Lift Overhaul - BMW Luxury Touring Community
 4Likes
  • 4 Post By jzeiler
post #1 of 4 Old Feb 25th, 2018, 3:25 pm Thread Starter
Lift Overhaul
I probably have one of the oldest Handy electric lifts. In fact the model that replaced mine has now been discontinued. I got a good deal on it and it works just fine but it had an aggravating electro-mechanical control. It was a rod that you had to slide past a pin to go from up to down and it was a cable running back to a lever that threw a toggle switch! It was very hard to actuate the damn thing and it was fixed up under the front right side of the lift.
I opened it up and looked at how the switch was set up and designed a circuit with two DPDT relays to replace the function of the switch. I added two micro switches to act as limit switches as the original design had a rod that was coupled to the same lever that threw the toggle switch. I hard wired a 12 VDC wall wart to provide the control voltage and mounted the switches in a little junction box.
Anyway about $80 worth of relays, sockets, push buttons and robbing some of my parts bins and now I have a very nice remote control dongle that attaches with a magnet. Took the better part of the weekend to put it all together but now the lift is much nicer to operate.
ID:	139826   Click image for larger version
ID:	139834   Click image for larger version
ID:	139850   Click image for larger version
ID:	139858   Click image for larger version
ID:	139874   Click image for larger version
post #2 of 4 Old Feb 25th, 2018, 3:33 pm
bmwcoolk1200's Avatar
Re: Lift Overhaul
Nicely done!
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 4 Old Feb 25th, 2018, 6:27 pm
Patric's Avatar
Re: Lift Overhaul
Nice!,
That brings back some memorys.... I use to help a friend a little at his BMW repair shop in the early '80s. He had two Handy lifts, one electric and one air. I used the electric one to change tires on. Tie the front end down at the wheel clamp, then he had two pipe/brackets that went into some holes in the top of the lift. Then you put a piece of 2x4 across the brackets. The 2x4 was under the center stand ( as I remember) . Then let the bike down a little the 2x4 held the back of the bike up then I could get the rear tire off.. turn the bike around to do the front..
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #4 of 4 Old Feb 25th, 2018, 11:13 pm
beech's Avatar
Re: Lift Overhaul
Wait a second, I thought all those old airheads balanced on the center stand. Take one wheel off it rocked to balance on the opposite wheel. What I used to do anyway.
Anyway, good save on the Handy lift. I once called them for a part, I wanted their hydraulic pump. Would not sell me one for my Italian lift. So I bought an air/hydraulic pump from Harbor Freight. Works well after I put some proper size O-rings in the thing. But having a lift is a great asset in the shop. Go for it if you can.
Beech
I change your tires $40, you buy them on the web.
beech is offline
Help to Get LT on New HFT MC Lift NVRider Other Stuff 10 Jun 15th, 2016 9:33 am
Motorcycle Lift & Safety Tips hschisler Chit Chat 18 Apr 9th, 2012 9:25 pm
Bike Lift versus Lift Table . . . dfinazzo Bike Talk 20 Aug 12th, 2009 5:00 am
New Lift in the Garage! hschisler Chit Chat 19 Oct 17th, 2008 9:15 pm
Big Blue Bike Lift grahamw K1200LT 1 Jul 7th, 2007 9:01 pm
