Fuel Tank Filler Neck Mod - BMW Luxury Touring Community
post #1 of 32 Old May 4th, 2007, 1:19 pm Thread Starter
murray's Avatar
Question Fuel Tank Filler Neck Mod
Has anyone drilled holes in the fuel tank filler neck in order to ease tank filling? If so what technique did you use ?
Thinking about inverting tank and use the shop vac to suck out plastic debris when drilling.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #2 of 32 Old May 4th, 2007, 1:25 pm
grifscoots's Avatar
Be sure to fill your lighter real good so you can see while working!
-=grif=-
Grok
grifscoots is offline
post #3 of 32 Old May 4th, 2007, 1:45 pm
Mein Gott! Don't use a ShopVac! There will still be gas fumes in the tank and they are explosive. The ShopVac is NOT explosive proof and you'll become a flambe.
Morley is offline
post #4 of 32 Old May 4th, 2007, 1:52 pm
Mein Gott indeed! use some air pressure into the tank from the removed Fuel Pump...
MAYBE!... but not recommended....
What are your problems fueling Mein Beasty? Certainly not worth a couple weeks in the Army Burn Center...
J.M.J...
Dcn Channing
post #5 of 32 Old May 4th, 2007, 2:02 pm Thread Starter
murray's Avatar
Very true,Was planning on empty tank my shop vac has a 20 ' hose . After posting thought the vac deal through and will not use.
I need every drop of fuel,minimize the effort and I want to speed up my fuel stops. Even though it only takes about 5 m to fill the main and fuel cell from start to finish with documentation.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #6 of 32 Old May 4th, 2007, 2:47 pm Thread Starter
murray's Avatar
I did this to my GS but it was never needed on the LT.
Even with a fuel cell I need it.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #7 of 32 Old May 4th, 2007, 6:03 pm
johnrehder's Avatar
Smile Is this a joke?
You really aren't thinking about doing that are you?
looking around for a possible replacement
2001 K1200 LTC Mauve (Hi-Way Star) may she rest in peace!
CCR'2001 Hotsprings, AR., Sante Fe, NM., Gatlinberg, TN.
Breckinridge, CO., Grand Teton Nat. Prk, WY.
Chateau Elan, GA., Tan-a-Tar-A missed it!
johnrehder is offline
post #8 of 32 Old May 5th, 2007, 4:38 am
dmatson's Avatar
The first week I got my LT I was filling it up and had the nozzel in the tank and my foot slipped on some gas and the filler nozzel kind of torqued sideways and I heard a crack. I took the nozzel out and looked down to see the flat plastic disc in the filler whole had cracked and sepperated from the tank. I thought crap I just cracked my tank. I got my leatherman out and reached in and grabed the plastic and then realized it was just a disk, so I poped it out and what a difference in filling the tank I can see into the tank as I am filling it.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #9 of 32 Old May 5th, 2007, 5:59 am Thread Starter
murray's Avatar
No it is not a joke !
Perhaps you do not see the benefit. BTW why does this upset you ?
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #10 of 32 Old May 5th, 2007, 6:12 am Thread Starter
murray's Avatar
Doug thanks for your info.
To clarify I will have a empty tank fuel pump assembly removed well vented work space tank grounded etc.
The holes I will drill will be on the filler neck below the threads.
If we were dealing with a RT or GS the filler neck can be removed separate from the tank. Friends who have done this mod to there RT are very happy.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #11 of 32 Old May 5th, 2007, 6:58 am
CharlieVT's Avatar
I am curious too.
I don't understand the problem or see the benefit either. Is this supposed to vent the tank during filling so that it fills faster? Or somehow allow you to get more into the tank?
I would consider the benefits of a hole drilled in the tank's filler neck (benefits which I clearly don't understand) against the increased risk of fire during a tipover or a crash.
Until I understand this better it sounds like a solution in search of a problem to me.
