Need help debugging radio issue - BMW Luxury Touring Community
post #1 of 7 Old Apr 20th, 2007, 10:16 am Thread Starter
hd2bmw's Avatar
I have experience this problem on my 2005 LT
The dealer has seen it and does not have a clue at this point what is causing it and is contacting BMW.
In the meantime I figured I would try some troubleshooting myself.
The problem appears after the bike get wet either by washing it or riding in the rain
1) The radio appears to be off as indicated on the LCD display.
2) Though I can hear it playing at a very low volume.
3) I have no idea what station since there is no indication of what is playing.
4) There is no control over the radio at all, no ability to change a station or playing CD or changed volume, no control at all.
5) Except you can use the on button to turn if off as note in item 2. But keep in mind there is no indication of the radio being on.
6) Other strange indication is that the stand down indicating icon is on and states that the one of the stands are in the down position.
7) The Bike starts without any problem
8) Placing it in gear even though the indication the stand is down will not cause the bike to turn off.
9) The power center stand will no work with the bike running. If i shut the engine off then the power center stand works
Sounds a ground issue but not sure. Everything else works fine
jim
PS Also if some one could get my a copy of wiring diagram or direct me to a useful one it would be appreciated
Jim Connor
Afraid of what!
hd2bmw is offline
post #2 of 7 Old Apr 20th, 2007, 10:26 am
Howdy, Jim.. haven't heard from you in a while..
Let's see.. have you tried removing all power from the bike by disco of the battery for, say, a couple minutes (30 seconds usually sufficient)... then reapply power.
As for the HCS, what about your lights? Deputy5211 had a problem when he put LED's on the bike.. HCS quit working!!!!
J.M.J...
Dcn Channing
post #3 of 7 Old Apr 20th, 2007, 10:29 am Thread Starter
hd2bmw's Avatar
Re
yes I have done the Battery
I do have LED but this has been happening for awhile
And yes it has been awhile
How was your Triduum ...
Jim Connor
Afraid of what!
hd2bmw is offline
post #4 of 7 Old Apr 20th, 2007, 10:30 am
It was beautiful, thanks be to God! I hope yours was, too!
Sent you a PM..
J.M.J...
Dcn Channing
post #5 of 7 Old Apr 20th, 2007, 10:43 am
Long ago, 2001 to be exact, I experienced a very similar problem on my '99 and it turned out to be a defective ignition switch. Replaced the switch and all has been well since.
YMMV
Jeff in Myrtle Beach
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
jeffklt is offline
post #6 of 7 Old May 2nd, 2007, 3:26 pm Thread Starter
hd2bmw's Avatar
Found the problem
It turns out that is was my icelink system caused the issue and it only occurred when the iPod was not installed.
Jim Connor
Afraid of what!
hd2bmw is offline
post #7 of 7 Old May 2nd, 2007, 6:28 pm
Jim,
Thanks for posting the solution. That was a rather unusual problem. The Ice Link has caused quite a bit of grief on the LT over the years while others have had good luck with it. Must be related to SW versions.
Radio just quit atps1234 K1200LT 62 May 29th, 2017 10:43 pm
Weird electrical problem with Radio hd2bmw K1200LT 6 Jul 7th, 2010 7:10 pm
Radio Question...Searched Hall of Wisdom hybridcage K1200LT 7 Dec 4th, 2006 1:32 pm
