2014-2017 Battery Replacements - BMW Luxury Touring Community
 1Likes
  • 1 Post By rc51tofuman
post #1 of 15 Old Dec 27th, 2019, 7:43 pm Thread Starter
rc51tofuman's Avatar
I have searched and really haven't found a definitive answer
2014-2017 RT /Liquid Cooled Wethead
Which aftermarket battery has the best Fitment besides OEM? Without modifying anything.
Thankyou in advance for Your replies
Sent from my SM-G973U using Tapatalk
rc51tofuman is offline
post #2 of 15 Old Dec 27th, 2019, 7:49 pm
Re: 2014-2017 Battery Replacements
You can find them here, they finally stock them.
www.batterymart.com
Sent from my SM-N960U1 using Tapatalk
nhonnguyen61 is offline
post #3 of 15 Old Dec 27th, 2019, 8:22 pm Thread Starter
www.batterymart.com
Thankyou......
These are pretty good? Will I get at least 2 years out of these batteries?
I have a 2017 RT and the battery is failing.
I have it on the BMW charger every night in the garage
post #4 of 15 Old Dec 27th, 2019, 8:27 pm
RC51TOFUMAN, I used to believe in trickle charge but I noticed it fail my batteries more then I don't use it so if I don't ride my16 rt often I would start it up once a week or two and let the cooling fan cycle few times before turn it off, don't forget to check your cable ends at the battery terminals especially on positive side it does come lose for some reason.
post #5 of 15 Old Dec 27th, 2019, 8:37 pm Thread Starter
Thanks....I will check it
post #6 of 15 Old Dec 28th, 2019, 9:27 am
PadG's Avatar
If you had searched this forum, then you hadn't searched properly! There was a thread on this not too long ago. Anyway, this is your best bet: https://www.walmart.com/ip/YUASA-GYZ...FREE/129243723 It's $101 now, but the last time that I looked it was just $83 through Walmart, like this one. So, Google the same battery and you might find one at lower price. The stock battery in your RT is most likely an Exide, and I am told that the stock battery for the GS/GSA is usually a Yuasa. This particular Yuasa model will deliver a little more power than the stock Exide.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #7 of 15 Old Dec 28th, 2019, 11:33 am Thread Starter
Thankyou
post #8 of 15 Old Dec 28th, 2019, 7:47 pm Thread Starter
I am leaning between these 2 batteries?
Anyone care to comment which one I should get ?
https://www.batteriesplus.com/produc.../cyla20chbsxta
https://www.batterymart.com/p-ytx14-...e-battery.html
thankyou in advance
post #9 of 15 Old Dec 30th, 2019, 1:04 am Thread Starter
I just installed this battery.* I can confirm the dimensions are Exactly the same as the OEM Exide battery
I paid $110 out the door
Here is a link
nhonnguyen61 likes this.
post #10 of 15 Old Jan 6th, 2020, 6:11 pm Thread Starter
Has anyone ever used an Odyssey PC535 in their 2014-2018 1200RT ??
post #11 of 15 Old Jan 8th, 2020, 9:41 pm
Hfjeff's Avatar
I have had great luck with Yuasa Batteries as PadG posted. Had them in bikes and snowmobiles and they last. I am on the stock battery in my 2016 and it is still doing well. I keep a Battery Tender Plus on it from Nov-Mar each winter.
2016 R1200RT
2011 Yamaha FJR (sold)
2016 Yamaha Super Tenere ES (sold)
2008 Yamaha Zuma (wife's ride but I maintain)
Hfjeff is offline
post #12 of 15 Old Jan 8th, 2020, 10:19 pm Thread Starter
My 2017 oem exide didn't last.
I had to get a replacement.
It's always on the bmw charger
post #13 of 15 Old Jan 9th, 2020, 8:31 am
PadG's Avatar
Must have been a bad battery (or charger)! My bike is always on the CPU type maintenance charger (I use BatteryDoc) as soon as it is parked in the garage. Plugged in via the acc. socket on the RT, and doesn't get unplugged until when I am ready for the next ride. Never had a battery failure. The Exide on my prior '07 RT was replaced preemptively, after almost 6 years, and the one on my '15 was also replaced preemptively, after almost 5 years with the Yuasa thatI had posted earlier. The OEM battery could have lasted a lot longer, judging from how the RT starts before I replaced the battery, as compared to starting later with the replacement Yuasa. Very easy for me to compare, since I always ride with my helmetcam on, and it is always turned on before I start the bike.
Funnily enough, the reason for both of my preemptively replacements in both cases was because I had stumbled on battery at the "right" price! The Yuasa had cost me just $87.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #14 of 15 Old Jan 9th, 2020, 9:33 am Thread Starter
Interesting
You have good luck.
I think other people have only gotten 2 years out of their oem batteries
post #15 of 15 Old Jan 9th, 2020, 9:43 am
PadG's Avatar
Interesting
You have good luck.
I don't know where you get your data from, but I am very sure that you are not correct!!!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