CharlieVT is offline
post #12 of 32 Old May 5th, 2007, 8:19 am Thread Starter
murray's Avatar
[QUOTE=CharlieVT]I don't understand the problem or see the benefit either. ?
>>SNIP prior post>< Motive I need every drop of fuel,minimize effort and speed up my fuel stops. Even though it only takes about 5 m to fill the main and fuel cell from start to finish with documentation<<
Always a valid concern but,Tank vent and overflow will not be altered therefore no increase risk of fire.
Charlie there isn't a problem.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #13 of 32 Old May 5th, 2007, 9:54 am
the1mavin's Avatar
Pete,
Mythbusters (the Discovery channel show) did everything they could to get a Shop Vac to ignite and were not very successful so I would not worry about that too much.
I am curious why you would do this though? Is it an Iron Butt thing - fill up faster and ride more miles? I am not condemning it just wondering the about why.
Tim
2005 Graphite
The only way to live is in the wind....
the1mavin is offline
post #14 of 32 Old May 5th, 2007, 10:14 am
RonKMiller's Avatar
I'll race you side by side to see who can fill their tank the fastest, with your proposed mod vs. my stock tank.
I'll bet you'll win by a second or two.
Then with both tanks full, we'll tip them over to simulate a crash - and see who can first accumulate a gallon puddle of gas on the ground.
I'll bet you win again, but his time by several minutes.
"Like Butt-ahh!"
RonKMiller is offline
post #15 of 32 Old May 5th, 2007, 10:24 am
RonKMiller's Avatar
Originally Posted by the1mavin
Pete,
Tim
They did not try very hard.
There was an incident at an FAA Certified Balloon Repair Station in Albuquerque a few years ago. I know the owner very well.
One of his repairmen was vacuuming metal chips with an extension wand from the bottom of an empty 15 gallon propane fuel tank that they had just drilled for a repair. (Propane has about 10% less energy than gasoline)
The large shop vac exploded with the force of a small bomb, and there were pieces of shrapnel in every part of the shop, luckily it was mostly plastic.
To this day he still realizes how lucky he was that no one was hurt or killed.
Myth confirmed.
"Like Butt-ahh!"
post #16 of 32 Old May 5th, 2007, 11:34 am
Pete,
Hate to burst their/your bubble, but they are F.O.S. My father was head design engineer for Shop Vac and I know for a fact they will explode. There was a non english speaking employee at a Texas co. that died from an explosion when he was using a Shop Vac to clean out the toner dust in a room full of copiers. Big law suit ensued...never mind the warnings on the product and in the packaging that daid not to use it on flammable products or in the presence of them.
Morley is offline
post #17 of 32 Old May 5th, 2007, 11:44 am Thread Starter
murray's Avatar
The tank is sealed by the top of the cap, Go look.
Happy Trolling!
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #18 of 32 Old May 5th, 2007, 12:28 pm
Pete,
I just wanted to add that I know exactly what you're trying to do, and exactly why. I'm planning on pulling the cap off my GT and drilling some holes for the same reasons. I even thought of making an extension tube to lift the gas cap up about 6 inches to deal with those pesky fuel hose nozzles.
Maybe you could just pop out the disk like Doug mentioned.
And don't let the naysayers get you down. Their limited experiences mean they just don't understand. Or they just don't have the same efficiency requirements as we do.
But I would stay away from the shop vac though.
post #19 of 32 Old May 5th, 2007, 1:33 pm
dmatson's Avatar
The plastic ring I took out of the tank with my leatherman had what looked like a indetation where it attached to the main body of the tank. With it out it is just alot easier to fill the tank, who cares about faster. It would be the first thing I would do if I got another LT. I do know that a shop vac will cause an explosion, seen it first hand on the a rescue call while working at the fire dept. Here is a pic of my filler, instead of drilling I would just take a sharp knife and cut it out it's thin brittle plastic not like the tank.
