Long, but interesting: Lane splitting - BMW Luxury Touring Community
post #1 of 13 Old Sep 14th, 2006, 1:01 am Thread Starter
vvk
vvk's Avatar
Post Long, but interesting: Lane splitting
Is what I do every day in our rush hour clogged little country.
I get a carpenters eye for wriggling through, 108CM mirrors wide.
Here's an consice article on lane splitting.
Lane Splitting: A Guide to the Game
by Richard D. Grazia
Lane splitting, like baseball, is a game of inches. In baseball, judging small distances accurately wins games. In motorcycling, it gets you home early and in one piece.
For five years, I have been commuting from Berkeley to San Francisco and back every day, 15 miles along the I-80 corridor and across the Bay Bridge. Often, I lane-split the whole distance, saving about an hour a day in travel time. The tips in this article result from that experience.
If you can ride on freeways fairly comfortably but haven't lane-split yet, practice judging the distance between two stationary objects wider than your motorcycle, then find the midpoint of that distance. That mid-point is where you'll want to be in any lane-split or passing move.
While lane-splitting, you are measuring distances, acting and reacting to your observations. The situation is fluid and changes take place in tenths of seconds or less. When traffic stops, the situation goes static. You become the only dynamic player.
Moving through stopped or slowly moving traffic is actually a combination of lane- splitting and lane-changing. The gap is where you find it; how you use it and avoid contact is the challenge.
Getting Started
Make sure your bike is in tune, has good brakes and good rubber.
Without cars around you, practice riding on lane buttons. Take a firm grip on your handlebars. Riding on the buttons will shake your bike, but it won't tip you over. Get used to the feeling; you'll be riding on the buttons occasionally while you're between cars.
To pass one car in slowly-moving traffic on the freeway, place yourself behind a car that has plenty of space in front of it. (Cars should be running parallel to your chosen car.) Line up to the right or left side (whichever affords the most space) of your chosen car. Make sure you're in a low enough gear to provide adequate roll-on power. Check your mirrors, then look up your route. If it's clear, give it the gas. Pass the car and pull into the forward space. You have just lane-split. When you're comfortable with the one-car pass, up the ante to two cars, then three and so on.
Seeing
Lane-splitting is essentially a hand-eye coordination activity. The operative term here is "eye." If you don't see what's happening around you, you'll never make the right move.
Keep your eyes moving: check the situation way up ahead. Read the intention of the vehicles near you; check your mirrors. Don't stare. At 30 mph, you are traveling at 44 feet per second. At that speed, you travel 4.4 feet in a tenth of a second.
Techniques
Cover the front brake lever with two fingers. If you have to stop, you'll be able to save a bit of reaction time, which translates into distance. Stopping even one inch away from an obstruction is good.
Relax your arms by bending them slightly at the elbows. Remember to breathe. If you become tired, stop lane-splitting for awhile.
Check your mirrors before starting any lane-splitting move. A fellow lane-splitter, closing quickly from behind as you enter the gap, could spoil your whole day. l also periodically check my mirrors while lane-splitting. If I see another lane-splitter coming up behind me, I can decide whether to pull over or speed up.
Control direction and speed with smooth micro-inputs, knees to tank, hands countersteering, hand to throttle. You don't have room for big maneuvers.
When the gap narrows and your move isn't going to work, slow down, drop back into a lane, or stop between lanes if you have to. Yo! stay cool.(Vic)
Make sure your mirrors and bar-ends will clear van, truck and car mirrors. It's not a major deal when they connect, usually just a loud clacking noise, but it is embarrassing. Other drivers may not like you just for lane-splitting, but tapping their mirrors out of adjustment makes it worse.
Be patient at merges. Other drivers often change lanes here, trying to gain some advantage. That's their illusion. Wait until they settle down. You are the only one who can really take advantage of the traffic situation.
