Foot Brakes - BMW Luxury Touring Community
post #1 of 7 Old Sep 1st, 2006, 11:46 am Thread Starter
Unhappy Foot Brakes
My rear brake fluid indicator is empty on my 2000 KLT and I do not have any brakes using the foot brake. The hand brakes work fine and the brake fluid level on each handle bar are within the bulls eye. Where is the inlet to fill the rear brake reservoir?
storm is offline
post #2 of 7 Old Sep 1st, 2006, 12:37 pm
The brake fluid reservoir on the right handlebar is for the front brake control circuit. It is not directly connected to the front brakes.
The reservoir for the front and rear brake wheel circuits is on the right hand side of the bike almost directly behind where the right saddlebag meets the right side tupperware. It is difficult to see or to get to unless you remove the tupperware. You have to remove the right passenger foot plate and I believe that there are 4 screws holding on the tupperware. The reservoir has 2 chambers in a single housing. I don't believe that the 2000 LT's have a level sensor so the fill level is not as critical as on the newer models (they have to be at the max level or you get flashing ABS lights).
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #3 of 7 Old Sep 1st, 2006, 12:37 pm
Zotter's Avatar
Genericly:
Lift seat
Right side - toward the rear
Look just forward of the curve of the fender panel
Usually have to remove the R side battery cover to get to it.
But - you don't mention what year your bike is - it can vary a bit.
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #4 of 7 Old Sep 1st, 2006, 1:16 pm
mtrevelino's Avatar
Have you noticed anything leaking by the rear wheel? On my 2000LT, I had to replace the rear brake line. The rubber lines only last so long, and if they are anything like the rubber used for the rear main seal, I would change all the rubber brake lines immediately!
Mike Trevelino
Williamsburg, VA
2008 RT - Sold December 2019
mtrevelino is offline
post #5 of 7 Old Sep 1st, 2006, 1:28 pm
The 2000 has one small reservoir under the rear seat on the right side. If you are careful you can refill it without taking off much if any tupperware. Be careful not to get any fluid on your paint. If you have a leak - you need to fix that first - and be sure to get any air out of the line.
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
post #6 of 7 Old Sep 1st, 2006, 2:50 pm
zaphod's Avatar
I believe that is only true for the integrated brakes. The 2000's brakes are not connected.
With the rear brakes so low that they don't work, make sure you bleed the system after you fill it up. If you don't have speed bleeders on already, get some. Do a search on speed bleeders for the full scoop.
Malcolm McGee
Little Rock, AR
'00 K1200LTC Canyon Red
'09 Kawasaki KLR 650
'96 Bunkhouse
IBA #24557
BMWMOA #117769
zaphod is offline
post #7 of 7 Old Sep 2nd, 2006, 12:57 am
Yep, only one rear brake reservoir on the standard ABS brakes ('99-'01 bikes, calipers say "Brembo"). See pic below. But I also agree that you need to find out why it is empty, fix it, and then bleed everything properly.
Do your brakes click markbreen K1200LT 20 Apr 2nd, 2012 10:35 pm
K1200LT Foot Peg Changes -- Rider & Passenger hschisler Ergonomics & Rider Comfort 25 Dec 10th, 2009 7:42 am
Power brakes: TOO sensitive? dshealey K1200/1300GT (The Next Generation) 6 Sep 29th, 2006 2:24 pm
Extended brake pedal, helps the use of the foot brake pozo_izquierdo K1200LT 1 Jul 30th, 2006 4:40 pm
I got a letter from BMW! dry_rider K1200LT 33 Jan 2nd, 2006 12:34 pm
