Final Drive Oil - BMW Luxury Touring Community
post #1 of 4 Old Jul 11th, 2007, 10:28 am Thread Starter
donsobeck's Avatar
Final Drive Oil
Here I sit as a 4 %er twice, and with a bottle of Valvoline sae 85w=140 synthetic blend that meets api services GL-5, MT-1.That its the final drive engineering that is bad and not the oils being used. But only GOD will say for sure.
DON
donsobeck is offline
post #2 of 4 Old Jul 11th, 2007, 12:38 pm
kdog's Avatar
Don,
How was the drive fixed the first time? Was it a bearing replacement or an entirely new drive?
-joel
kdog is offline
post #3 of 4 Old Jul 11th, 2007, 4:06 pm Thread Starter
donsobeck's Avatar
The bearing was replaced by BMW under warranty with a 17 ball unit.
The first went out at 30,000 and the second at 90,000.
After the first the oil in the final drive was changed at the same time as engine oil.
The second went out after 2000 miles after a oil change and the drain plug looked great.
DON
post #4 of 4 Old Jul 11th, 2007, 4:51 pm
kdog's Avatar
Thanks, Don. My gut feel is that after a bearing replacement, the failure rate of the drive is MUCH higher than 4%. Probably more like 75%. That's due to the difficulty of properly setting up the rear drive after a bearing replacement. Most mechanics simply aren't qualified to do the job. If and when mine finally fails, I'll buy a brand new drive.
Regards,
-joel
kdog is offline
Final Drive failure...05LT....49,000 miles DRothermel K1200LT 51 Jan 3rd, 2012 4:08 am
Final Drive murray K1200LT 22 Sep 28th, 2008 10:02 am
Final Drive Pivot Needle Bearings Moonshine K1200LT 27 Oct 8th, 2007 5:24 pm
So what is a final drive worth ? Patric K1200LT 12 Jun 27th, 2007 4:47 pm
