Now Mine Is Shaking/Front End Shimmy - BMW Luxury Touring Community
post #1 of 17 Old Apr 11th, 2007, 12:17 pm Thread Starter
Unhappy Now Mine Is Shaking/Front End Shimmy
Fellow Riders, I have a 05 K1200LT which I just took in for new tires my old ME880'S took me 16.000 miles and could have went another 1.500 or so. But I decided to get new shoes before the dealer gets over loaded with work and would not be able to install new tires for weeks on my bike. Or I lost it in heavy rain in a corner or the dreaded flat. The bike rode well on the worn tires the weekend before over 450 miles my first long ride this spring. After getting new tires I was downshifting from 5th to 4th and the thing shook me good at 45 or so,pulled over and scratched my head wondering if I hit something or if the pavement was rough this was not the case. I got back on her got up to speed down shifted again from 5th to 4th it did It again. Back to the shop I went and left the bike with them ,they called me back to tell me my rims were out of true. I could not accept that as the problem even if it was so for it rode fine for over 450 miles on worn tires and new ones made it worse? Well I'm a poor working stiff like most of you and buying new rims at 1.300 is not a reasonable option to me. They rebalanced the tires and it helped a little and sort of checked the steering stabilizer but the verdict is still out on the problem. Words of wisdom would be appreciated about what to do because I don't believe I need new rims the slight truing problem was there before and was not bad enough to cause a shimmy before, Is this a reasonable conclusion?Thanks
Shaftywon is offline
post #2 of 17 Old Apr 11th, 2007, 1:57 pm
First Off please fill in your profile as it helps to know who we are helping. Second, you can block up the front wheel and spin it your self and place an object close to the tire to check for out of round. Then hold something close to the edge of the rim and check it as well. I think you will find the TIRE is out of round. I had one I installed myself and it gave the same shake on decceleration through 45. The new tire was out of round slightly (maybe a 1/16 of an inch). I went a head and wore it out and the next ME880 I put on was true and the shake is now gone.
So get a second opinion, another bike shop or dealer or have this one show you that the tire is true and your rim is out of round (very unlikely).
Good Luck
post #3 of 17 Old Apr 11th, 2007, 2:49 pm
fas
fas's Avatar
shake
What tire did they mount? Some times the tire is just flat not balanceable.
Rob Nelson
Grey Goose
Toscana Temptress
fas is offline
post #4 of 17 Old Apr 11th, 2007, 4:52 pm
dano0827's Avatar
i could be wrong, but it may also be a broken belt in the tire, i would ask to see if you can get another tire. that is unacceptable
dano0827 is offline
post #5 of 17 Old Apr 11th, 2007, 5:00 pm
Old tires no shake, new tires shake. Bad tire or they bent the rim mounting the tire.
Big_E is offline
post #6 of 17 Old Apr 11th, 2007, 5:08 pm
mwnahas's Avatar
I agree bad tire or bad mounting job.
I only got the shake at 40-45 mph when I had worn tires.
Just Go
Cleveland Ohio
mwnahas is offline
post #7 of 17 Old Apr 11th, 2007, 6:03 pm
motorman587's Avatar
Had two LTs in the past.
Both did the same thing, but always with different tires. Which tires you ask?? Have no I idea. With fresh tires the wobble did not happen so I can only guess that it is a tire problem. I am about to put new rubber on the LT and can tell you now that I have Bridgestone, "wobble" at low speed and putting on Mets, that I had before no "wobble". I would say this normal with the LT and it gets better with age.
motorman587 is offline
post #8 of 17 Old Apr 12th, 2007, 9:32 am
Check back tire air pressure
This is probably way out in left field, but I had a problem with very low speed front end wobble. Lots of diagnosis, but the bottom line was, LOW BACK TIRE PRESSURE. Can't believe it was that simple, but it was down about 20 pounds. Raised the pressure to 48 and all problems went away. Not one tech caught the problem.
post #9 of 17 Old Apr 12th, 2007, 9:35 am
Bike rode fine.. tires replaced... rim bent... they owe you new ones.
J.M.J...