14' KTM 1190
72' Honda SL 100
65' Honda CB160
70' Honda CB350
dmatson is offline
post #20 of 32 Old May 5th, 2007, 2:39 pm
johnrehder's Avatar
Smile not upset
Just can't understand why that would benefit your gas stops. Are you talking about the filler neck on an aux tank? I just have never heard of a need to have that done to a gas tank. party on if you think it will benefit your stops, maybe this is the next gas cap type mod and everyone will be drilling!
post #21 of 32 Old May 5th, 2007, 3:46 pm
Rick-L's Avatar
OK I'm kinda slow... but after 15 or 20 post I think I understand.
You're not really planning on drilling the filler neck itself, but the disc inside that 'blocks' it, correct? Then as the fuel goes in the tank, the air, fumes, etc. inside the tank can escape faster and the pump won't keep shutting off? What is the intended purpose of that disc anyway, just to prevent splashback or contain the vapors for reclamation by the pump nozzle?
Am I the only one who had his jaw dropping thinking you were gonna drill into the side of the neck?
Or am I still way off?
Rick-L is offline
post #22 of 32 Old May 5th, 2007, 4:08 pm
bowlesj's Avatar
I know what Pete is doing, but for those of us not in LD competition, that ring is not such a bad thing, at least for me.
When I fill I put the nozzle all the way in. Run it until autoshutoff. Then I raise the nozzle and find the ring with the end of the nozzle, drop the nozzle down just a hair below the ring, and pump again until shutoff.
I probably don't get a complete full tank, but I never get splash back and I don't have to watch the level rise, which can be difficult in some lighting.
Just my $.02.
2004 - LT - Anthracite
bowlesj is offline
post #23 of 32 Old May 5th, 2007, 4:37 pm Thread Starter
murray's Avatar
Smile
John here are the benefits and reason's endurance riders would perform this mod. If one ever pushed their physical mental limits on the bike you realize even the simple tasks deplete energy.
Imagine 10 oz more fuel in the tank during a 11 day rally.Picture 31 gas stops at a minimum X 10 oz =311 oz more fuel or 2.43 gallons.
1- allow more fuel to be put in the tank.
2- Less energy expenditure at fuel stops .
3-reduces mental and physical demands-fatigue.
So perhaps this is not for everyone but a little extra fuel may make the difference in making it to the gas station
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #24 of 32 Old May 5th, 2007, 4:44 pm Thread Starter
murray's Avatar
Originally Posted by Rick-L
You're not really planning on drilling the filler neck itself What is the intended purpose of that disc
Yes drill the filler neck.
The Disc and filler neck allows head space in the tank for fuel expansion with increasing temps.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #25 of 32 Old May 5th, 2007, 4:56 pm
dmatson's Avatar
The disk is a requirement just as it is in all of our cars so you have to use unleaded gas, the nozzel is smaller.
14' KTM 1190
72' Honda SL 100
65' Honda CB160
70' Honda CB350
dmatson is offline
post #26 of 32 Old May 5th, 2007, 9:25 pm
RonKMiller's Avatar
Happy Trolling!
No kidding, I never realized that. Brilliant.
I would like to see your mod when finished, and I encourage you to do it!
I've only done about - oh - 30 or so on the LT that NO ONE else has thought of...
So what you are trying to do is to fill your tank just a leetle bit faster (and to keep that pesky pump from shutting off when your tank is full like it is designed to do) and get an extra 8 ounces of fuel, correct? Is this the edge you are hoping for that will help you win an LD competition?
I'll be the first one there with a fire extinguisher when the auto shutoff on the pump doesn't work properly and you've got a a major gas spill. Haz mat and the Fire Department will be second. Might delay you just a tad.
Some mods make lots of sense. This one is just plain dangerous.
... and illegal.
IMHO.
Done trolling!