Be wary of solo drivers who use car pool lanes to get ahead of the traffic jam in the non- car pool lanes. At the last minute, they will try to enter the jam; if you are about to make a pass at that point, the results will not be amusing.
When other vehicles, whether signaling or not, start a lane-change maneuver, don't accelerate in an attempt to get past them. Give them the right of way.
Be aware of empty spaces to the side of the car that you intend to lane-split past. Try to go by before the driver is aware of you. Failing that, if the car tries to move over while you're on the side of his car, match the car's move if you have the space. Your other option is again to be patient for a bit. The relationships will change, the car's place will be taken by another vehicle, and you can lane-split the two safely.
Passing another motorcycle which appears to be staying in a lane presents an interesting problem: It's as hard to tell if the rider knows you're there as it is to judge a car driver's awareness of your presence. The motorcyclist has your flickability, however. If you fell certain that the rider is holding steady in a lane, zap past. If you're uneasy about the motorcyclist's intentions, lane-change away and go about your business.
Most drivers place their vehicle near the left side of their lane. They are sighting on the lane divider nearest to them. In most instances, your position should be on the right side of the lane. This will give you the most maneuvering room.
In order to pass between sets of lane buttons without riding over them, sight on the last button of the front set and quickly make your move. Usually, you'll pass smoothly through, or at worst ride over the last button. Whatever you do, don't get hung up on not riding over the buttons. Not hitting or being hit by other vehicles is what's happening.
Speed
The great race car driver Juan Fangio once said, "I drive just fast enough to win." You probably shouldn't ride between vehicles at more than 10 to 15 mph faster than they are traveling. If they're stopped, they are traveling 0 mph.
Cops
Even though lane-splitting is legal in some states, whether you'll get pulled over by the police is dependent on whether or not they feel what you are doing is safe. The catch, of course, is that each patrolman has a different criteria for what constitutes "safe." Ride in a manner which you feel is safe for you. If you get ticketed, plead not guilty and take it to a jury. The ticket is a judgment call. Obviously, you are in the right or you wouldn't have been lane-splitting. Was it safe? Hell, yes! The fact that you're standing in court with all your limbs intact is proof of that. At any rate, keep an eye out for the cops just in case.
Observations
Being aware of the lethal danger you're in and simultaneously ignoring it is a requirement of lane-splitting. This ability is composed of experience, guts and self confidence.
Lane-splitting is as much fun and as challenging as a mile of technical enduro landscape or miles of canyon carving.
The flow of freeway traffic is like a river. Learn to read every ripple and snag in the pattern.
The whole freeway is your playing field. The gap between vehicles is where the game is played.
On a motorcycle, you are in another space- time continuum from other vehicles. No wonder they don't see you.
When you are all going the same speed - cars, trucks and motorcycles - holding position, you are motionless, relative to one another. When you accelerate slightly, the pattern changes, but only at a difference of several miles per hour. (All vehicles are moving at 65 mph., you accelerate to 67 mph. The situation changes at 2 mph.) Moves take place in relative slow motion.
The experienced eye can judge the mid- point of variably changing distances. Rear bumper to front fender of surrounding vehicles. It is a solvable three-body problem.
You will see other motorcyclists lane- splitting. It is a temptation to see who can go the fastest. Deal with the temptation as you see fit.
Henceforth, all car drivers will be known as "Civilians." However, when we drive cars, we will be known as motorcyclists.
Be in tune with your machine; the way it smells, the sounds it makes, the shadow it casts when you ride.
Graduation Day
You have just lane-split all the way home in the rain, in the dark, at rush-hour on Friday night. You've had a great rideSooner or later, it hits even the best rider -- the sudden realization that your approach speed is much too fast for the corner rapidly filling your faceshield. It doesn't matter if you're a commuter cruising home from work or a racer who just suffered a lapse of attention at speed; riding out of this mess gracefully demands attention, skill and mental preparedness. Let's take the problem a stage at a time.
