1100LT using oil - BMW Luxury Touring Community
post #1 of 4 Old Aug 5th, 2007, 3:42 pm Thread Starter
ironbuttwannabe's Avatar
1100LT using oil
I have an 1100LT that uses about 3/4 of a quart of oil every 2 days on the highway, which is around 2,000 miles. Around home it uses no oil. Im servicing the bike here soon and is there anything I can check for losing this oil? Or is it a normal thing when you turn higher RPM's. There is no oil under the bike ever after sitting. It is close to 85,000 miles. thanks
neil
Neil '00 K1200LT '08 KLR
"Far away, is far away...
Only if you don't go!!!"
ironbuttwannabe is offline
post #2 of 4 Old Aug 5th, 2007, 5:09 pm
K11 oil consumption
Talk to the K11 owners' group--they're really helpful and knowledgeable.
http://k11og.org/
ljjohns is offline
post #3 of 4 Old Aug 6th, 2007, 9:48 am
UncleRock's Avatar
Compression check, first thing I'd do. Everything heats up on LD ride, more oil gets past loose rings. I would also look at the color of the plugs for signs of oil getting into combustion chamber.
Rock
I'll will poisons the soul
Living well is the best revenge
Rock
UncleRock is offline
post #4 of 4 Old Aug 6th, 2007, 10:20 am
JATownsend's Avatar
neil
I have a close friend who rides an 1100LT. He has almost 100,000 on the odo. During a quick run from Nova Scotia to Indiana, he needed to add a 1/4 qt every 1000 miles or so. (I added nothing) His scoot is meticulously maintained, but when ridden long and hard (all day at 80+) it uses some oil.
I know that is not a tech answer. But, he has NO other issues and he considers that level of consumption normal at those speeds with that engine.
J. Averill Townsend
Bloomfield Hills, MI
IBA# 24374
2002 K1200LTC - Silver
JATownsend is offline
Should I buy one? decompressing K1200LT 10 Jun 21st, 2007 2:04 pm
Old School Suspension Question K1100LT BlackHoof Other K-Bikes Discussion 6 Mar 13th, 2007 11:43 pm
1100LT vs 1200LT bigbear Other K-Bikes Discussion 12 Mar 2nd, 2006 8:41 am