"Like Butt-ahh!"
post #27 of 32 Old May 5th, 2007, 9:34 pm
Hi, Pete - lissen, I got no quarrel with your tank filler neck mod, butt I'll add a word of caution here. Back in '99/'00/'01 and maybe even since then, there were anecdoctal posts about folks letting the gas station hose 'pistol nozzles' create a problem with the in-tank tube where the fuel level sensor lives. Seems that it's possible to insert the the 'pistol nozzle' into the tank and turn it in such a way as to dent or crimp the tube, thereby causing the level sensor to provide a false reading. It's never happened to me and ole Toad, so I can't tell ya what position contributes to the possibility. I'd just say that increasing the diameter of the tank filler neck by removal of the disk 'might' allow that 'pistol nozzle' more lateral movement with a chance at damaging the tube. Just food for thought and to be aware of the possibility, especially if one is in a hurry to tank up and go. Good luck with your project, Pete. Hope you accomplish what you wanna do, with no side affects.
post #28 of 32 Old May 7th, 2007, 12:49 pm
dglenn1's Avatar
An additional note on the disk. Mine was damaged and I took the bike to the dealer since it was still under warranty. They agreed to replace the tank. Went to pick up the bike with the new tank and -- NO DISK!! I verified they had actually replaced the tank with a new one but apparently replacement tanks don't have the disk at all. If anyone else has had theirs replaced and can verify, I'd be interested.
(BTW - I must be slow because I don't get the mod that is being described at all, but it isn't important to me.)
Dan
2005 K1200LT - Ocean Blue
; Nolan 103 Helmet w/Bluetooth;
and
(Secures gear/luggage);
; Droid X (Replaces
and factory radio);
(Not installed);
(Currently unistalled),
; Clymer Manual; BMW Service DVD
dglenn1 is offline
post #29 of 32 Old May 7th, 2007, 3:33 pm
kriach's Avatar
My 07 LT does not have disk in the filler neck. I will take a pic tonight and post it. Mine is a Canadian/European model so there may be differences between the two.
Regards
Ken Riach
2007 K1200LT
kriach is offline
post #30 of 32 Old May 7th, 2007, 6:07 pm
surfran's Avatar
I would guess the disk is there for environmental reasons to better seal the tank from fumes or vapors exiting the machine. Kinda like the new gas cans that don't have a normal vent.
2000 Canyon Red "Crimson Cruiser"
40,000 miles grinning, and counting....
BMWMOA # 131660
surfran is offline
post #31 of 32 Old May 8th, 2007, 2:29 pm
dmatson's Avatar
Remember when we all had to change to unleaded gas? They made the nozzel smaller than the leaded one and put a "disk" in the filler so we could not put the leaded nozzel in by mistake as that would have destroyed the catalitec converter, it's still here just go look in all your gas tanks. When you get a smog test done on your car they take off the cap and check for the small hole and check the seal and pressure of you cap. Even though you can't buy leaded gas any more maybe they are worried that we may put diesel in!
14' KTM 1190
72' Honda SL 100
65' Honda CB160
70' Honda CB350
dmatson is offline
post #32 of 32 Old May 8th, 2007, 2:45 pm
Cat Herder
andy's Avatar
Yes, I drilled a few air holes into the tube that extends into the gas tank, no problem. The way I did it was just to push a sharp instrument through the plastic tube. That way way there is not excess material, nothing to fall to the ground, nothing to clog anything.
Andreas Pleschutznig
'14 GSAW soon:
Still in search of Occam's razor to cut a Gordian knot.
andy is offline
K1200RS Fuel Smell? old1951 Other K-Bikes Discussion 1 Apr 23rd, 2007 8:07 pm
Pinched line under fuel tank rattler50 K1200LT 9 Apr 20th, 2007 5:30 am
Fuel tank removal Schweintechnik K1200LT 13 Nov 16th, 2006 12:02 pm
Fuel Cell Installation Questions MolenaarD K1200LT 16 Nov 16th, 2006 11:34 am