Decide to make it:
Your first emotion should be a firm determination to "ride through the corner". You have to stay mentally strong and supress any doubts, which can quickly explode into panic, and can overwhelm your ability to take charge of the situation. Too often a rider panics and locks the rear brake, losing his ability to control the situation. He then slides off a corner that he could have made if he simply had been resolved to do so.
Some riders simply freeze, and never make any control inputs at all. It's more comon for a rider to crash when he panics entering a corner that he could have completed than it is for a rider to fall trying to corner too hard. Learn to relax and maintain your body position and motorcycle control in these high-pressure circumstances.
Lead with your eyes:
You go where you look, so LOOK UP THE ROAD AND THROUGH THE CORNER where you want to go. Don't let you eyes begin searching for a place to crash. Part of overcoming panic is wrenching your eyes away from the ditch or railing or even the open field looming ahead and putting them where you want to turn. It's also the first step in actually turning that way.
Brake deep, lean hard:
If there's ever a moment when your braking practice pays off, it's now. As long as you have some significant pavement ahead, there is room to brake. The slower you go, the tighter an arc you can ride through the corner. Of course, the closer you come to the edge of the lane, the tighter an arc you NEED to stay there. Given sufficient room and hard enough braking, at some point your speed drops below the point at wich you can safely lean it over and drive through the corner. That speed is probably higher than you realize, however, unless you have spent some time on a racetrack exploring the outer edges of your bike's performance abilities. The only way you will learn how much your bike has left and how to use it fully is to practice. Learn from this experience:
A close call should reinforce your confidence if you handle it successfully, reminding you that you have a reserve to tap. It should also remind you of your limitations. In other words, either know your road, or slow down.
Miles of smiles of miles of smiles of...
The hardest thing to do on a K1200LT is riding it home.
Vic
Booze Brother #1
Gandalf Grau
The Netherlands
vvk is offline
post #2 of 13 Old Sep 14th, 2006, 2:06 am
Thumbs up
Great read...thanks for posting!
I live in a state that doesn't allow this, but I'm all for it.
post #3 of 13 Old May 31st, 2007, 11:30 pm
omurphy's Avatar
think about this
this is interesting.
omurphy is offline
post #4 of 13 Old Jun 1st, 2007, 12:14 am
hallzee's Avatar
Dedicated lane splitter here. The less my bike is simply idled by congested cagers, is the less I am contributing to greenhouse gasses...
My wife hates it when she's on the bike though, but not really a problem, because we don't usually commute together. Also, lane splitting a 2-up fully loaded LT can be a real challenge.
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #5 of 13 Old Jun 1st, 2007, 6:29 am
THE Democracy Doctor
jayjacobson's Avatar
Originally Posted by vvk
For five years, I have been commuting from Berkeley to San Francisco and back every day, 15 miles along the I-80 corridor and across the Bay Bridge. Often, I lane-split the whole distance, saving about an hour a day in travel time....
Yup, 15 miles along that corridor will make you an expert in no time!
jayjacobson is offline
post #6 of 13 Old Jun 1st, 2007, 10:36 am
Since my last post, I experienced lane-splitting . . . A LOT! While in CA, I lane-split at every opportunity, and then some. Now I can state with all confidence that it is safe, as long as the rider is skilled enough. I was actually amazed at how many riders I passed while lane-splitting. Makes me wonder if they should be on a bike at all. Then again, they know themselves better than I do. Perhaps NOT lane-splitting is the best place for them. Well...maybe inside a Volvo wagon is truly "the best place" for them.
post #7 of 13 Old Jun 1st, 2007, 12:10 pm
grifscoots's Avatar
I loved it myself and it makes so much sense is the reason the rest of the U.S. doesn't allow it.
I also think it would be kewl to go to the head of line at construction stops.
-=grif=-
Grok
grifscoots is offline
post #8 of 13 Old Jun 1st, 2007, 1:26 pm
I'm gettin ready to do about 65 miles of that myself here shortly today, the first leg of a 400 mile weekly commute on home from my worksite from socal.
