"Borrowed Post" DIN adaptors to USB - BMW Luxury Touring Community
post #1 of 1 Old Apr 30th, 2016, 9:31 am Thread Starter
PMitchell's Avatar
Since I have a K75 as well an an LT, I review the posts on K75's in Yahoo Groups.
Thought this might be interesting to all as well a gobs of good information on the website below . . .
'Robert Fleischer dba Fleischer's Service' [email protected]
I have finished my extensive testing of 4 versions of DIN adaptors to USB connectors; same for wired versions.
Not easy to find good reliable ones.
Here is my report on the testing, abbreviated (I tested for temperature, output, regulation, and some other things):
DIN PLUG (or WIRES) TO USB POWER ADAPTORS: These are difficult to find. Various versions are available from ONLY ONE company, AFAIK, that are RELIABLE....and well-made. All connect to your bike's electrical system, either to the battery, or to the system after the ignition switch, or simply plug into the DIN jack on your bike. These adaptors I recommend are NOT cheap cigarette lighter socket plugs but quality Hella-DIN types, that grip well too. All have 5 volt USB type outputs. Single and dual versions, either with 2.1 or 3.3 ampere ratings for output.
NOTE! These items have a tiny current drain when plugged-into your bike. Thus, if you intend to leave them connected all the time, I suggest you wire them into the bike so power is ON to the adaptor only when the ignition switch is ON. I have thoroughly tested a number of these. Both 3.3 ampere and 2.1 ampere versions have a no-load drain of about 0.006 to 0.007 ampere. The standard 5 volt USB output is solid, well-regulated, and was tested between 11 and 15 volts input at the DIN plug.
BurnsMoto.com seems to be the only source I found in the USA.
Product is made in Taiwan.
Cliff-top.co is the maker, and has some models that are not seemingly available in the USA, but BurnsMoto has what you likely need.
snowbum
pm
Ride till you can't!
"Der Weg ist das Ziel"
2011 South Africa
2016 Spain & Portugal
'18 R1200RTW
Sold in '67
PMitchell is online now
"NEW POST" FUNCTION STILL NOT WORKING WITH PHONE Lynn_Keen BMWLT Site Support Forum 7 Feb 3rd, 2014 2:13 pm
CQ bulb replacement needs adaptors. mkiesel Lighting 1 Jul 30th, 2008 11:39 am
I got a "you need to post" note. CajunBass K1200LT 7 Dec 5th, 2007 10:26 pm
