another low beam problem/question - BMW Luxury Touring Community
post #1 of 11 Old Apr 23rd, 2007, 8:16 pm Thread Starter
gr8fulfred's Avatar
The low beam on my '99 LT quit this morning at 5:30 (fortunately in the garage before I left) and I believe it is the original - 60K miles. The previous owner of the LT had installed a headlight modulator, not my favorite accessory, but I live with it, mostly off. Anyway, before I send off for HID, I replaced the bulb today with the standard BMW replacement, but it doesn't work either, and the original bulb appears to be OK. I tried to bypass the modulator and plug it in as it was originally intended, but still no light on low. The high beam still works but no longer modulates. Any thoughts on where I should look next?
Fred Jewell
No longer president, River City Beemers
2009 R1200RT - Silver
BMWMOA #123779
BMWRA #38714
IBA #24559
"Shadowboxing the apocalypse, wandering the land"
gr8fulfred is offline
post #2 of 11 Old Apr 23rd, 2007, 9:51 pm
tbarstow's Avatar
Do you still have the old bulb? If so, is it actually burned out?
I'd start by checking the fuses. Your manual should tell you which one is for the headlight.
Tim Barstow
2004 GSA Silver
2007 X Challenge
tbarstow is offline
post #3 of 11 Old Apr 23rd, 2007, 10:01 pm Thread Starter
gr8fulfred's Avatar
old bulb did not look burned out, I gave the fuses a quick look and did not see one that looked bad. Is there a separate fuse for high and low?
Fred Jewell
BMWMOA #123779
BMWRA #38714
IBA #24559
post #4 of 11 Old Apr 23rd, 2007, 10:06 pm
zippy_gg's Avatar
Question
Just a thought... How did you check the modulator? Was that in your garage, where perhaps the light sensor "thought" it was no longer daylight and it should no longer modulate? (i.e. too dark)
In the stock headlight the ground is common to both high and low beams, but I am not certain if this is still true with a modulator in place. Is it possible to bypass the modulator altogether and see what works and what doesn't?
I agree with your concern that if the low beam does not work now, it won't work with HID either until you resolve the issue.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #5 of 11 Old Apr 23rd, 2007, 10:12 pm Thread Starter
gr8fulfred's Avatar
When I checked the high beam it was still light out, my garage faces west and the sun was shining in it, so it should have modulated but did not. I did try to bypass the modulator and still got no low beam, so now I'm thinking maybe a fuse?
Fred Jewell
BMWMOA #123779
BMWRA #38714
IBA #24559
post #6 of 11 Old Apr 23rd, 2007, 10:21 pm
zippy_gg's Avatar
Definitely not a fuse.
Have you tried connecting a voltmeter at the lead end by the bulb? If there is voltage then your issue just may be a bulb, or a bad ground.
If there is no voltage then you may have a loose or cut wire feeding the low beam.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #7 of 11 Old Apr 23rd, 2007, 10:25 pm Thread Starter
gr8fulfred's Avatar
Thanks. I'll dig out my voltmeter and try that.
Fred Jewell
BMWMOA #123779
BMWRA #38714
IBA #24559
post #8 of 11 Old Apr 23rd, 2007, 11:18 pm
My guess would be a corroded connection at (or near) the bulb socket. You will probably find that the wire is brittle for about 3/4 of an inch before the connection so some splicing will be required.
jorawro is offline
post #9 of 11 Old Apr 24th, 2007, 7:04 pm Thread Starter
gr8fulfred's Avatar
Being the highly intelligent person I am, always sharp and aware of all things going on around me, I finally realized the parts sales clerk sold me the high beam instead of the low, and I have believed it to be the low beam all this time. So, I kept installing and removing it, checking all the connections, swearing like a drunk sailor at the bike, threatining to trade her in on a Gold Wing, etc., and not until I had removed it for about the 20th time did I realize that the high beam bulb was now no longer in the headlight and was instead in my hand. Back to A&S tomorrow to vent my wrath on the unsuspecting parts counter clerk (and don't you warn him Ted) and get the correct bulb. This time I can easily see that the old bulb is indeed bad and I am sure the problem will be corrected with a new one. The one good thing in all this, aside from advice from the great people on this forum, is that I removed the headlight modulator. I never really liked it anyway. So, thanks again for all the help, but I thought you might like to know it was operator error all along.
Fred Jewell
BMWMOA #123779
BMWRA #38714
IBA #24559
post #10 of 11 Old Apr 24th, 2007, 7:16 pm
grifscoots's Avatar
FYI: the '99 doesn't have fuses for the headlights.
-=grif=-
Grok
grifscoots is offline
post #11 of 11 Old Apr 26th, 2007, 6:03 am
THE Democracy Doctor
jayjacobson's Avatar
Being the highly intelligent person I am, always sharp and aware of all things going on around me........
Fred, don't even sweat it. Once, my own shadow even snuck up on me! AND I hadn't even had so much as one of those ICE COLD Guinness's yet!!
jayjacobson is offline
HI LO HID Installation on 99 K1200LT With Pics ! JPSpen Lighting 37 Jul 12th, 2008 11:44 pm
HID High Beam on '99 LT dlbushey Lighting 4 Jan 24th, 2007 9:56 pm
HID High Beam on '99 LT dlbushey Lighting 2 Jan 23rd, 2007 1:58 pm
Negative experience with high-wattage low beam paulcbrowne Lighting 4 Nov 15th, 2005 2:01 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 8:36 pm