Dcn Channing
post #10 of 17 Old Apr 12th, 2007, 11:06 am Thread Starter
Front End Shimmy Advice
Thanks to all who responded to my situation. I have past the input on to my Dealership and they are considering every option suggested and are working with me on the issue. The owner said he does not think my rims are the problem but the new tires either the rear or the front the rear being his first choice.
post #11 of 17 Old Apr 12th, 2007, 4:03 pm
PATTERSON's Avatar
My bike started out with Dunlop 020's......had the front end wobble.....changed to Metzler 880's......still had the wobble.......dealer changed out the lower steering yoke.......still wobbled....installed 205's......no more wobble.
Good Luck........
Pat
Patterson/USAF1....'05 LT
and the little guy behind me is the world famous "Marty Hill"
Never look into a lazer with the remaining eye
363K on BMW's
PATTERSON is offline
post #12 of 17 Old Apr 12th, 2007, 6:16 pm
mconlogue's Avatar
Just had 2 new tires mounted. drove 1/4 mile, and had a wicked wobble. I turned around, and returned to the dealership. Told them to replace and "really" balance the front tire this time.
I marked the mounted tire as bad, so I would ensure it was changed. new tire, and a good balance job, no problem.
Mark Conlogue
MCSE, MCT
CEH (Certified Ethical Hacker)
CBCP
I take Life with a grain of salt......and a slice of lime and a shot of Tequila
20 grand & 2K miles don't make you a biker
I COULD TELL THEY WERE BIKERS,
IT SAID "LIVE TO RIDE" ON THEIR TRAILER
mconlogue is offline
post #13 of 17 Old Apr 12th, 2007, 6:21 pm
glenhinegardner's Avatar
hey Patterson
when you say 205's do you mean the Dunlop 205s?
This is the first I have read of anyone using 205's?
Glen
glenhinegardner is offline
post #14 of 17 Old Apr 13th, 2007, 2:23 pm
PATTERSON's Avatar
Originally Posted by glenhinegardner
hey Patterson
Glen
Hi Glen..............Yep (had to go peek at them just now to make sure) they're Dunlop 205F (front....120/70 B17) and 205D (rear .....160/70 B17). They do sit noticeably taller than either of the 2 previous tires.....on the centerstand, I may have1/4 inch under the rear wheel.
Pat
363K on BMW's
post #15 of 17 Old Apr 13th, 2007, 9:36 pm
Can you give us (tire watchers) more info on this tire? Cost?, and how do you like them? are they rated for the weight of the LT? how many miles you getting?
Glen
post #16 of 17 Old Apr 13th, 2007, 9:52 pm
OK i'm sure i'll make alot of enemies here but here goes, the lt is a piece of shit. I've been riding since i'm 11 and have had many bikes. (i'm 45) I bought my bike from what i believe is the best dealer in the us. (Hermy's) he tried everything to get no just one but two lt's to not wobble. (my friend bought one the same time i did) He tried everything. More then i want to type. Bottom line my friend filed for lemon law and won, Hermy gave me a great deal on a 06 gt and i love it, no problems. the bike has a problem with its design. They all shake some feel it some don't but it will not go away. Sorry for the bad news. I almost bought a gold wing but didn't, but i did get to test ride it. It would wobble but would stop immediately. My friend bought a rt, I have a gt and i'm happy. I love BMW's i've had a gt, rt,lt and now a gt. I love bmw's but this bike just isn't right.
mikemoto is offline
post #17 of 17 Old Apr 14th, 2007, 9:38 pm
Shimmy in Front
I have experienced the same on my 2005 LT. at 40 MPH if you let go of the handle bars for just a second, it would scare you. The dealer replaced the tire, rebalanced, and ultimately replaced the wheel. It helped but still had a shimmy although slight.
At 12,000 miles, I replaced both tires and the shimmy is completely gone. I think the LT must require exceptional tires and a near perfect balance. I would return it and seek rebalance to start with,
Ron Mc
TXPipeliner is offline
K1200LT Front Wheel Shimmy ITDNMTR Bike Talk 13 Dec 9th, 2015 3:46 pm
Front Steering Shimmy cedkins K1200LT 21 Mar 27th, 2007 2:56 pm
Front and shake/ shimmy front, ... revisited andy K1200LT 12 Jan 12th, 2007 7:16 pm
Front end shimmy gregorysharp K1200LT 21 Oct 28th, 2006 10:43 am
Speaking of Trailer's , here is a peek at mine Patric K1200LT 1 Dec 22nd, 2005 9:48 pm
