets.com/Products...ct.asp?Item=HA
Check out those sites.
Hope that helps,
Ron
IBA 45658 MOA167437
Total BMW miles 497,451
Goldwing miles 238,383
kellenbenz is offline
post #6 of 12 Old Mar 24th, 2008, 5:24 pm Thread Starter
Thanks, Dick and Ron:
I am trying to start using only one helmet for all my bikes and that is why I do not want to use separate earsets: they do not work with the built-in J&M helmet speakers. Too tight in ear cavities and too painful.
Until recently, I have used Etymotic's earplug-speakers on some bikes and used one helmet on the LT and another elsewhere. Just too much trouble.
By the way, Boostaroo is an amplifier for earsets, so again, it would not help me.
My point is that the K1200LT system works very well, combining my Sat radio, GPS, radar detector, FRS radio and passenger intercom at correct volume.
I would like to make it easy on myself and have the same setup with the same helmet on other bikes and that is why I want to use the compatible J&M Intergrator. Since its volume is lower, I am willing to try less insulating earplugs.
If everything else fails, I may built an inline amplifier into the helmet cord - I am able to do that, but do not feel like it is worth the effort yet.
I'll keep you all posted on the further developments. Time to continue prepping the bikes for beginning of the season. Finally!
rdwalker is offline
post #7 of 12 Old Mar 24th, 2008, 5:43 pm
rmg08057's Avatar
Robert
When the J&M unit first came out for the LT I found that, for me, I would like a bit more volume at the speakers. WHen I explained to the owner what I was doing (wearing earplugs and turning the volume up), he got a bit antsy and made it clear that they weren't intended to be used that way. I am not surprised then that the mobile unit sufferes in this area...a pity as the LT unit is so very good in so many other ways.
Good luck and I'll keep an eye on this thread. Maybe J&M would do a one-off installation of the Boosteroo inline on the curly cord :-).
Ralph
Located: Auckland, New Zealand...
but I left my biking heart along the Scenic Byways of America.....
"Come fill the cup that clears
Today of past regrets and future fears." ....Omar Khayyam
rmg08057 is offline
post #8 of 12 Old Mar 24th, 2008, 9:42 pm Thread Starter
Originally Posted by rmg08057
...WHen I explained to the owner what I was doing (wearing earplugs and turning the volume up), he got a bit antsy and made it clear that they weren't intended to be used that way...
Interesting!
I'll post the results of my experiments here.
So far, I found that it is the output of the Integrator that is limiting (it can only put out so much) rather than the input having a limited sensitivity (like the AUX input on K12LT factory radio).
I have boosted the inputs using my Mix-It amplifier, but it resulted in noisy clipping of the audio (distortion). That may be due to the fact that the Integrator is designed to use battery power sparingly and has lesser maximum output swing than the K12LT system running directly off the bike power system.
As said, my preference at this point is to use less-attenuating plugs. If that does not work out, I may look into amplifying the output to helmet speakers. That is going to be quite cumbersome, so that I'll leave it for last.
I design electronics for living, therefore I am not worried about the task, however I do not feel like cutting up the cords and adding yet another bulky box to the setup.
rdwalker is offline
post #9 of 12 Old Mar 24th, 2008, 11:32 pm
Sensaphonics (http://www.sensaphonics.com/) provides custom molded earplugs that fit a variety of earphones. I have a set for my Shure SE530's. I use them for air travel. You can also get foam inserts that go into the slot in the place of the (Shure or other brand) earphones. Assorted foam densities are available, with different amounts of sound attenuation; you can try them until you find one with the right level for your needs. If I remember right, they start at -5 or -7 dB, and range up to -30 dB (??).
You go to an audiologist to get the molds made. The audiologist sends the molds to Sensaphonics and the new earplugs come back in about three weeks or so.
Custom-fitted earplugs are the most comfortable and give the best seal, because they fit your ears perfectly. With the earphones in, they give near perfect isolation, even on a noisy airplane full of crying babies, and I can listen to music at a quiet level.
XMagnaRider is offline
post #10 of 12 Old Mar 25th, 2008, 3:37 pm
You might want to check these by Alpine. Number one in Europe. Still may be to much reduction for you. They come with two filters so that you can 'tune' them. http://motorcyclingprovisions.com/pr...8&productId=84
2spark is offline
post #11 of 12 Old Mar 27th, 2008, 10:29 am
I have had a good bit of luck with the self molded kits. You mix two parts together and mold them into your ears - wait the allotted time and you have custom silicone ear plugs. I have found that if you keep them clean, they will last a long time - or until you Golden finds one on the floor and chews it up.
My last kit came from an online sport shooting website. I figured they would have decent ear protection products and they did - at a better price than motorcycle specific sites.
If you are interested, I will see if I can find the invoice and give you a website. I purchased two just in case I messed one up.
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
post #12 of 12 Old Mar 31st, 2008, 9:43 pm
BecketMa's Avatar
Have you tried cutting the foam ear plugs?
BecketMa is offline
Small earplugs? Children's sizes? rdwalker Bike Talk 3 Aug 16th, 2007 8:13 am
J&M Headset loud enough with earplugs? rdwalker Intercom, CB, & 2-Way Radios 7 Jan 19th, 2007 12:11 pm
New type of earplugs eljeffe Bike Talk 2 Jul 25th, 2006 10:13 pm
Earplugs? tomowskifz6 Bike Talk 21 May 27th, 2006 7:21 am
Cool DIY Earplugs Ekim Intercom, CB, & 2-Way Radios 23 Apr 1st, 2006 11:52 pm
