ABS lights - BMW Luxury Touring Community
post #1 of 14 Old Apr 30th, 2007, 6:33 am Thread Starter
ABS lights
My 2004 1200LT has only done 7000km, it has a persistant fault that my local garage cant solve. I know that there is some very knowledgeable persons that use this site from my previous post so perhaps you can help.
The ABS & warning light flash together once every second, I think this means brake fluid level? But every thing has been checked out ok, also the computor check shows no fault. The brake lights are all OK, if I turn off & start again, the problem is still there. I have to drive around 20km then stop, turn off ignition & start again, this seems to work.
Do you have any idea what causes this, I do live in a warm country & wondered if excess temperature can cause this?
harryt is offline
post #2 of 14 Old Apr 30th, 2007, 7:03 am
ABS lights
I had a similar problem, my lights would flash after rapid acceleration. Tried many options for a fix, finally took the bike to dealer I trust, BMW of Charlotte, NC. It turns out when I had a rear tire replaced in MO. the dealer there did not put the rear caliper bolts in the proper place. I don't know why they even had them off but now all is well.
budzee is offline
post #3 of 14 Old Apr 30th, 2007, 7:37 am
bowlesj's Avatar
Make sure the rear reservoir of the dual reservoir behind the right pannier is full up to the neck. My '04 must be completely full, even beyond the max mark. I think the switches in the reservoirs have varying sensitivities.
Mine will behave as yours if not completely full. And FWIW the rear portion of the res. is for the front brakes.
Some will say a low battery will cause this, but in my case, I never get this fault even with an almost dead battery as long as the reservoirs are full.
2004 - LT - Anthracite
bowlesj is offline
post #4 of 14 Old Apr 30th, 2007, 7:44 am
NOGILLS2's Avatar
Cool
Typically, flashing abs lights mean low brake fluid in the rear fluid reservoirs, there are two in the rear, and one of them is somewhat hidden and is usually the culprit. It only takes a little bit to cause this problem, I have a syringe that I use to add fluid to mine. Hope this helps!
NOGILLS2
Booze Brother# 69
2003 K1200LTE "BEERBURNER" RIP 07/21/09
2006 Aluma Trailer "AFTERBURNER" SOLD
2007 ST1300ABS "Quicksilver"
NOGILLS2 is offline
post #5 of 14 Old Apr 30th, 2007, 8:34 am
A weak battery can also cause this, as well as worn brake pads. Flushing the brakes can also help. jrlakin
jrlakin is offline
post #6 of 14 Old May 1st, 2007, 5:42 am Thread Starter
Many Thanks, I was not sure about the rear brake fluid level. I am sure that this is the problem. I will have the garage check.
harryt is offline
post #7 of 14 Old May 1st, 2007, 5:43 am Thread Starter
Many thanks,
I will check this out.
harryt is offline
post #8 of 14 Old May 1st, 2007, 6:03 am
BLBantz's Avatar
My rear fluid res. needed only two or three drops of fluid and the flashing went away. I guess they are very sensitive.
Brian
Fanwood, NJ
2003 K1200LT Anthracite
BLBantz is offline
post #9 of 14 Old May 1st, 2007, 10:42 pm
gatorglenn's Avatar
Hey,
Where exactly are these rear reservoirs? My ABS lights flash but only once in a while so I am guessing that the level is close to full.
Glenn
gatorglenn is offline
post #10 of 14 Old May 2nd, 2007, 7:18 am
BLBantz's Avatar
The two are actually in one reservoir. Just under the seat on the right side of the bike tucked under side panel. If you don't look carefully you will only see one reservoir filler cap, but there is another behind it. Very hard to get to without taking off the plastic but if you remove a screw or two and carefully pry the plastic out, you can get to the caps. Use a syringe to fill them. My lights were like yours only flashing occasionally and just a few drops fixed the problem.
Brian
Fanwood, NJ
BLBantz is offline
post #11 of 14 Old Jun 12th, 2007, 10:26 pm
bluebeam's Avatar
second reservior
I have owned my 06 for 2 months and was really not wanting to buy a repair book or CD till I had to, well I think its time.....so where is this second reservior at?? I can get to the one on the right side the one that you check the level from the right bag.
bluebeam is offline
post #12 of 14 Old Jun 16th, 2007, 4:04 pm
pozo_izquierdo's Avatar
There seems to be a confusion about the one or two brake fluid reservoirs in different model years.
I was also looking for the second (or dual ) reservoir from my ´05 but there is only one in mine and yours.
I learned this during my 60.000 km service as the tech showed the pictures:
the first LTs 99 - 01 (or 02) came with one reservoir
02 (or 03) -04 came with two (or dual) reservoir
05 onwards again with one reservoir
Now, don't ask me more specific questions on the detail differences but this has someting to do with the different ABS generations and integral or non-intergral brake systems of different model years.
BTW, I have the flashing ABS light syndrome as well. I topped the only rear reservoir, the bike was computer checked last Tuesday during the service and the only thing that was found in the log was "incorrect sensor distance" on the front wheel. When it was measured the gap was normal. When I rode away from the service the warning light was away fro two days until started again.
Bike has not been soaked, nothing abnormal has happened etc.
What is going on?
Regards
Hyvinkää, Finland
pozo_izquierdo is offline
post #13 of 14 Old Jun 16th, 2007, 9:21 pm
This is for the 05 and up Integral ABS system.
The ABS monitored reservoirs for the wheel circuits are ON the ABS unit itself. The single reservoir back by the pannier is for the rear control circuit (it is not monitored). The wheel circuit reservoirs are accessible by removing the left side battery cover and are accessed for filling by removing the vent caps with an 8 mm hex wrench. The one for the front circuit is the tall one while the rear is the short one.
post #14 of 14 Old Jun 17th, 2007, 5:03 pm
was
was's Avatar
What is going on?
Regards
Hi Ari, I'm guessing that your dealer wiped the fault code after checking the sensor gap, so you had two days of flash-free riding. Since the system threw the fault code again, I'm guessing (in order of increasing expense, but not necessarily ease of diagnosis) a fault in the wiring (poor ground or broken/cut insulation, that sort of thing, but it only shows up intermittently); faulty sensor; or flakey ABS computer. Let us know what you find, ABS warning lights seem to be increasingly common. Thanks and good luck.
Bill
Guilford, CT
'99 Canyon Red K1200 LT - Buddah Bike
was is offline
ABS Warning Lights and Radio Indicator JeffB K1200LT 16 Oct 28th, 2011 8:59 am
Hella FF50 Driving Lights installed unleashd Lighting 22 Aug 21st, 2006 2:11 pm
Them flashing ABS lights SilverBuffalo Chit Chat 4 May 14th, 2006 6:52 pm
Help with ABS lights RonBilbo K1200LT 8 May 9th, 2006 3:08 pm