I get passed by other bikers at times. I'm either riding my K1200S or my Yamaha FZ1 (which I have today), but I don't lane split on the beastly LTC, I like my mirrors right where they are
I'm not in that much of a hurry, I just like and need to keep moving, especially in this heat. Sure, I'd like to make a game of it and mad-dash, but thats not a prudent thing to do.
I swear I can hear driver's yelping "damn bikers!" everytime I pass or scare em.
So....in the tradition of (well, time proven at least) cager lingo aimed at biker's I got a very nice black license plate frame for my S, engraved, that says "DAMN BIKERS!"......I figure it'll keep the cager's entertained enuff for me until I swing on by
ya'll beecool out there...geo
ldbikin is offline
post #9 of 13 Old Jun 1st, 2007, 2:19 pm
lane splitting
I spend about a week every month in SoCal and split lanes and filter on surface streets all the time. Filtering is riding between the lanes up to the front at stoplights. It is legal in California and most drivers will even move a bit for you.
Some points to add to an excellent article: You should have the front brake covered and your left hand on the horn/brights switch all the time. Use all your lights in the daytime. Stay off the cell, radio and your mind should be fully focused as if you were on a track or dirt bike course. On a larger bike when possible, fold your mirrors in. Most drivers will move over and let you by, don't take it personal if they purposely close the gap. Never get mad and kick somone's car door or flip them off.....you have no idea what kind of mood they are in and weapons they may have. Enjoy the game...lane splitting is proof that God loves motorcyclists....(at least in Califronia and most of the rest of the world)
Ron
byke33 is offline
post #10 of 13 Old Jun 1st, 2007, 4:47 pm
ConspiracyofOne's Avatar
I split every day on my LT. Yeah, it took a little getting used to (not as narrow as my Superhawk was) but it's not too bad. Really keeps you on your toes. I have found that my modulator helps clear the way!!!
Ray
Raymond Dell'Olio
Bronx, NY
718-530-5793
2000 K1200LT (Sold)
"A nation of sheep,
Owned by pigs,
Ruled by wolves."
ConspiracyofOne is offline
post #11 of 13 Old Jun 2nd, 2007, 6:23 am
Originally Posted by messenger13
-------------I was actually amazed at how many riders I passed while lane-splitting. --------------
Where? In 5 years of daily lane splitting in Southern California, I rarely saw a motorcycle that was not lane splitting, and those were usually out of state riders not quite ready for the learning curve. My guess is that well over 90% of the CA riders do it.
post #12 of 13 Old Jun 2nd, 2007, 10:09 am
I'm just telling of my observations as I rode from the AZ/CA border on Rt 40, all the way over to Van Nuys where member 'zippy_gg' lives. I was beginning to wonder if I didn't fully understand when and where I was legally allowed to lane split. And then I rode with zippy_gg (Gilles), and all became right as rain. We lane split EVERYWHERE! And anybody worried about lane-splitting with the big LT, just ride with Gilles for a day. He's very good. I guess learning to ride in France does have it's advantages.
post #13 of 13 Old Jun 2nd, 2007, 7:03 pm
That's the one little bright thing about So Ka traffic. If you ride, you can lane split and creep to the front of the traffic line at signals.
Lane Splitting - Legal in your state? KYchris02 Bike Talk 62 Jan 21st, 2007 1:54 pm
Splitting Traffic ELKHNTR Chit Chat 29 Jul 3rd, 2006 1:22 am
Lane splitting, anybody?? DBHutchins Ride Tales 3 Mar 9th, 2006 3:20 pm
Lane splitting .... sorry, remind me again. rmg08057 Australia, New Zealand, and AsiaPac 8 Jan 11th, 2006 8:21 pm
Lane Splitting article amarider Northern California 39 Oct 15th, 2005 11:27 pm
