LT 1200 maintenance schedule - BMW Luxury Touring Community
post #1 of 3 Old Feb 19th, 2008, 9:04 pm Thread Starter
Timmy's Avatar
Can somebody help me out in regards to what needs to be done in regards to the "major service" recommended at 12K for my LT 1200? I have a local mechanic that will do the work but I need a list of items that need to be completed? Thanks.....................
Timmy is offline
post #2 of 3 Old Feb 19th, 2008, 10:31 pm
Cooler on the east coast!!!
gglove's Avatar
Re: LT 1200 maintenance schedule
Welcome to the site. The 12000 mile service is a big one!
I hope this helps:
http://www.bmwlt.com/forums/attachme...achmentid=9177
G-Glove
2003 Silver LTC
gglove is offline
post #3 of 3 Old Feb 20th, 2008, 8:15 am
Timmy - the recommended service items that may be performed by your local mechanic (assuming he/she is familiar with BMW K engines and the power train on the K1200LT) can be found in the small Service and Technical Booklet that should have been delivered with your bike. I'm not sure what model year of K1200LT you have, but there are two maintenance lists that apply. I believe the one for model years '99 thru '04 were changed somewhat and followed up with the newer model year service check list. John Flowers has the latest version, and you'll find the earlier version listed here as an attachment.
Your mechanic won't be able to tap into the Motronic unit to read any fault codes that may have occurred during ownership (takes a rather expensive MoDiTec machine to do that, in most cases - although there is an aftermarket unit labeled GS-911 that some folks use and you may hear from them later).
At any rate, you, or your mechanic, should obtain either an OEM shop manual and electrical schematic, or the Clymers aftermarket tech manual, if you're gonna do proper service on your scoot. Highly recommended; and I believe there is/was a set for sale in the classified forum.
Good luck, Timmy. Let us know how thangs turn out. And welcome to the community.
maintenance schedule iehrlich K1200/1300GT (The Next Generation) 1 Aug 20th, 2007 8:05 pm
K1200LT Maintenance Schedule rsp2112 K1200LT 4 Jan 7th, 2007 11:23 pm
Maintenance schedule for an 06 graydude K1200LT 4 Jul 29th, 2006 8:01 pm
