Building a Trailer - Suspension Question - BMW Luxury Touring Community
post #1 of 15 Old Feb 29th, 2008, 11:57 am Thread Starter
jorawro's Avatar
I am in the process of re-designing my trailer that I built a couple of years ago. I am questioning the need for "suspension" (springs).
I built my current trailer with independent torsion suspension but the lightest I could buy were 500 pound rating. After pulling it about 25000 miles I have come to the conclusion that any "spring rate" I have is in the tires.
Am I out to lunch thinking that a trailer with no springs would work?
Roy Jorawsky
Deputy Chief - SFD
2002 K1200LT - "BackDraft" - Deceased
2008 HD Ultra Screaming Eagle
jorawro is offline
post #2 of 15 Old Feb 29th, 2008, 12:31 pm
Re: Building a Trailer - Suspension Question
don't the springs help absorb the shock from bumps to help the tires. granted the tires carry the weight.
no i'm not an engineer.
Loansumrider: Jim
01 LT Fast Pacific Blue ... " The Goose "
? when to ASUME, and HOW MUCH should you ASUME, safely ?
loansumrider is offline
post #3 of 15 Old Feb 29th, 2008, 1:16 pm
perhaps an airbag system?
J.M.J...
Dcn Channing
post #4 of 15 Old Feb 29th, 2008, 2:26 pm Thread Starter
jorawro's Avatar
Normally that would be the case, but ----- with the trailer loaded I wouldn't be looking at more than 300 pounds total weight. If you deduct the weight of the wheels, axle, springs (unsprung weight) you are left with +-200 pounds. Even using a single leaf on each side I doubt that there would be enough to flex a spring.
I'm not an engineer either -- that's why I thought I would check with the collective wisdom of this board, just in case I'm missing something very obvious
Roy Jorawsky
Deputy Chief - SFD
jorawro is offline
post #5 of 15 Old Feb 29th, 2008, 4:42 pm
garry_kramer's Avatar
If at all possible I would design it with independent suspension. I think on a lighter trailer this would be better.
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
garry_kramer is offline
post #6 of 15 Old Feb 29th, 2008, 7:33 pm
Slim's Avatar
not a engineer by no means but when i built my coffin in 98 i pulled it for a few months with the springs and everything was fine but i wanted to lower the trailer so it would sit level when hooked to the bike so i made her a rigid pulled it to june jam approx 100-150 miles pulled terrable and cracked a few boards so i put the springs back in and have logged ????miles with no problemsI DO PACK THE WHEEL BEARINGS AT LEAST TWICE A YEAR
Slim is offline
post #7 of 15 Old Feb 29th, 2008, 7:56 pm
motorhead's Avatar
My #1 camping & touring buddy built a small trailer a few years ago with NO suspenion ..... YIKES !!
Lasted one year pulling that BOUNCING S.O.B. !!
Even with air pressure down to 18-22# ( Perfect pressure to spread tread contact patch evenly) Than damn trailer on silky smooth surfaces was fine, but get into rythemic ripples in the road way it bounced like a basketball constantly. If you cornered with any speed going into rough surfaced corners the trailer would skip sideways behind him.
Built another sub frame with light leaf springs, now all is fine and running @ same inflation pressure on tires.
JMHO. Scott
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #8 of 15 Old Feb 29th, 2008, 8:44 pm
Patric's Avatar
I used the leaf springs off the front of a snowmobile . They worked good . But that was around '81 , & the snow machines are a bit bigger now . So they may be a bit stiffer ...
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #9 of 15 Old Feb 29th, 2008, 11:05 pm Thread Starter
jorawro's Avatar
Thanks for the input guys .
Looks like I will go with the springs, best to be on the safe side and it adds very little more weight.
Roy Jorawsky
Deputy Chief - SFD
jorawro is offline
post #10 of 15 Old Feb 29th, 2008, 11:32 pm
Smile Re: Building a Trailer - Suspension Question
Don't know for sure what your design is, but on the two I have built through the years I used spring / shock assemblies from the rear of a motorcycle. Lots of sizes / weights / lengths / styles / types, to choose from.
Good Luck!
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Dman is offline
post #11 of 15 Old Mar 1st, 2008, 12:01 am
Take a look here
http://www.synthx.com/articles/trailer-versatility.html
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
post #12 of 15 Old Mar 1st, 2008, 6:46 am
RonKMiller's Avatar
Shocking.
Twin 250 lb. springs from Truckspring.com. Shocks from Scooterworks.com.
I'm switching out the garbage Chinese trailer tires for these UNSAFE AND DANGEROUS REMANUFACTURED Michelin 225mph aircraft tires from Desser.com next week.
I need a 'Busa.
ID:	16881   Click image for larger version
"Like Butt-ahh!"
RonKMiller is offline
post #13 of 15 Old Mar 1st, 2008, 7:39 pm
taylorjn's Avatar
+1 on suspension. Started trailering with a Smitty's - no suspension except the tires @15psi. On the way home on the first trip a guy pulled next to me at the pump and said he and his lady were placing bets on when the trailer would flip and ground us. Never knew it - riding a Beemer, natcherly. The Smitty's went in favor of our first Bushtec. No more bounce!
Jim Taylor
Minneapolis
07 Black LT "Dancing Heart", 03 Quantum "Ice"
02 Black LTC "Raven" (RIP 8/26/06)
08 Can-Am Spyder (hers) (#731)
taylorjn is offline
post #14 of 15 Old Mar 2nd, 2008, 9:05 am
kellenbenz's Avatar
Roy,
I built a cargo trailer years ago without any suspension. It worked, but we used it for camping and broke many Coleman lantern globes before learning how to pack them. It bounced a lot. The guy I sold it to complained that it pulverized all of his pills on a 400 mile trip. When I built the Suitcase trailer(photo attached),I decided to use the independent torsion type half axles. This has worked out great for me. I got them from Southwest Wheel Co.
http://www.southwestwheel.com/store/...alf-axles.aspx
Hope that helps you out,
Ron
ID:	16902   Click image for larger version
IBA 45658 MOA167437
Total BMW miles 497,451
Goldwing miles 238,383
kellenbenz is offline
post #15 of 15 Old Mar 2nd, 2008, 11:25 am Thread Starter
jorawro's Avatar
Thanks Ron
I used the same torsion axles on my last build. I found them a little stiff as I didn't get anywhere near the load rating for them. I have decided to go with light single spring leafs this time --- will report back on the results
Roy Jorawsky
Deputy Chief - SFD
jorawro is offline
Suspension adjustment assembly question davek1 K1200LT 2 May 8th, 2007 9:24 am
Question about trailer towing ColoSpgs_K1200LT Trailers, Sidecars, & Trikes 11 Jul 19th, 2006 6:02 am
Building a trailer McRuss Trailers, Sidecars, & Trikes 4 May 7th, 2006 9:10 am
Question about Duantless hitch and Bushtec trailer SilverBuffalo Trailers, Sidecars, & Trikes 3 Oct 10th, 2005 8:04 am
