Ignition Switch Freezing up - BMW Luxury Touring Community
post #1 of 5 Old Jan 17th, 2007, 8:14 pm Thread Starter
It has finally gotten cold in CT and my ignition switch is frozen in the AM so that I have to take the wifes hair dryer to it. Then when I get to work, the key is frozen and with not come out. It will turn off, just not remove.
Anyone run into the problem and solved it?
Brian & Audrey Long
El Cajon, CA
2005 LT Blue
2007 R1200GS ADV(traded)
2003 LT Brown (sold)
(2002 LT totaled by cage)
Ride Safe!!
bslong is offline
post #2 of 5 Old Jan 17th, 2007, 9:44 pm
cccpastorjack's Avatar
Try "LOCK DE-ICER"
I have never had this problem, but you can buy a small can of Lock-DeIcer from Autozone, NAPA, etc. I also have heard that graphite lock lube is good. It is dry so it doesn't freeze.
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #3 of 5 Old Jan 17th, 2007, 9:45 pm
You will have to wait until it thaws to remove the key. Once removed squirt a little graphite grease into the key hole and work it around a bit with the key. WD -40 will also work short term if you do not have the graphite.
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
post #4 of 5 Old Jan 18th, 2007, 10:09 am
As Jack and Brian said above you have to get rid of the moisture that appears to be thawing and refreezing. In the longer term that moisture will eventually corrode the wires at the bottom of the tumbler. It's happened to me, though not on an LT.
Tim Frederick
Woodbury, MN
fredthead is offline
post #5 of 5 Old Jan 18th, 2007, 5:47 pm Thread Starter
ignition freeze
Thanks for the info.
Brian & Audrey Long
El Cajon, CA
2005 LT Blue
Ride Safe!!
bslong is offline
Ignition switch problem BLBantz K1200LT 8 Jan 11th, 2014 2:44 pm
Euro Switch bruce13p K1200LT 5 Dec 18th, 2006 3:36 am
Need Help With PIAA 1100X with Auto Switch eharris Lighting 6 Jul 16th, 2006 1:13 am
radio control switch omurphy K1200LT 4 Nov 27th, 2005 8:14 am
Brake Light Switch jeffklt K1200LT 7 Nov 15th, 2005 2:24 pm
